12-10-2009, 13:19 | #257 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | quick and easy samsung genio touch Selected model: S3650 Selected com port: COM3 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM12 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 82 second, sw ver: 3.4.0015 |
12-10-2009, 13:19 | #258 (permalink) |
Member: 288521 Status: Offline Thanks Meter: 685 | Selected model: D600E Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 1313 Sending loader2... OK Flash ID: 00EC22FC000100010034 Unlock block Unlock block Unlock block Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 153 second, sw ver: 3.4.0015 |
12-11-2009, 09:20 | #259 (permalink) |
No Life Poster Join Date: Apr 2009 Age: 41
Member: 1015389 Status: Offline Sonork: 19830303 Thanks Meter: 526 | Last version on support: 2G tools v3.4.0018 Selected model: M120 Selected com port: COM3 Selected speed port: 921600 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: M120DXHD4 IMEI: 35987101053942 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 15 second, sw ver: 3.4.0018 -------------------------------------------------------------------------- |
12-11-2009, 18:25 | #260 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 173741 Status: Offline Thanks Meter: 986 | S5600 "s5600bvida" READ NEWS FOR DETAILS! Searching Samsung USB interface... not found Searching Qualcomm USB interface... detected (COM25) Model: S5600 SW: S5600BVIDA Searching Qualcomm USB interface... detected (COM25) Model: S5600 SW: S5600BVIDA Reading data from phone... OK Reading security... OK Calculating codes... OK (time - 00:00:59) Freeze code... 81959741 NET lock code... 80737958 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 12369874 Activa code... 12369874 How to enter codes: NET: #7465625*638*80737958# Sub: #7465625*782*00000000# SP: #7465625*77*00000000# CP: #7465625*27*00000000# SIM: #7465625*746*12369874# For check lock status: *#7465625# |
12-13-2009, 08:51 | #261 (permalink) |
Junior Member Join Date: Dec 2006
Member: 412883 Status: Offline Thanks Meter: 0 | Selected model: M620 Selected com port: COM83 Selected speed port: 921600 Phone must be ON! Please, connect phone Entering TestMode... OK Start calibrate NVM Calibrate NVM field - fail Calibrate NVM - Ok Repair OTP - ok Elapsed time: 76 second, sw ver: 3.4.0014 ------------------------------------------------------------------------------- Selected model: M620 Selected com port: COM83 Selected speed port: 921600 Phone must be ON! Please, connect phone Entering TestMode... OK SW: M620JPIB1 Langpack: Arabic IMEI: 35580602674830 S/N: RU8QA55802 HW-> XXXXXXXX Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 001 Flash Device ID: 227e3d00 Flash size: 67108864 Bytes Flash sectors: 518 sectors Bluetooth ID: 642f56-664e2f Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE Locks is inactive [NETLOCK]: Use #0111*00000000# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 16 second, sw ver: 3.4.0014 ------------------------------------------------------------------------------- |
12-14-2009, 07:40 | #262 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | Samsung s8000 jet unlock done by the mobile shop with z3x box SEE this report, tested 100% ok work with Z3X BOX. thanks Z3X team, Searching phone at COM interface... ok Searching Samsung USB interface... not found Searching Qualcomm USB interface... detected (COM79) Searching Samsung USB Flash interface... detected (COM78) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:12:34) Searching Samsung USB interface... detected (COM78) Checking mobile state... normal Model: S8000 SW: S8000XEIG2 IMEI: 352028032000445 Searching Samsung USB interface... detected (COM78) Checking mobile state... normal Model: S8000 SW: S8000XEIG2 IMEI: 352028032000445 Unlock as MSL3... OK (time - 00:00:02) BR, themobileshop |
12-14-2009, 14:19 | #263 (permalink) |
Freak Poster Join Date: Jul 2006 Location: india
Member: 306087 Status: Offline Thanks Meter: 24 | Selected model: S5230 Selected com port: COM3 Selected speed port: 921600 Connect phone(RJ 45 cable) and power on - press 2-3 second Detecting UART port..... OK Repower phone - please wait If see on phone "Upload data to PC" - reconnect phone manually Phone must be ON Search modem ... OK Search modem on:COM10 Model: GT-S5230 CountryCode: TSC Factory SW: S5230CFIG2_IG3 UniqueNumber: 55330000665885 MemoryPhone: K522H1HACA(S5230) Phone IMEI: 35795303716325 /9 Phone S/N: RPYSB13047 Phone Bluetooth ID: C8 7E 75 97 ED 06 Phone SW: S5230CFIG2_IG3 Phone HW: MP 0.610 Phone CalData ver: 20091117 Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:84848616 [NET LOCK]:95847269 [Subset LOCK]:00000000 [SP LOCK]:07360381 [CP LOCK]:00000000 Decrypted time: 52 sec Elapsed time: 113 second, sw ver: 3.4.0015 |
12-14-2009, 20:22 | #264 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Europe
Member: 46350 Status: Offline Thanks Meter: 885 | Samsung E1080 unlock done Selected model: E1080 Selected com port: COM36 Selected speed port: 460800 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 50 second, sw ver: 3.4.0005 ------------------------------------------------------------------------------- |
12-15-2009, 05:47 | #265 (permalink) |
No Life Poster Join Date: Dec 2007 Location: shirdi..sai baba.. Age: 36
Member: 662678 Status: Offline Thanks Meter: 2,539 | samsung S3650 sp unlock done with z3x Last version on support: 2G tools v3.4.0018 Selected model: S3650 Selected com port: COM31 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM12 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM13 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 87 second, sw ver: 3.4.0018 |
The Following User Says Thank You to ..::ohm::.. For This Useful Post: |
12-15-2009, 06:02 | #266 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Cuba Age: 45
Member: 1020744 Status: Offline Thanks Meter: 428 | Selected model: E2210 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35282703034128 Phone SW: E2210LUAIE2 Phone BT ADDR: 0025-67-87D8F8 Phone SN: RPVS652438 Deactivated MSL - TRUE Unlock - ok Elapsed time: 17 second, sw ver: 3.4.0014 ------------------------------------------------------------------------------- |
12-15-2009, 06:08 | #267 (permalink) |
Member: 1020744 Status: Offline Thanks Meter: 428 | Selected model: M200 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35826102093037 Phone SW: M200VMHJ1_H Phone BT ADDR: 0023-D7-9EFFAD Phone SN: RVYS128214 Deactivated MSL - TRUE Unlock - ok Elapsed time: 8 second, sw ver: 3.4.0014 ------------------------------------------------------------------------------- |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
