Old 01-13-2018, 21:37   #19786 (permalink)
Member: 2117710
Thanks Meter: 22
Thumbs up SM-N950U TMB Unlock done
SM-N950U TMB Unlock done.
Operation: Unlock
Selected model: SM-N950U
Selected port: COM1 Puerto de comunicaciones
Software version: 30.4
Checking Login and Password... OK
Ballance: 20 crd.
You have 20 credit(s) left. This operation takes 10 credits.Continue?  Yes
Waiting ADB device...
Please, allow USB debugging on phone... OK
Reading phone info...
Model: SM-N950U
Android version: 7.1.1
Product code: SM-N950UZVATMB
Phone version: N950USQU2BQLA
PDA version: N950USQU2BQLA
CSC version: N950UOYN2BQLA
CSC country code: USA
CSC sales code: TMB
HW version: REV1.0
Phone SN: R28J84CJSBT
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2017-12-01
RF cal date: 2017.08.30
IMEI: 3518xxxxxxx
Rebooting phone... OK
Waiting ADB device... OK
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Rebooting to upload... OK
Searching Ramdump interface... COM31 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Start... OK
Unlock done
Done with Samsung Tool PRO v.30.4
Old 01-14-2018, 08:27   #19787 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 200
Ballance: 8 crd.
You have 8 credit(s) left. This operation takes 5 credits.Continue? Yes
Model: SM-N950U
Product code: SM-N950UZKACCT
Phone version: N950USQS2BQK2
PDA version: N950USQS2BQK2
CSC version: N950UOYN2BQK2
CSC sales code: CCT
HW version: REV1.0
Phone SN: R28J92D510M
Chip name: MSM8998
Security patch: 2017-11-01
RF cal date: 2017.09.19
IMEI: 358508080167570
Start... OK
Searching Ramdump interface... COM30 detected
Calculating... OK
Freeze code: 39190926
NET lock: 52481852
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.30.5
Old 01-14-2018, 08:46   #19788 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 200
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will apear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Read Codes via Server
Selected model: SM-J320ZN
Selected port: COM783 SAMSUNG Mobile USB Serial Port
Software version: 30.5
Ballance: 95 crd.
You have 95 credit(s) left. This operation takes 5 credits.Continue? Yes
Model: SM-J320ZN
Android version: 5.1.1
Product code: SM-J320ZZKNTLP
Phone version: J320ZNDOU1AQH1
PDA version: J320ZNDOU1AQH1
CSC version: J320ZNTLP1AQH1
CSC country code: Australia
CSC sales code: TLP
HW version: MP 0.200
Phone SN: R58H854AJ4H
Chip name: MSM8916
Modem board: MSM8916
Security patch: 2017-08-01
RF cal date: 2016.08.30
IMEI:
Start... OK
Searching Ramdump interface... COM9 detected
Calculating... OK
Freeze code: 64263038
NET lock: 53904259
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Old 01-14-2018, 08:47   #19789 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 200
Ballance: 95 crd.
Model: SM-J320ZN
CSC sales code: TLP
Chip name: MSM8916
IMEI:
Start... OK
Calculating... OK
NET lock: 53904259
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Old 01-14-2018, 13:24   #19790 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 600
Wink
old samsung e2152 phone lock removed ok
Old 01-14-2018, 14:17   #19791 (permalink)
EjazATF's Avatar
Member: 2192499
Sonork: Stopped using..
Thanks Meter: 1,499
Sm-j530f/ds frp 7.0
SM-J530F/DS
FRP Removed Successfully using ADB method of z3x
Model: SM-J530F
Android version: 7.0
Product code: SM-J530FZDDPAK
Phone version: J530FXXU1AQED
PDA version: J530FXWU1AQF1
CSC version: J530FOJV1AQF3
CSC country code: PAKISTAN
CSC sales code: PAK
HW version: REV0.5B
Phone SN: R28J642DHMR
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2017-06-01
RF cal date: 20170630
IMEI: 3564xxxxxxxxxxxx
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
The Following 3 Users Say Thank You to EjazATF For This Useful Post:
Old 01-14-2018, 15:29   #19792 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 66
Unlock A520W 100%
Selected model: SM-A520W
Checking Login and Password... Listo
Ballance: 35 crd.
You have 35 credit(s) left. This operation takes 5 credits.Continue? Si
Searching Samsung modem... detectado COM100
Leyendo información del teléfono ... Listo
Modelo: SM-A520W
AP version: A520WVLS1AQH1
CSC version: A520WOYA1AQH1
CP version: A520WVLS1AQH1
Código del Producto: SM-A520WZKABMC
Phone SN: R58J54RDHFH
Número único: CBJ100F6565FA34
Searching Samsung diag port... detectado COM99
CP build: Aug 3 2017 19:04:44
Lectura de datos desde el teléfono ... Listo
Calculando... Listo
Buscando servidor... Listo
Waiting for server answer... Listo
Congelar código: 64642639
NET lock: 31315136
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Para comprobar bloquea el estado: *#7465625#
Old 01-14-2018, 17:46   #19793 (permalink)
technomak's Avatar
Member: 2035802
Sonork: 100.1675827
Thanks Meter: 52
Samsung j320f ssuccessfully unlocked !
