03-21-2018, 11:43 | #20327 (permalink) | |
Freak Poster Join Date: Feb 2009 Location: afghanistan
Member: 968250 Status: Offline Sonork: 100.1673266 Thanks Meter: 32 | Quote:
Operation: Unlock Selected model: SM-G531F Software version: 31.0 Waiting ADB device... OK Reading phone info... Model: SM-G531F Android version: 5.1.1 Product code: SM-G531FXXXAMO Phone version: G531FXXU1APB2 PDA version: G531FXXU1AOH1 CSC version: CSC country code: CSC sales code: HW version: MP 0.200 Phone SN: R58G706VDDJ Modem board: RF cal date: 20150704 IMEI: 352956070338642 Checking Super user right... true Reading NV data... OK Analyzing SEC file... OK Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... error (2) Done with Samsung Tool PRO v.31.0 Sent from my SM-G532F using Tapatalk | |
03-21-2018, 13:15 | #20328 (permalink) |
Freak Poster Join Date: Feb 2018
Member: 2812378 Status: Offline Thanks Meter: 95 | Checking hash file... OK Searching Samsung modem... detected COM740 Reading phone info... OK Model: SM-G610F AP version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CP version: G610FDDU1AQF4 Product code: SM-G610FZDDKSA Phone SN: R58J91C4F8P Unique number: CAJ002AB7EC7184 Searching Samsung diag port... detected COM741 Reading phone info... OK CP version: G610FDDU1AQF4 CP build: Jun 10 2017 20:51:41 Reading data from phone... OK Reading NV data... OK Modem board: SHANNON315 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 52819040 NET lock: 17041373 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# |
03-21-2018, 13:51 | #20329 (permalink) |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | A530F and A730F hello, both unlocked and have a nice day. UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-A530F Software version: 31.0 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM326 Reading phone info... OK Model: SM-A530F AP version: A530FXXU1AQLC CSC version: A530FOJM1AQLC CP version: A530FXXU1AQLC Product code: MID Phone SN: R58K14425YP Unique number: CCK0077CFFA01B4 Searching Samsung diag port... detected COM325 Reading phone info... OK CP version: A530FXXU1AQLC CP build: Dec 20 2017 14:46:17 Reading data from phone... error (1) Searching server... OK Checking available files... OK Downloading file... OK Checking local file... OK Switching to flash mode... OK Searching USB Flash interface... COM6 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Searching Samsung modem... detected COM326 Reading phone info... OK Model: SM-A530F AP version: A530FXXU1AQLC CSC version: A530FOJM1AQLC CP version: A530FXXU1AQL3 Product code: MID Phone SN: R58K14425YP Unique number: CCK0077CFFA01B4 Searching Samsung diag port... detected COM325 Reading phone info... OK CP version: A530FXXU1AQL3 CP build: Dec 14 2017 15:10:08 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 05735918 NET lock: 96138375 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.31.0 UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-A730F Software version: 31.0 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM330 Reading phone info... OK Model: SM-A730F AP version: A730FXXU1AQLE CSC version: A730FOJM1AQLE CP version: A730FXXU1AQLE Product code: MID Phone SN: RF8K12NMJCK Unique number: CCK00C1CEC022A4 Searching Samsung diag port... detected COM329 Reading phone info... OK CP version: A730FXXU1AQLE CP build: Dec 21 2017 17:19:58 Reading data from phone... error (1) Searching server... OK Checking available files... OK Downloading file... OK Checking local file... OK Switching to flash mode... OK Searching USB Flash interface... COM6 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Searching Samsung modem... detected COM330 Reading phone info... OK Model: SM-A730F AP version: A730FXXU1AQLE CSC version: A730FOJM1AQLE CP version: A730FXXU1ARA1 Product code: MID Phone SN: RF8K12NMJCK Unique number: CCK00C1CEC022A4 Searching Samsung diag port... detected COM329 Reading phone info... OK CP version: A730FXXU1ARA1 CP build: Jan 16 2018 18:43:42 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 60635818 NET lock: 70739639 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.31.0 |
03-21-2018, 14:48 | #20330 (permalink) |
Freak Poster Join Date: Nov 2013
Member: 2059700 Status: Offline Thanks Meter: 18 | grand prime plus read code without root UNLOCK INSTRUCTIONS: Direct unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To read security codes (without root permissions): 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Read Codes Selected model: SM-G532F Software version: 30.1 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZDDMID Phone version: G532FXXU1AQG5 PDA version: G532FXWU1AQG5 CSC version: G532FOJV1AQG5 CSC country code: Iraq CSC sales code: MID HW version: MP 0.300 Phone SN: R58K15SPXSD Chip name: MT6737T Modem board: MT6737T Security patch: 2017-07-01 RF cal date: 20180127 IMEI: 3560710******** Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:39) Freeze code: 42707241 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 04937517 SIM lock: -------- For check lock status: *#7465625# Done with Samsung Tool PRO v.30.1 |
