12-27-2009, 15:01 | #302 (permalink) |
Junior Member Join Date: Dec 2008 Location: BANGLADESH
Member: 917195 Status: Offline Thanks Meter: 11 | samsung s5230 successfull 1.cable select j750 2.press direct unlock 3.power on phone Then if show "Selected model: S5230 Selected com port: COM7 Selected speed port: 921600 Connect phone(RJ 45 cable) and power on - press 2-3 second Detecting UART port..... OK Repower phone - please wait If see on phone "Upload data to PC" - reconnect phone manually Disconnect RJ45 cable and connect data cable(APCBS10BBE or compatible) to phone Search modem ..." 4.change cable and use e210 usb cable Net Search modem ....ok locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 105 second, sw ver: 3.4.0018 Thanks |
12-28-2009, 14:18 | #303 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Samsung S8000 ----------------------------------- READ NEWS FOR DETAILS! Searching Samsung USB interface... not found Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Reading file as S8000... ok Model: S8000 Version: S8000XEIG2 Info: Patched for unlock Searching Samsung USB Flash interface... detected (COM20) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:04:23) Searching Samsung USB interface... detected (COM20) Checking mobile state... normal Model: S8000 SW: S8000XEIG2 IMEI: 3 Searching Samsung USB interface... detected (COM20) Checking mobile state... normal Model: S8000 SW: S8000XEIG2 IMEI: 3 Unlock as MSL3... Calculating codes... OK (time - 00:00:35) Freeze code... 26925352 NET lock code... 82040240 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 00000000 Multi lock... 00000000 How to enter codes: NET: #7465625*638*82040240# Sub: #7465625*782*00000000# SP: #7465625*77*00000000# CP: #7465625*27*00000000# SIM: #7465625*746*00000000# For check lock status: *#7465625# Reading file as S8000... ok Model: S8000 Version: S8000XEIG2 Searching Samsung USB Flash interface... detected (COM20) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:04:22) |
12-29-2009, 12:02 | #304 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | Searching phone at COM interface... ok Model: F480 SW: F480AEHJ1 Unlock as MSL2 Direct... OK (time - 00:00:03) |
12-30-2009, 07:31 | #306 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Cuba Age: 45
Member: 1020744 Status: Offline Thanks Meter: 428 | Samsung A877 Impression Preved! Count supported models - 144 Searching Samsung USB interface... not found Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Model: A877 SW: A877UCID3 Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: A877 SW: A877UCID3 Unlock as MSL2 Direct... OK (time - 00:00:02) |
12-30-2009, 08:50 | #307 (permalink) |
No Life Poster Join Date: May 2009 Location: destination SL3 brute force
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | s3655 unlock done READ NEWS FOR DETAILS! Last version on support: 2G tools v3.4.0021 Selected model: S3650 Selected com port: COM19 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM146 Model: GT-S3653 CountryCode: OPEN Factory SW: S3653DXII6 UniqueNumber: 79040000074066 MemoryPhone: K522H1HACC(S3650) Phone IMEI: 35803903160741 /5 Phone S/N: RD8SA80670 Phone Bluetooth ID: A0 07 98 54 40 09 Phone SW: S3653DXII6 Phone HW: MP 0.601 Phone CalData ver: 20091022 Detecting UART port..... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:18051797 [NET LOCK]:00000000 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 21 sec Elapsed time: 107 second, sw ver: 3.4.0021 ------------------------------------------------------------------------------- |
12-30-2009, 09:05 | #308 (permalink) |
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | 730scii1 unlock done READ NEWS FOR DETAILS! Reading file as 730SC... ok Model: 730SC Version: 730SCII1 Info: Camera and media patch v2 Reading file as 730SC... ok Model: 730SC Version: 730SCII1 Info: Camera and media patch v2 Checking ports... ok Searching Samsung USB Flash interface... detected (COM145) Searching Samsung USB interface... detected (COM145) Checking mobile state... flash Searching Samsung USB Flash interface... detected (COM145) Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 00:02:58) big thanks to blang.. flash to original fw from support then click unlock then flash again via patch... that all.. |
12-30-2009, 16:03 | #309 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Life Of Paradise
Member: 140477 Status: Offline Sonork: 100.1658502 Thanks Meter: 426 | M200 elected model: M200 Selected com port: COM12 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use manual parameters Phone in TAT MODE Phone IMEI: 00000000000000 Phone SW: M200XFHK1 Phone BT ADDR: 0012-47-000001 Phone SN: RW4QC13796 Deactivated MSL - TRUE Selected model: M200 Selected com port: COM12 Selected speed port: 921600 Write imei - ok Repair - ok Elapsed time: 12 second, sw ver: 3.4.0021 -------------------------------------------- |