Selected model: SM-J320F
Searching Samsung modem... detected COM991
Reading phone info... OK
Model: SM-J320F
Version: J320FXXU0AQK2/J320FDBT0AQK1/J320FXXU0AQI1/J320FXXU0AQK2
Product code: SM-J320FZKDDBT
Phone SN: RV8J50YDEWR
IMEI: 356440087616072
Unique number: CQN00D0614FC434
Reading codes... OK
Please wait, calculating codes... OK (time - 00:00:30)
Freeze code: 41482504
NET lock: 38538264
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 01-14-2018, 17:56   #19794 (permalink)
technomak's Avatar
Member: 2035802
Sonork: 100.1675827
Thanks Meter: 52
G935f frp reset done by UFS method !!
Operation: Reset FRP UFS
Selected model: SM-G935F
Selected port: COM4 Z3X BOX Serial Port
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds
Checking phone at COM4 OK
Phone detected, do not release 'Vol down'
Release 'Vol down' now
Comparing selected model... match (G935F)
Setup connection... OK
Reseting FRP... OK
Reset FRP done
Old 01-15-2018, 09:35   #19795 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1659400
Thanks Meter: 809
Wink j120a read codes diag mode
Operation: Read Codes DIAG
Selected model: SM-J120A
Checking hash file... OK
Searching Samsung modem... detected COM90
Model: SM-J120A
AP version: J120AUCU2APJ2
CSC version: J120AATT2APJ2
CP version: J120AUCU2APJ2
Product code: SM2J120AZWCATT
Phone SN: R58J14FPCAY
Unique number: CFN00A6BEEE9FC3
Searching Samsung diag port... detected COM89
CP build: Oct 13 2016 18:53:03
Reading NV data... OK
Modem board: SHANNON308
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:56)
Freeze code: 85084636
NET lock: 40483513
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 01-15-2018, 11:02   #19796 (permalink)
sr8787's Avatar
Member: 788946
Thanks Meter: 378
Samsung j1 Ace Unlock done
Selected model: SM-J111F
Searching Samsung modem... detected COM25
Model: SM-J111F
Version: J111FXXU0AQD2/J111FOLB0APL2/J111FXXU0AQC2/J111FXXU0AQD2
Product code: SM-J111FZWDXME
Phone SN: RV8J90WLH5T
IMEI: 35262109xxxxxxx
Unique number: CFN00C1C6D05F64
Reading codes... OK
Please wait, calculating codes... OK (time - 00:01:37)
Freeze code: 90582418
NET lock: 60374070
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Thanks z3x Team
Old 01-15-2018, 12:32   #19797 (permalink)
Member: 1732025
Sonork: 100.1615024
Thanks Meter: 338
Thumbs up Samsung j327p unlock done !!!!!
Model: SM-J327P
Android version: 6.0.1
Product code: Not Active
Phone version: J327PVPU1AQF4
PDA version: J327PVPU1AQF4
CSC version: J327PSPT1AQF4
CSC sales code: SPR
HW version: J327P.03
Phone SN: 00000000000
Modem board: MSM8917
RF cal date: 2017.02.18
IMEI: 352510082626443
Writing AT RIL... OK
Initialization AT RIL... OK
Unlocking... OK
Unlock done
Old 01-15-2018, 22:26   #19798 (permalink)
chipscell25's Avatar
Member: 1537078
Sonork: celular center
Thanks Meter: 211
G935T unlock done
Operation: Unlock
Selected model: SM-G935T
Ballance: 30 crd.
You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-G935T
Product code: SM-G935TZBATMB
Phone version: G935TUVS4BQC1
PDA version: G935TUVU4APIA
CSC version: G935TTMB4APIA
CSC sales code: TMB
HW version: REV0.7
Phone SN: RF8HB2YHTQY
Chip name: MSM8996
Modem board: MSM8996
Security patch: 2016-09-01
RF cal date: 2016.11.23
IMEI: 355018080927257
Start... OK
Searching Ramdump interface... COM3 detected
Calculating... OK
Start... OK
Unlock done
Old 01-16-2018, 05:46   #19799 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 419
Operation: Reset FRP/React/EE
Selected model: SM-J106H
Searching Samsung USB Flash interface... COM13 detected
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP lock... OK
Reset done
Old 01-16-2018, 05:47   #19800 (permalink)
unaiz's Avatar
Member: 1433496
Sonork: 100.1655152
Thanks Meter: 419
Model: SM-J111F
Product code: SM-J111FZKDXSG
Phone version: J111FXXU0AQC2
PDA version: J111FXXU0AQD2
CSC version: J111FOJV0AQD3
CSC country code: UAE
CSC sales code: XSG
Phone SN: RV8J40XQDFZ
Chip name: SC9830I
Modem board: SC9830i
Security patch: 2017-04-01
RF cal date: 2017.04.19
IMEI: 2515925302514f0
Bypass FRP... OK
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1546 Yesterday 12:33
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 17:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.28552 seconds with 9 queries
