01-02-2010, 04:09 | #318 (permalink) | |
No Life Poster Join Date: May 2009 Location: destination SL3 brute force
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | s5233s unlock done Quote:
br pbt3 | |
01-02-2010, 05:04 | #319 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Kanada
Member: 737720 Status: Offline Thanks Meter: 1,421 | successfully repair EEPROM D9001 Selected model: D900I Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3541 Sending loader2... OK Flash ID: 00EC2206000100000034 Restore EEP - ok Elapsed time: 81 second, sw ver: 3.4.0021 |
01-02-2010, 15:45 | #320 (permalink) |
Freak Poster Join Date: Sep 2009 Location: TUNISIA
Member: 1114818 Status: Offline Thanks Meter: 247 | e1120 Last version on support: 2G tools v3.4.0021 Selected model: E1120 Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35980402291194 Phone SW: E1120AGIC2 Phone BT ADDR: 0000-00-000000 Phone SN: RVYS407713 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok |
01-03-2010, 02:54 | #322 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Cuba Age: 45
Member: 1020744 Status: Offline Thanks Meter: 428 | Preved! Count supported models - 144 Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: A707 SW: A707UCGD2 Unlock as MSL2 Direct... OK (time - 00:00:03) |
01-03-2010, 05:59 | #323 (permalink) |
No Life Poster Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 | S5600v successfully unlock and unfreeze. Searching Qualcomm USB interface... detected (COM64) Model: S5600 SW: S5600BUIF2 Unlocking as New Security... Prepare Loader... OK Sending PreLoader... OK Sending Loader... OK Start Loader... OK Reading Security... Detected New Sec... Bypass... OK Calculating codes... OK (time - 00:00:45) Freeze code... 91491816 NET lock code... 70936137 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 12369874 Activa code... 12369874 |
01-03-2010, 10:37 | #324 (permalink) |
Member: 1114818 Status: Offline Thanks Meter: 247 | C 260 it's old modéle but i want to share it Last version on support: 2G tools v3.4.0021 Selected model: C260 Selected com port: COM10 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: C260AGGC1 IMEI: 35977301824127 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok |
01-03-2010, 10:52 | #325 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | Searching Qualcomm USB interface... detected (COM190) Model: S5600 IMEI: 35264103347255 SW: S5600AEIF1 Reading data from phone... OK Reading security... OK Calculating codes... OK (time - 00:00:35) Freeze code... 40930391 NET lock code... 51492961 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 12369874 Activa code... 12369874 How to enter codes: NET: #7465625*638*51492961# Sub: #7465625*782*00000000# SP: #7465625*77*00000000# CP: #7465625*27*00000000# SIM: #7465625*746*12369874# For check lock status: *#7465625# |
01-03-2010, 11:00 | #326 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1199290 Status: Offline Thanks Meter: 0 | Hi, we need urgently new or used Samsung Flash MD512256 in large qty, We also need flash 4470LLYBBO or 4470LLYBBE in bulk. please contact us without hesitation at any time for your stock list. If convinient, you can contact me at [email protected] or through my mobile : 86 15005169575 . Thanks Waittting for your good news. Best regards CARLA |
01-03-2010, 11:04 | #327 (permalink) |
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | FOMA L601i Unlock FOMA L601i Unlock............. Code: Mode: Normal Model: L601i Build version: Oct 19 200621:42:32Jul 04 200612:00:00L601i SW Version: L601i-AMSS6293.41-V10a-OCT-19-2006-DCM-JP IMEI: 35242701074086-7 BlueTooth Address: 0D:47:4D:7E:BB:01 Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. NV read... NV save:..\backup\L601i_352427010740867_03012010_154234.cnv Elapsed: 37 secs. Mode: Normal Model: L601i Build version: Oct 19 200621:42:32Jul 04 200612:00:00L601i SW Version: L601i-AMSS6293.41-V10a-OCT-19-2006-DCM-JP IMEI: 35242701074086-7 BlueTooth Address: 0D:47:4D:7E:BB:01 Flash Name: toshiba_ty9000ac10aobg Flash Info: 1980/0020/0200 Elapsed: 0 secs. Firmware signature in base: 209 Ver: Oct 19 200621:42:32Jul 04 200612:00:00L601i Signature detected! Start send loader... Loader startup OK... Start read nand... Skip block... Patch... Read nand done... Start erase nand... Erase nand done... Start write nand... Nand write done... Unlock done! Phone rebooted! Elapsed: 8 secs. Last edited by amar181; 01-03-2010 at 11:10. |
The Following User Says Thank You to amar181 For This Useful Post: |
01-03-2010, 11:08 | #328 (permalink) |
No Life Poster Join Date: Apr 2009 Age: 41
Member: 1015389 Status: Offline Sonork: 19830303 Thanks Meter: 526 | 2 S5230 unlock by z3x lock to talk mobile Selected model: S5230 Selected com port: COM3 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM10 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 49 second, sw ver: 3.4.0001 ------------------------------------------------------------------------------- Selected model: S5230 Selected com port: COM3 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM51 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 56 second, sw ver: 3.4.0001 |
01-03-2010, 11:08 | #329 (permalink) |
Member: 1199297 Status: Offline Thanks Meter: 0 | please i need the unlock code for Huawei e1550 IMEI : 357123033418392 Firmware : 11.608.12.00.135 Dashboard version : UTPS11.002.03.24.135_MAC11.301.09.02.135 Serial NR. : B54CAA1982210796 |
01-03-2010, 12:25 | #330 (permalink) |
No Life Poster Join Date: Mar 2006 Location: morroco
Member: 245026 Status: Offline Thanks Meter: 382 | Selected model: E1360B Selected com port: COM17 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35************ Phone SW: E1360BBGIC7 Phone BT ADDR: 0025-66-53F4B4 Phone SN: RP4S519188 Deactivated MSL - TRUE [FREZEE]: 44337310 [NET Lock]: 41613290 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 9 second, sw ver: 3.4.0021 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
