Old 11-11-2017, 01:57   #19366 (permalink)
Member: 1710424
Thanks Meter: 22
Samsung S6 Edge ATT G925A Repair IMEI & Unlock Network
@thanhnamPDAviet
Waiting ADB device... OK
Reading phone info...
Model: SAMSUNG-SM-G925A
Android version: 6.0.1
Product code:
Phone version: G925AUCU6EQCF
PDA version: G925AUCS5DPK5
CSC version: G925AATT5DPK5
CSC country code: USA
CSC sales code: ATT
HW version:
Phone SN:
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2017-01-01
RF cal date:
IMEI: 350000000000006
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Initialization zTool... OK
Running zTool, please wait... OK
HWID: 88 51 04 EE D5 04 00 00 00 00 00 00 00 00 00 00
Calculating... OK
Initialization AT RIL...
AT RIL stopped, restarting... OK
Checking for compatible phone and cert
Phone KEY ID: 0346
Checking certificate file... OK
KEY ID: 0346
Crypting CERT 1... OK
Writing NV data... OK
Rebooting phone... OK
Write CERT done
Old 11-11-2017, 01:58   #19367 (permalink)
Member: 1710424
Thanks Meter: 22
Samsung S7 Edge Docomo SC-02H Unlock Network
@thanhnamPDAviet
Please, allow USB debugging on phone... OK
Model: SC-02H
Android version: 7.0
Product code: SM-G935DZBADCM
Phone version: SC02HOMU1BQH1
PDA version: SC02HOMU1BQH1
CSC version: SC02HDCM1BQH1
CSC country code: JP
CSC sales code: DCM
HW version: REV0.4
Phone SN: RF8HC1T8T9D
Chip name: MSM8996
Modem board: MSM8996
Security patch: 2017-08-01
RF cal date: 2016.12.16
IMEI: 356817075844XXX
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM6 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 20418072
NET lock: 42849260
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Old 11-11-2017, 20:44   #19368 (permalink)
Member: 399404
Thanks Meter: 29
UNLOCK INSTRUCTIONS:
Micro-USB cable:
1. Phone must be powered on.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and choose 'DM/DUN over HSIC' (ignore it, if it's not available).
4. Reboot phone.
Or use 'Activate Diag' function from 'Repair' tab.
5. Connect USB cable, install drivers if needed.
6. Select Samsung diagnostic port in port settings.
7. Press 'Unlock' button for direct unlock.
Operation: Unlock
Selected model: SM-N910A
Selected port: COM92 SAMSUNG Mobile USB Serial Port
Software version: 29.7
Reading IMEI... OK
IMEI: 354483064194749
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool PRO v.29.7
Old 11-11-2017, 23:11   #19369 (permalink)
Member: 399404
Thanks Meter: 29
Direct Unlock:
3. Type *#9090# and choose 'DM/DUN over HSIC'.
4. Reboot phone.
7. Press 'Unlock' button and select 'Unlock' option.
Domestic Unlock:
1. Power on the phone.
2. Enable 'USB debugging' in 'Settings'-'Developer options',
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'.
3. Connect the phone to PC with USB cable, install drivers if needed.
5. Select device in ADB settings.
6. Press 'Unlock' button and select 'Domestic unlock' option.
Operation: Unlock
Selected model: SM-G900P
Model: SM-G900P
Product code: Not Active
Phone version: G900PVPS3CQD1
PDA version: G900PVPS3CQD1
CSC version: G900PSPT3CQD1
CSC sales code: SPR
HW version: G900P.04
Phone SN: 00000000000
Modem board: MSM8974PRO
Security patch: 2017-04-01
RF cal date: 2014.11.11
IMEI: 990004733917370
Writing AT RIL... OK
Initialization AT RIL... root required
Initialization AT RIL... OK
Unlocking... OK
Unlock done
The Following User Says Thank You to qtouch For This Useful Post:
Old 11-12-2017, 02:35   #19370 (permalink)
kjava's Avatar
Member: 846616
Sonork: 100.1675590
Thanks Meter: 514
[ 11/12/2017 9:25:00 AM ] Operation: Read Codes via Server
[ 11/12/2017 9:25:00 AM ] Selected model: SM-G935A
[ 11/12/2017 9:25:00 AM ] Software version: 29.7
[ 11/12/2017 9:25:00 AM ] Waiting ADB device...
[ 11/12/2017 9:25:00 AM ] Please, allow USB debugging on phone... OK
[ 11/12/2017 9:26:00 AM ] Reading phone info...
[ 11/12/2017 9:26:00 AM ] Model: SAMSUNG-SM-G935A
[ 11/12/2017 9:26:00 AM ] Android version: 7.0
[ 11/12/2017 9:26:00 AM ] Product code: SM-G935AZKAATT
[ 11/12/2017 9:26:00 AM ] Phone version: G935AUCS4BQE1
[ 11/12/2017 9:26:00 AM ] PDA version: G935AUCS4BQE1
[ 11/12/2017 9:26:00 AM ] CSC version: G935AATT4BQE1
[ 11/12/2017 9:26:00 AM ] CSC country code: USA
[ 11/12/2017 9:26:00 AM ] CSC sales code: ATT
[ 11/12/2017 9:26:00 AM ] HW version: REV0.7
[ 11/12/2017 9:26:00 AM ] Phone SN: R38H50KWCSJ
[ 11/12/2017 9:26:00 AM ] Chip name: MSM8996
[ 11/12/2017 9:26:00 AM ] Modem board: MSM8996
[ 11/12/2017 9:26:00 AM ] Security patch: 2017-05-01
[ 11/12/2017 9:26:00 AM ] RF cal date: 2016.05.18
[ 11/12/2017 9:26:00 AM ] IMEI:
[ 11/12/2017 9:26:00 AM ] Rebooting phone... OK
[ 11/12/2017 9:26:00 AM ] Waiting ADB device... OK
[ 11/12/2017 9:27:00 AM ] Rebooting phone... OK
[ 11/12/2017 9:27:00 AM ] Waiting ADB device... OK
[ 11/12/2017 9:28:00 AM ] Initialization zTool... OK
[ 11/12/2017 9:28:00 AM ] Running zTool, please wait...
