01-11-2018, 05:52 | #19756 (permalink) |
No Life Poster Join Date: May 2008
Member: 775581 Status: Offline Thanks Meter: 186 | J320ZN read codes done. Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J320ZN Software version: 30.4 Checking Login and Password... could not connect to server Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J320ZN Android version: 5.1.1 Product code: SM-J320ZZKNTLP Phone version: J320ZNDOU1AQH1 PDA version: J320ZNDOU1AQH1 CSC version: J320ZNTLP1AQH1 CSC country code: Australia CSC sales code: TLP HW version: MP 0.200 Phone SN: R58J55JF3NT Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-08-01 RF cal date: 2017.05.25 IMEI: Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM24 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 15372097 NET lock: 86420713 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.4 |
01-11-2018, 06:03 | #19757 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Read Codes via Server Selected model: SM-N950F Software version: 30.4 Checking Login and Password... OK Ballance: 18 crd. You have 18 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM743 Reading phone info... OK Model: SM-N950F AP version: N950FXXU2BQKG CSC version: N950FOVF2BQKG CP version: N950FXXU2BQKG Product code: VOD Phone SN: R58JA60YEPV Unique number: 988A9C31314349445530 Searching Samsung diag port... detected COM744 Reading phone info... OK CP version: N950FXXU2BQKG CP build: Nov 29 2017 10:27:46 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 04150318 NET lock: 27460290 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.4 |
01-11-2018, 18:32 | #19759 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | J327T1 UNLOCK DONE Operation: Unlock Selected model: SM-J327T1 Software version: 30.4 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J327T1 Android version: 7.0 Product code: SM2J327TZKATMK Phone version: J327T1UVU1AQK6 PDA version: J327T1UVU1AQK6 CSC version: J327T1TMK1AQK6 CSC country code: USA CSC sales code: TMK HW version: REV0.1 Phone SN: RV8J917FFLD Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-11-01 RF cal date: 20170919 IMEI: 352001092270711 Searching Samsung diag port... detected COM40 Reading phone info... OK CP version: J327T1UVU1AQK6 CP build: Nov 20 2017 14:50:17 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
01-12-2018, 11:16 | #19761 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | g610f ds patch cert done Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZDDMID Phone version: G610FDDU1AQF4 PDA version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CSC country code: Iraq CSC sales code: MID HW version: MP 0.400 Phone SN: R58J92FEM0B Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20170916 IMEI: 358105012600ccc Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.30.4 |
01-12-2018, 18:13 | #19762 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | LG GPad 7.0 45 units DONE! Code: Mode: Normal Model: DAAAANAZ Build version: May 8 201722:47:54Mar 11 201503:00:00DAAAANAZ SW Version: MPSS.DI.2.0.1.c1.15-00046-M8926DAAAANAZM-1 IMEI: 014097006XXXXX BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.43) Direct unlock Working with security zone Checking phone at COM80 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM79 Reboot phone Done Elapsed: 51 secs. --> (v9.43) |
01-12-2018, 20:11 | #19763 (permalink) |
No Life Poster Join Date: May 2005 Location: Tirana Age: 43
Member: 143851 Status: Offline Thanks Meter: 162 | G930T successfully unlocked. Operation: Unlock Selected model: SM-G930T Selected port: COM70 Z3X BOX Serial Port Software version: 30.4 Checking Login and Password... OK .. Model: SM-G930T Android version: 7.0 Product code: SM-G930TZDATMB Phone version: G930TUVS4BQL2 PDA version: G930TUVS4BQL2 CSC version: G930TTMB4BQL2 CSC country code: USA CSC sales code: TMB HW version: REV0.6 Phone SN: R58H443G2GL Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-12-01 RF cal date: 2016.04.25 IMEI: 355916073121046 Rebooting phone... OK Waiting ADB device... Please, allow USB debugging on phone... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM25 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
01-12-2018, 22:20 | #19764 (permalink) |
Insane Poster Join Date: Apr 2010 Location: Nigeria
Member: 1278018 Status: Offline Sonork: 100.1683773 Thanks Meter: 13 | [ 1/12/2018 6:12:00 PM ] Checking Login and Password... OK [ 1/12/2018 6:12:00 PM ] Ballance: 30 crd. [ 1/12/2018 6:12:00 PM ] You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes [ 1/12/2018 6:12:00 PM ] Waiting ADB device... OK [ 1/12/2018 6:12:00 PM ] Reading phone info... [ 1/12/2018 6:12:00 PM ] Model: SM-G935T [ 1/12/2018 6:12:00 PM ] Android version: 7.0 [ 1/12/2018 6:12:00 PM ] Product code: SM2G935TZDATMB [ 1/12/2018 6:12:00 PM ] Phone version: G935TUVS4BQL2 [ 1/12/2018 6:12:00 PM ] PDA version: G935TUVS4BQL2 [ 1/12/2018 6:12:00 PM ] CSC version: G935TTMB4BQL2 [ 1/12/2018 6:12:00 PM ] CSC country code: USA [ 1/12/2018 6:12:00 PM ] CSC sales code: TMB [ 1/12/2018 6:12:00 PM ] HW version: REV0.7 [ 1/12/2018 6:12:00 PM ] Phone SN: RF8HB0ELHYN [ 1/12/2018 6:12:00 PM ] Chip name: MSM8996 [ 1/12/2018 6:12:00 PM ] Modem board: MSM8996 [ 1/12/2018 6:12:00 PM ] Security patch: 2017-12-01 [ 1/12/2018 6:12:00 PM ] RF cal date: 2016.11.03 [ 1/12/2018 6:12:00 PM ] IMEI: 356164075437263 [ 1/12/2018 6:12:00 PM ] Rebooting phone... OK [ 1/12/2018 6:12:00 PM ] Waiting ADB device... OK [ 1/12/2018 6:13:00 PM ] Rebooting phone... OK [ 1/12/2018 6:13:00 PM ] Waiting ADB device... OK [ 1/12/2018 6:13:00 PM ] Waiting for device to become ready... OK [ 1/12/2018 6:14:00 PM ] Initialization zTool... OK [ 1/12/2018 6:14:00 PM ] Running zTool, please wait... [ 1/12/2018 6:14:00 PM ] Start... OK [ 1/12/2018 6:14:00 PM ] Initialization... OK [ 1/12/2018 6:14:00 PM ] Generate and check client proof... OK [ 1/12/2018 6:14:00 PM ] Verify proof by client... OK [ 1/12/2018 6:14:00 PM ] Reading data from phone... OK [ 1/12/2018 6:14:00 PM ] Rebooting to upload... OK [ 1/12/2018 6:14:00 PM ] Searching Ramdump interface... COM4 detected [ 1/12/2018 6:14:00 PM ] Reading data from phone... OK [ 1/12/2018 6:14:00 PM ] Calculating... OK [ 1/12/2018 6:14:00 PM ] Searching server... OK [ 1/12/2018 6:15:00 PM ] Waiting for server answer... OK [ 1/12/2018 6:15:00 PM ] Waiting ADB device... OK [ 1/12/2018 6:15:00 PM ] Waiting for device to become ready... OK [ 1/12/2018 6:15:00 PM ] Initialization zTool... OK [ 1/12/2018 6:15:00 PM ] Running zTool, please wait... [ 1/12/2018 6:15:00 PM ] Start... OK [ 1/12/2018 6:15:00 PM ] Initialization... OK [ 1/12/2018 6:15:00 PM ] Generate and check client proof... OK [ 1/12/2018 6:15:00 PM ] Verify proof by client... OK [ 1/12/2018 6:15:00 PM ] Reading data from phone... OK [ 1/12/2018 6:16:00 PM ] Rebooting phone... OK [ 1/12/2018 6:16:00 PM ] Unlock done |
01-13-2018, 10:06 | #19765 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | G935T direct unlock done Code: 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G935T Selected port: COM8 USB Serial Port Software version: 30.4 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G935T Android version: 7.0 Product code: SM-G935TZSATMB Phone version: G935TUVS4BQL2 PDA version: G935TUVS4BQL2 CSC version: G935TTMB4BQL2 CSC country code: USA CSC sales code: TMB HW version: REV0.7 Phone SN: RF8H32YRCKX Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-12-01 RF cal date: 2017.01.12 IMEI: 35775107*****72 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM5 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
01-13-2018, 13:59 | #19766 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: morocco Age: 36
Member: 1917054 Status: Offline Thanks Meter: 268 | G935F reset frp done Quote:
01-13-2018, 16:26 | #19767 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | J710F Reset FRP SUCCESS Operation: Reset FRP Selected model: SM-J710F Software version: 30.5 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZDNXEF Phone version: J710FXXU3AQF4 PDA version: J710FXXU3AQF8 CSC version: J710FXEF3AQF1 CSC country code: France CSC sales code: XEF HW version: MP 0.300 Phone SN: RF8H635X49K Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-06-01 RF cal date: 20160630 IMEI: 357125072544202 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.5 |
01-13-2018, 19:32 | #19768 (permalink) |
Freak Poster Join Date: Dec 2011 Location: ALGERIA
Member: 1706377 Status: Offline Thanks Meter: 61 | sm-j530f root and unlock done: Operation: Unlock Selected model: SM-J530F Software version: 30.5 Waiting ADB device... OK Reading phone info... Model: SM-J530F Android version: 7.0 Product code: SM-J530FZDAACR Phone version: J530FXXU1AQI3 PDA version: J530FXWU1AQK1 CSC version: J530FOJV1AQK1 CSC country code: GHANA CSC sales code: ACR HW version: MP 0.500 Phone SN: R58J92JJLVN Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-08-01 RF cal date: 20170913 IMEI: 352947091****** Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Rebooting phone... OK Waiting ADB device... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 37 44 B5 B0 AC 21 A1 06 96 88 5C A9 4D C4 A9 59 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.5 |
01-13-2018, 21:37 | #19769 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Panama
Member: 2117710 Status: Offline Thanks Meter: 70 | SM-N950U TMB Unlock done SM-N950U TMB Unlock done. Code: Operation: Unlock Selected model: SM-N950U Selected port: COM1 Puerto de comunicaciones Software version: 30.4 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N950U Android version: 7.1.1 Product code: SM-N950UZVATMB Phone version: N950USQU2BQLA PDA version: N950USQU2BQLA CSC version: N950UOYN2BQLA CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R28J84CJSBT Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-12-01 RF cal date: 2017.08.30 IMEI: 3518xxxxxxx Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM31 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
01-14-2018, 08:27 | #19770 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Checking Login and Password... OK Ballance: 8 crd. You have 8 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-N950U Android version: 7.1.1 Product code: SM-N950UZKACCT Phone version: N950USQS2BQK2 PDA version: N950USQS2BQK2 CSC version: N950UOYN2BQK2 CSC country code: USA CSC sales code: CCT HW version: REV1.0 Phone SN: R28J92D510M Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-11-01 RF cal date: 2017.09.19 IMEI: 358508080167570 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM30 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 39190926 NET lock: 52481852 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.5 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