03-21-2018, 22:21 | #20331 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Reset FRP Selected model: SM-G570M Software version: 31.0 Waiting ADB device... OK Reading phone info... Model: SM-G570M Android version: 6.0.1 Product code: SM-G570MWDACDR Phone version: G570MUBU1AQF1 PDA version: G570MUBU1AQF1 CSC version: G570MUWA1AQF1 CSC country code: Dominican Republic CSC sales code: CDR HW version: Rev0.0 Phone SN: R28HC0FRWPD Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-06-01 RF cal date: 20161205 IMEI: 353420xxxxxxxxx Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.31.0 |
03-22-2018, 08:36 | #20332 (permalink) |
Member: 2812378 Status: Offline Thanks Meter: 95 | Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM7 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done |
03-22-2018, 15:41 | #20333 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Unlock Selected model: SM-J500M Selected port: COM289 SAMSUNG Mobile USB Serial Port Software version: 31.0 Reading phone info... Reading IMEI... OK IMEI: 359771xxxxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.31.0 |
03-22-2018, 15:41 | #20334 (permalink) |
03-22-2018, 16:03 | #20335 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Operation: Patch Certificate Selected model: SM-A320F Software version: 30.8 Waiting ADB device... OK Reading phone info... Model: SM-A320F Android version: 7.0 Product code: SM-A320FZDATUR Phone version: A320FXXU2BQG4 PDA version: A320FXXU2BQI3 CSC version: A320FOJV2BQI3 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.300 Phone SN: R28J22SKYNV Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-08-01 RF cal date: 20170218 IMEI: 3xxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.30.8 |
03-22-2018, 16:04 | #20336 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Repair Selected model: SM-A320F Software version: 30.8 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-A320F Android version: 7.0 Product code: SM-A320FZDATUR Phone version: A320FXXU2BQG4 PDA version: A320FXXU2BQI3 CSC version: A320FOJV2BQI3 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.300 Phone SN: R28J22SKYNV Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-08-01 RF cal date: 20170218 IMEI: 3xxxxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 36 05 00 00 00 00 00 00 00 00 00 00 63 D6 08 55 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.30.8 |
03-22-2018, 17:33 | #20337 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Unlock Selected model: SM-A300M Selected port: COM291 SAMSUNG Mobile USB Serial Port Software version: 31.0 Reading phone info... Reading IMEI... OK IMEI: 35983xxxxxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.31.0 |
03-23-2018, 07:08 | #20338 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | samsung SGH-T669 T-mobile unlock done Reading phone info... OK Model: SGH-T669 Country code: ºÏ¹Ì/TMB Cal date: 2010-04-30 Factory SW: UVJD9 Unique number: 00040000318528 Memory phone: K5W2G1HACF(T669)S Phone SN: RPBZ926128 Reading IMEI... OK IMEI: 353652043029512 Reading SYSINFO... OK Searching server... OK Writing sysinfo... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.31.0 |
03-23-2018, 15:08 | #20339 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Unlock Selected model: SGH-M919 Selected port: COM293 SAMSUNG Mobile USB Serial Port Software version: 31.0 Reading phone info... Reading IMEI... OK IMEI: 35908xxxxxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.31.0 |
03-23-2018, 16:21 | #20340 (permalink) |
Crazy Poster Join Date: Feb 2011 Location: sylhet
Member: 1508900 Status: Offline Thanks Meter: 4 | successfully unlock G610f 7.0 Operation: Unlock Selected model: SM-G610F Software version: 29.9 Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 7.0 Product code: SM-G610FZKGXME Phone version: G610FDDU1BQJ4 PDA version: G610FDXU1BQK2 CSC version: G610FOLB1BQK2 CSC country code: MALAYSIA CSC sales code: XME HW version: MP 0.400 Phone SN: R28JC0YX80J Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-08-01 RF cal date: 20171212 IMEI: 35xxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 75 05 00 00 00 00 00 00 00 00 00 00 82 94 15 CF Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.9 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
