04-26-2018, 17:38 | #20521 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | j327a read code Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM155 Reading phone info... Model: SM-J327A AP version: J327AUCS1AQJ1 CSC version: J327AATT1AQJ1 CP version: J327AUCS1AQJ1 Product code: ATT Phone SN: R28JB2GZBSF IMEI: 357153087815748 Unique number: CQ300EEC6E002B4 Searching Samsung diag port... detected COM154 Reading phone info... OK CP version: J327AUCS1AQJ1 CP build: Oct 11 2017 11:05:10 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 35315907 NET lock: 24695847 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.31.4 |
04-28-2018, 16:07 | #20522 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Ukraine
Member: 74053 Status: Offline Thanks Meter: 75 | You solution is fake! No downgrade U5 to U4. Operation: Flash Selected model: SM-A510F Software version: 31.5 File analysis... OK Total file size: 0xADE94B30 (2782 Mb) Searching USB Flash interface... COM16 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending boot.img... error timeout Done with Samsung Tool PRO v.31.5 |
04-28-2018, 17:24 | #20523 (permalink) |
Insane Poster Join Date: May 2012
Member: 1754209 Status: Offline Thanks Meter: 21 | SM-G935T FRP REMOVE You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G935T Android version: 7.0 PDA version: G935TUVS4BRA1 CSC version: G935TTMB4BRA1 Phone version: G935TUVS4BRA1 Product code: SM-G935TZKATMB CSC country code: USA CSC sales code: TMB Phone SN: RF8H52G40FH IMEI: 35721 HW version: REV0.7 RF cal date: 2017.09.12 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2018-01-01 Boot Warranty bit: 0 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.31.5 |
04-28-2018, 17:31 | #20524 (permalink) | ||
Freak Poster Join Date: Apr 2005 Age: 43
Member: 138234 Status: Offline Thanks Meter: 79 | Quote:
04-28-2018, 19:33 | #20525 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Reset FRP Selected model: SM-G532M Software version: 31.5 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G532M Android version: 6.0.1 PDA version: G532MUMU1AQG5 CSC version: G532MUUB1AQG1 Phone version: G532MUBU1AQF1 Product code: SM-G532MZDATPA CSC country code: PANAMA CSC sales code: TPA Phone SN: R58J34AZFTW IMEI: 357485xxxxxxxxx HW version: MP 0.300 RF cal date: 20170321 Chip name: MT6737T Modem board: MT6737T Security patch: 2017-07-01 Boot Warranty bit: 0 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.31.5 |
04-28-2018, 22:32 | #20526 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Reset FRP/React/EE Selected model: SM-J500M Software version: 31.5 Searching Samsung USB Flash interface... COM3 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.31.5 |
04-29-2018, 14:08 | #20528 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Unlock Selected model: SM-G900A Selected port: COM423 SAMSUNG Mobile USB Serial Port Software version: 31.5 Reading phone info... Reading IMEI... OK IMEI: 354691xxxxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.31.5 |
04-30-2018, 16:05 | #20532 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | SM-G928F FLASHING DONE Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G928F Software version: 31.3 File analysis... OK Total file size: 0xF0FDD340 (3855 Mb) Searching USB Flash interface... COM5 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending cache.img... OK Sending hidden.img... OK Sending modem.bin... OK Flashing done (time - 00:03:43) Done with Samsung Tool PRO v.31.3 |
04-30-2018, 17:23 | #20533 (permalink) |
Freak Poster Join Date: Jan 2014 Location: algeria
Member: 2116178 Status: Offline Thanks Meter: 38 | A530F Unlock DONE! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-A530F Software version: 31.5 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM39 Reading phone info... Model: SM-A530F AP version: A530FXXU1AQLC CSC version: A530FOXM1AQLC CP version: A530FXXU1AQLC Product code: ITV Phone SN: R58K211N39X IMEI: 35xxxxxxxxxxxxx IMEI2: 35xxxxxxxxxxx Unique number: CBJ000DA04FDC15 Searching Samsung diag port... detected COM38 Reading phone info... OK CP version: A530FXXU1AQLC CP build: Dec 20 2017 14:46:17 Reading data from phone... error (1) Searching server... OK Checking available files... OK Available CP file for downgrade, try download and flash? Continue? Yes Downloading file... OK Checking local file... OK Switching to flash mode... OK Searching USB Flash interface... COM22 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Searching Samsung modem... detected COM39 Reading phone info... Model: SM-A530F AP version: A530FXXU1AQLC CSC version: A530FOXM1AQLC CP version: A530FXXU1AQL3 Product code: ITV Phone SN: R5xxxxxxxxx IMEI: 35xxxxxxxxxxxxx IMEI2: 35xxxxxxxxxxxxx Unique number: CBJ000DA04FDC15 Searching Samsung diag port... detected COM38 Reading phone info... OK CP version: A530Fxxxxxxxxxxx CP build: Dec 14 2017 15:10:08 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 37251608 NET lock: 58414814 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.31.5 |
05-01-2018, 12:19 | #20534 (permalink) |
Member: 74053 Status: Offline Thanks Meter: 75 | From U4 need delete of CM.bin and sboot.bin Solution is very old. http://www.gsmforum.ru/threads/24177...68#post1304068 http://forum.gsmhosting.com/vbb/f777.../#post12973917 |
05-01-2018, 12:43 | #20535 (permalink) |
Member: 74053 Status: Offline Thanks Meter: 75 | easy way, no first world, no youtube 1. Flash COMBINATION_FAC_FA51_A510FXXU5ARB1_FAC_CL9213193_Q B17042170_REV00_user_mid_noship.tar.md5 2. Enable USB debuging 3. Flash A510FXXU4BQC2_A510FOJV4BQC2_A510FXXU4BQC3_HOME.tar .md5 with uncheked cm.bin and sboot.bin 4. After start ADB is enabled, reset FRP 5. Enable bootloader unlock and factory reset phone |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