[ 11/12/2017 9:28:00 AM ] Start... OK
[ 11/12/2017 9:28:00 AM ] Initialization... OK
[ 11/12/2017 9:28:00 AM ] Generate and check client proof... OK
[ 11/12/2017 9:28:00 AM ] Verify proof by client... OK
[ 11/12/2017 9:28:00 AM ] Reading data from phone... OK
[ 11/12/2017 9:28:00 AM ] Searching Ramdump interface... COM6 detected
[ 11/12/2017 9:29:00 AM ] Reading data from phone... OK
[ 11/12/2017 9:29:00 AM ] Calculating... OK
[ 11/12/2017 9:29:00 AM ] Searching server... OK
[ 11/12/2017 9:29:00 AM ] Waiting for server answer... OK
[ 11/12/2017 9:30:00 AM ] Freeze code: 83649640
[ 11/12/2017 9:30:00 AM ] NET lock: 47520728
[ 11/12/2017 9:30:00 AM ] SUB lock: 00000000
[ 11/12/2017 9:30:00 AM ] SP lock: 00000000
[ 11/12/2017 9:30:00 AM ] CP lock: 00000000
[ 11/12/2017 9:30:00 AM ] For check lock status: *#7465625#
Old 11-12-2017, 08:20   #19371 (permalink)
gsmali40's Avatar
Member: 2707726
Sonork: 100.1675740
Thanks Meter: 119
SAMSUNG J530F UNLOCK DONE BY Z3X 100000%............
The Following User Says Thank You to gsmali40 For This Useful Post:
Old 11-12-2017, 10:10   #19372 (permalink)
gsmali40's Avatar
Member: 2707726
Sonork: 100.1675740
Thanks Meter: 119
SAMSUNG G570F UNLOCK DONE BY Z3X 100000%............
Old 11-12-2017, 12:30   #19373 (permalink)
Member: 2682425
Thanks Meter: 79
thanks thanks Z3X For the Files
SM-J730F
Combination and for the firmware
File analysis... OK
Total file size: 0xAFBDBF04 (2811 Mb)
Searching USB Flash interface... COM3 detected
Setup connection... OK
Reading PIT from phone... OK
Sending sboot.bin... OK
Sending param.bin... OK
Sending cm.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img... OK
Sending modem.bin... OK
Sending cache.img... OK
Sending hidden.img... OK
Flashing done (time - 00:02:18)
Done with Samsung Tool PRO v.29.6
Old 11-13-2017, 09:13   #19374 (permalink)
Member: 1972804
Thanks Meter: 15
please help
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will apear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
If you have it voided (0x01(void)), then you can't unlock this phone using sever.
4. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings)
Selected model: SM-J330FN
Software version: 29.7.2
Checking Login and Password... OK
Ballance: 5 crd.
You have 5 credit(s) left. This opreratin takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM440
Reading phone info... OK
Model: SM-J330FN
AP version: J330FNXXU1AQF9
CSC version: J330FNBTU1AQF2
CP version: J330FNXXU1AQF7
Product code: BTU
Phone SN: R58J86S0JFN
Unique number: CQE00DBA9D70084
Searching Samsung diag port... detected COM439
CP build: Jun 15 2017 15:50:55
Reading data from phone... error (1)
Done with Samsung Tool PRO v.29.7.2
Old 11-13-2017, 10:57   #19375 (permalink)
Member: 2643730
Thanks Meter: 217
sm-g935fd flashing error
sm-g935fd flashing error at system , back side says sm-g935fd , inside dm mode its sm-g935f
firmware is AP_G935FXXS1DQHK
BL_G935FXXS1DQHK
CP_G935FXXU1DQE7
CSC_ODD_G935FODD1DQE1
HOME_CSC_ODD_G935FODD1DQE1
Old 11-13-2017, 14:32   #19376 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 271
Ballance: 50 crd.
You have 50 credit(s) left. This opreratin takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM80
Model: SM-J330FN
AP version: J330FNXXU1AQI1
CSC version: J330FNVFG1AQI1
CP version: J330FNXXU1AQF1
Product code: CNX
Phone SN: R58JA0G4DLL
Unique number: CQE00E8FCD83A94
Searching Samsung diag port... detected COM79
CP build: Jun 1 2017 14:22:06
Calculating... OK
Freeze code: 42470508
NET lock: 13792792
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 11-13-2017, 17:01   #19377 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,293
Samsung J500H Frp Reset
Operation: Reset FRP/React/EE
Selected model: SM-J500H
Software version: 29.6
Searching Samsung USB Flash interface... COM5 detected
Searching FRP lock... OK
Erasing FRP lock... OK
Reset done
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
The Following User Says Thank You to Tanha0321 For This Useful Post:
Old 11-13-2017, 17:02   #19378 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,293
Samsung G361H Frp Reset
Selected model: SM-G361H
Searching Samsung USB Flash interface... COM8 detected
Erasing FRP... OK
Searching Reactivation lock... not supported
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Old 11-13-2017, 17:02   #19379 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,293
Samsung J120G Frp Reset
Selected model: SM-J120G
Reset done
Old 11-13-2017, 17:03   #19380 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,293
Samsung G531H Frp Reset
Selected model: SM-G531H
Erasing FRP... OK
Reset done
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1615 Today 10:38
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Page generated in 0.63767 seconds with 9 queries
