02-28-2011, 12:39 | #3346 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1049869 Status: Offline Thanks Meter: 25 | here is log Model: GT-I5800 CountryCode: TRG Factory SW: I5800XWJH2_TRGJG2 UniqueNumber: 86240000241594 MemoryPhone: KAC007021B(I5801) PDA/CSC version: I5800XWJH2/I5800TRGJG2 Phone version: I5800XXJG3 Phone HW: MP 1.000 IMEI: / Phone S/N: RT1ZB09226 Build: Q6270B-KPRBL-1.5.55062ST Reading Security... OK Bypass MSL... OK Unlocking ... OK Done with Samsung 3G tool ver 9.4 |
02-28-2011, 16:16 | #3347 (permalink) |
Junior Member Join Date: Oct 2007
Member: 616375 Status: Offline Thanks Meter: 0 | LEASE HELP: Selected model: S5230 Selected com port: COM23 Selected speed port: 921600 Phone must be ON Search modem ... Timeout - modem not found Elapsed time: 66 second, sw ver: 3.4.0066 |
02-28-2011, 18:08 | #3348 (permalink) |
Freak Poster Join Date: Dec 2009 Location: beside gsm world
Member: 1178779 Status: Offline Thanks Meter: 18 | U900 direct unlock done...... Model: SGH-U900 CountryCode: ئؤإ°½؛ Factory SW: U900JPHD3 UniqueNumber: 60030000141067 MemoryPhone: K5R2G1GACM(U900) IMEI: 35244202553371/0 Phone S/N: R5XQ510868 Build: M6281A-KLRZ-4.0.9530 Reading SysInfo... OK Calculating... OK Searching Samsung USB interface... detected (COM55) Model: SGH-U900 SW: U900JPHE1 IMEI: 35244202553371/0 Bypass MSL... OK Unlocking... OK (time - 00:00:07) Done with Samsung 3G tool ver 9.1 |
03-01-2011, 05:23 | #3349 (permalink) |
Banned Join Date: Sep 2003 Location: Cambodia
Member: 39069 Status: Offline Sonork: 100.1606677 Thanks Meter: 190 | Model: SGH-A551 CountryCode: XSA Factory SW: A551DVHF2 UniqueNumber: 74160000931275 MemoryPhone: K5D1G13DCM(A551) IMEI: 35593602057893/2 Phone S/N: R3VS227258 Build: M6260A-KYRZ-2.1.300609T Reading SysInfo... OK Calculating... OK Unlocking... OK (time - 00:00:03) Done with Samsung 3G tool ver 9.4 |
03-01-2011, 06:47 | #3350 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | s3500i hang on logo done with fleshing Selected model: S3500I Selected com port: COM7 Selected speed port: 460800 Decode *.s3 file - please wait segments 9 segment 1 20000000 100 byte segment 2 20300000 52113996 byte segment 3 2001E000 172 byte segment 4 20016000 5248 byte segment 5 20078000 1129752 byte segment 6 2000C000 21572 byte segment 7 20058000 56 byte segment 8 20058138 13724 byte segment 9 2003803C 36528 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 89000000B088 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 121 Format FFS - wait... OK Send content - wait... OK Elapsed time: 2687 second, sw ver: 3.5.0005 ------------------------------------------------------------------------------- |
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post: |
03-01-2011, 07:59 | #3351 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM5 [VCP3] selected module v3.74 Device: Spice-S300 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:0D54:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: KONKA23_EC006_PCB01_GSM_MT6223_S00.KAA006_PUNJABI_ 1_01_522.BIN project-id: KAA006_PUNJABI_1.01.522, 00000000 code offset: 00000000 ffs offset/size [01]: 00340000/000C0000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00340000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2AEA0000000000 Backup required data Done ====> Patch required data ... ........... lock area found ........... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................ error: area 1 can not apply patch Special operation Done ====> Write ... flash: 01227E221A2201:2AEA0000000000 flash: 01227E221A2201:2AEA0000000000 Write: lock-area-1 flash: 01227E221A2201:2AEA0000000000 flash: 01227E221A2201:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 47 sec Remove/Install battery now ! |
