03-08-2018, 14:32 | #20236 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | sm-c9000 v7.1.1 frp fail Selected model: SM-C9000 Software version: 30.8 Searching Samsung USB Flash interface... COM151 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... error Done with Samsung Tool PRO v.30.8 |
03-08-2018, 14:59 | #20237 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | S3650 unlock done Selected model: S3650 Selected com port: COM10 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM12 Model: GT-S3650 CountryCode: ATL Factory SW: S3650BAII3 UniqueNumber: 91100000037943 MemoryPhone: K522H1HACC(S3650) Phone IMEI: 35255204418248 /7 Phone S/N: RF9B478832 Phone Bluetooth ID: 54 9B 12 5F 6F AF Phone SW: S3650XXIJ2 Phone HW: MP 0.605 Phone CalData ver: 20110428 Searching server... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:25306424 [NET LOCK]:71947946 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 29 sec Elapsed time: 42 second, sw ver: 3.5.0040 |
03-08-2018, 15:43 | #20238 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Read Codes Selected model: SM-G532M Software version: 30.8 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G532M Android version: 6.0.1 Product code: SM-G532MZKADOR Phone version: G532MUBU1AQF1 PDA version: G532MUMU1AQG5 CSC version: G532MUWE1AQG5 CSC country code: DOMINICAN REPUBLIC CSC sales code: DOR HW version: MP 0.300 Phone SN: R58HC2866QB Chip name: MT6737T Modem board: MT6737T Security patch: 2017-07-01 RF cal date: 20161210 IMEI: 353109xxxxxxxxx Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM3 detected Reading data from phone... OK Please wait, calculating codes... OK (time - 00:01:06) Freeze code: 71913839 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 97353792 SIM lock: -------- For check lock status: *#7465625# Done with Samsung Tool PRO v.30.8 |
03-08-2018, 22:23 | #20239 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | LG 2-3G Tool v9.45 supported models: 1554 Mode: Normal Model: LGMS210A Build version: Dec 11 201712:10:47May 27 201713:00:00LGMS210A SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1 IMEI: 3533410xxxxxxx-9 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.45) Checking Login and Password... OK Ballance: 45 crd. You have 45 credit(s) left. This operation takes 10 credits.Continue? Yes Searching modem interface... found COM30 Reading data from phone... OK Checking root rights... Writing zTool... OK Initialization zTool... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... OK Reading data from phone... OK Unlocking done Elapsed: 412 secs. --> (v9.45) |
The Following User Says Thank You to chipscell25 For This Useful Post: |
03-09-2018, 22:44 | #20242 (permalink) |
Insane Poster Join Date: May 2012
Member: 1754209 Status: Offline Thanks Meter: 21 | G920T Imei change Done REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G920T Software version: 30.9 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 7.0 Product code: Phone version: G920TUVS6FRA3 PDA version: G920TUVS6FRA3 CSC version: G920TTMB6FRA3 CSC country code: USA CSC sales code: TMB HW version: Phone SN: R58G512W5NV Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-01-01 RF cal date: IMEI: 350000000000006 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 51 A4 1C 74 06 00 00 00 00 00 00 00 00 00 00 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.30.9 Sent from my iPhone using Tapatalk |
03-09-2018, 22:45 | #20243 (permalink) |
Member: 1754209 Status: Offline Thanks Meter: 21 | G920T Unlocking done UNLOCK INSTRUCTIONS: New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Unlock Selected model: SM-G920T Software version: 30.9 Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 7.0 Product code: SM2G920TZKATMB Phone version: G920TUVS6FRA3 PDA version: G920TUVS6FRA3 CSC version: G920TTMB6FRA3 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58G512W5NV Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-01-01 RF cal date: 20151012 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 51 A4 1C 74 06 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.9 Sent from my iPhone using Tapatalk |
03-10-2018, 05:42 | #20244 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | samsung SGH-T939 `T`... Mobile unlock done samsung SGH-T939 `T`... Mobile unlock done [IMG][/IMG] Checking phone at COM15 Reading phone info... OK Model: SGH-T939 Country code: ¹Ì±¹ Cal date: 2009-10-24 Factory SW: UVIJ6 Unique number: 60550000473951 Memory phone: KBN00300HA(T939)S Phone SN: R6YSB02722 PDA/CSC version: T939UVJA3 Phone HW: T939UVJA Reading IMEI... OK IMEI: 355078030930777 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.30.9 |
03-10-2018, 06:11 | #20245 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Read Codes DIAG Selected model: SM-G610F Software version: 30.8 Checking hash file... OK Searching Samsung modem... detected COM80 Reading phone info... OK Model: SM-G610F AP version: G610FXWU1BQK3 CSC version: G610FOJW1BQK3 CP version: G610FXXU1BQJ4 Product code: KSA Phone SN: R58K110JLTP Unique number: C000033C4E8ED94 Searching Samsung diag port... detected COM79 Reading phone info... OK CP version: G610FXXU1BQJ4 CP build: Oct 13 2017 19:19:38 Reading data from phone... OK Reading NV data... OK Modem board: SHANNON315 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:00) Freeze code: 39369642 NET lock: 15846931 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.8 |
03-10-2018, 06:11 | #20246 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-J200F Software version: 30.8 Searching Samsung USB Flash interface... COM9 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.8 Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 30.8 Searching Samsung USB Flash interface... COM9 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.30.8 |
03-10-2018, 06:12 | #20247 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-J106H Software version: 30.8 Searching Samsung USB Flash interface... COM13 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.8 |
03-10-2018, 06:13 | #20248 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 30.8 Searching Samsung USB Flash interface... COM9 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.8 |
03-10-2018, 06:13 | #20249 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP Selected model: SM-J111F Software version: 30.8 Waiting ADB device... OK Reading phone info... Model: SM-J111F Android version: 5.1.1 Product code: SM-J111FZKDXSG Phone version: J111FXXU0AQC2 PDA version: J111FXXU0AQD2 CSC version: J111FOJV0AQD3 CSC country code: UAE CSC sales code: XSG HW version: MP 0.200 Phone SN: RV8J40XQDFZ Chip name: SC9830I Modem board: SC9830i Security patch: 2017-04-01 RF cal date: 2017.04.19 IMEI: 2515925302514f0 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.8 |
03-10-2018, 06:14 | #20250 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Read Codes Selected model: SM-J320F Software version: 30.8 Searching Samsung modem... detected COM25 Reading phone info... OK Model: SM-J320F Version: J320FXXU0AQH3/J320FOJV0AQH3/J320FXXU0AQH3/J320FXXU0AQH3 Product code: SM-J320FZDDKSA Phone SN: RV8J91P46SE IMEI: 352414097764713 Unique number: CQN0033896A0B94 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:39) Freeze code: 13637972 NET lock: 28272957 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.8 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