12-31-2009, 09:34 | #310 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | Selected model: A137 Selected com port: COM11 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 30 Sending loader2... OK Phone IMEI -> 01166200720638 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> [NET LOCK]:07146440,07146440,07146440,07146440, [SIM LOCK]:00000000,00000000,00000000,00000000, [PHONE LOCK]:00000000,00000000,00000000,00000000, [SP LOCK]:00000000,00000000,00000000,00000000, Read Info - ok Elapsed time: 34 second, sw ver: 3.4.0001 ------------------------------------------------------------------------------- |
12-31-2009, 13:03 | #311 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | Last version on support: 2G tools v3.4.0021 Selected model: C5110 Selected com port: COM11 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader... OK Send loader - ok Phone IMEI -> 35282503006275 Phone SOFTWARE -> C5110BVIF Langpack-> Not found langpack ! Phone HW -> MP 0.600 Phone BT ADDR -> 0025-67-D6D2E0 [UNFREEZE]:58197570 [NET LOCK]:84490580 Read info - ok Elapsed time: 125 second, sw ver: 3.4.0001 ----------------------------------------------------------------------- |
12-31-2009, 14:04 | #313 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Searching Qualcomm USB interface... detected (COM96) Model: A877 IMEI: 357011xxxxxxxx SW: A877UCID3 Unlock as MSL2 Direct... OK (time - 00:00:00) Unlock Successfully done.Thanks to Z3X Team. |
12-31-2009, 18:44 | #314 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | Selected model: D900 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 5313 Sending loader2... OK Flash ID: 00EC22FC000100010034 Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 138 second, sw ver: 3.4.0021 ------------------------------------------------------------------------------- Selected model: C3050 Selected com port: COM3 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start repair IMEI...... SW: C3050BVIC7 IMEI: 35768003144823 MSL DEACTIVATED - TRUE Imei store to RAM Imei store to flash Repair IMEI - ok Elapsed time: 37 second, sw ver: 3.4.0021 |
01-01-2010, 08:47 | #315 (permalink) |
No Life Poster Join Date: Apr 2007 Location: United Harvard Paris Age: 33
Member: 492345 Status: Offline Sonork: 100.1594007 Thanks Meter: 161 | Finally Done! Samsung C6620 Unlocked Success! im using Old version. heres some screenshots: Full Logs: Code: Server news: [29.12.2009] Samsung Qualcomm Tool Update 6.3.01 S8000, S8003 and M8910 - repair IMEI [28.12.2009] DataCard Smart Tool Update 1.6 - ZTE MFxxx Added! [23.12.2009] Samsung Tool 3.4.0021 - Add new function -> Repair SWAP on S3650, and fix for all software write imei. [23.12.2009] Samsung Smart Phone Tool Update 2.1.00 i7500 direct unlock and IMEI repair [22.12.2009] Samsung Tool 3.4.0020 - Repair imei for msl16 phone S3650,S5650,M5650,I6220 and more. [19.12.2009] Data Cart Smart Tool 1.5 release! [07.12.2009] Samsung Qualcomm Tool Update 6.2.07 Softbank 740SC - unlock and media [04.12.2009] LG Qualcomm Language Editor 1.0.1 beta released! [03.12.2009] Shell 3.3 released! [14.11.2009] China Editor 3.7 Released! [11.11.2009] Shell 3.2 and Card 2.1 released! [16.10.2009] LG Qualcomm Tool 1.6.9 Released! KU990i, KU990iG, KU990iGO all version unlock! ----------------------------------- READ NEWS FOR DETAILS! Last version on support: 2G tools v3.4.0021 Selected model: C6620 Selected com port: COM5 Selected speed port: 921600 Power On phone Press on phone keyboard code *#0228# Press Back and press 2 key Select UART-CP and connect phone on cable Phone detected Bad ask Unlock - fail Elapsed time: 5 second, sw ver: 3.4.0015 ------------------------------------------------------------------------------- Selected model: C6620 Selected com port: COM5 Selected speed port: 921600 Power On phone Press on phone keyboard code *#0228# Press Back and press 2 key Select UART-CP and connect phone on cable Phone detected [SOFTWARE]: : i : Acc [Unique number]:Accumulated no Bad ask Unlock - fail Elapsed time: 5 second, sw ver: 3.4.0015 ------------------------------------------------------------------------------- Selected model: C6620 Selected com port: COM5 Selected speed port: 921600 Power On phone Press on phone keyboard code *#0228# Press Back and press 2 key Select UART-CP and connect phone on cable Phone detected [SOFTWARE]:C6620XXIC2 [Unique number]:60380000015360 [IMEI]:357167020429Euan [Serial number]:R1VS320963 Start Bruteforce Msl code detected: 526973 Unlock - fail Elapsed time: 9046 second, sw ver: 3.4.0015 ------------------------------------------------------------------------------- Selected model: C6620 Selected com port: COM5 Selected speed port: 921600 Power On phone Press on phone keyboard code *#0228# Press Back and press 2 key Select UART-CP and connect phone on cable Phone detected [SOFTWARE]:C6620XXIC2 [Unique number]:60380000015360 [IMEI]:35716702042Euan [Serial number]:R1VS320963 Start Bruteforce Msl code detected: 720906 Unlock - ok Elapsed time: 11788 second, sw ver: 3.4.0015 ------------------------------------------------------------------------------- Smart Sim Hopefully on Next Update it will make more FASTER on unlocking process and fix the bugs. it took 4 hours on unlocking Process... Whew! I still Love You Z3x Team! BR Euan from Free Country Happy New Year! |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