03-01-2011, 08:01 | #3352 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM5 [VCP3] selected module v3.74 Device: Spice-S300 Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 new imei: 354304026175701 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:0D54:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2AEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: KONKA23_EC006_PCB01_GSM_MT6223_S00.KAA006_PUNJABI_ 1_01_522.BIN project-id: KAA006_PUNJABI_1.01.522, 00000000 code offset: 00000000 ffs offset/size [01]: 00340000/000C0000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00340000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S300_KONKA23_EC006_PCB01_GSM_MT6223_S00.KAA006_PUN JABI_1_01_522__ffs... file saved: C:\InfinityBox\MModule\Spice-S300_KONKA23_EC006_PCB01_GSM_MT6223_S00.KAA006_PUN JABI_1_01_522__ffs_20110301-123056.B0E.bin flash: 01227E221A2201:2AEA0000000000 Backup required data Done ====> Patch required data ... 4 step(s) required Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E221A2201:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 3 sec Remove/Install battery now ! |
03-01-2011, 09:31 | #3353 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Amoude-syria Age: 49
Member: 98928 Status: Offline Thanks Meter: 464 | M_c5212i imei repair ok Code: Selected model: C5212I_m Selected com port: COM7 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Repair IMEI block Repair IMEI block Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 143 second, sw ver: 3.5.0006 |
03-01-2011, 11:31 | #3355 (permalink) |
No Life Poster Join Date: Feb 2010 Location: IN YOUR HEART :)
Member: 1243555 Status: Offline Thanks Meter: 661 | Selected model: C3050 Selected com port: COM5 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: C3050RFII1 IMEI: 35958603819079 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 23 second, sw ver: 3.5.0006 thx Z3X tem |
03-01-2011, 12:37 | #3356 (permalink) |
Banned Join Date: Mar 2004
Member: 58357 Status: Offline Thanks Meter: 27 | Selected model: S3650 Selected com port: COM2 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM34 Model: GT-S3650 CountryCode: FTM Factory SW: S3650BVII6 UniqueNumber: 74280001195479 MemoryPhone: K522H1HACC(S3650) Phone IMEI: 35856803410141 /4 Phone S/N: R5XSB50300 Phone Bluetooth ID: C8 7E 75 5E 67 BF Phone SW: S3650BVII6 Phone HW: MP 0.602 Phone CalData ver: 20091115 Searching server... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:57481351 [NET LOCK]:92929730 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 67 sec Elapsed time: 81 second, sw ver: 3.5.0005 |
03-01-2011, 13:59 | #3357 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 552794 Status: Offline Thanks Meter: 13 | Selected model: T459 Selected com port: COM11 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3721 Sending loader2... OK Flash ID: 00EC2206000100000034 timeout Send NOR - fail Elapsed time: 113 second, sw ver: 3.5.0007 ------------------------------------------------------------------------------- t459 eeprom write fail |
03-01-2011, 14:30 | #3359 (permalink) |
Member: 58357 Status: Offline Thanks Meter: 27 | Selected model: E1150 Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 36 second, sw ver: 3.5.0005 ------------------------------------------------------------------------------- Selected model: J700 Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use manual parameters Phone in TAT MODE Phone IMEI: 35563902056731 Phone SW: J700BVHB3 Phone BT ADDR: 0021-D1-10AA8A Phone SN: RPJQ670390 Deactivated MSL - TRUE [FREZEE]: 88000320 [NET Lock]: 56801820 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 16 second, sw ver: 3.5.0005 |
03-01-2011, 15:58 | #3360 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | Count supported models - 217 Searching Samsung USB interface... detected (COM30) Model: GT-S8500 SW: S8500XXJF4 IMEI: 35********* Done with Samsung 3G tool ver 8.9 Searching Samsung USB Modem... detected (COM30) Reading Phone Info... OK Model: GT-S8500 Factory SW: S8500BUJF1_ATLJF1 CountryCode: ATL UniqueNumber: 86250000068862 MemoryPhone: KAC007021M(S8500) SW: S8500XXJF4 IMEI: 35462704874239/1 Reading SysInfo... OK Searching server... OK Calculating codes... OK (time - 00:00:50) Freeze code: 52037520 NET lock: #7465625*638*71726318# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# SIM lock: #7465625*746*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.9 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
