01-08-2010, 05:08 | #346 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Cuba Age: 45
Member: 1020744 Status: Offline Thanks Meter: 428 | --------------------------- 01/07/2010 03:09:43 PM ----------------------------- Selected model: M310 Selected com port: COM3 Selected speed port: 921600 Phone must be ON! Please, connect phone Entering TestMode... OK SW: 215LVBHG2 Langpack: Not found langpack ! IMEI: 35546802443625 S/N: RVPS318858 HW-> MP 0.500 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 001 Flash Device ID: 227e3d00 Flash size: 67108864 Bytes Flash sectors: 518 sectors Bluetooth ID: 002491-279264 Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*41135837# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 13 second, sw ver: 3.4.0021 ------------------------------------------------------------------------------- |
01-08-2010, 05:09 | #347 (permalink) |
Member: 1020744 Status: Offline Thanks Meter: 428 | Samsung A237 Unlocked by z3x Selected model: A237 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3721 Sending loader2... OK Flash ID: 0001227E000000C0E1D0 Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 127 second, sw ver: 3.4.0021 ------------------------------------------------------------------------------- |
01-08-2010, 10:36 | #348 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Neverland
Member: 1099972 Status: Offline Thanks Meter: 208 | 821sc Cable used:E210 Procedure: 1.Connect E210 cable usb/rj 45 2.Check 2 in 1 cable & Qualcomm mode 3.Search phone 4.Press unlock After unlock success.. Next step (Flashing) 1. download multimidia & network unlock patch and load 2. removed rj45( use usb only ) 3. hold * + power on 4. install all phone driver if needed 5. ticked update firmware note: wait until phone rebot as normal Here are some screenshots: |
01-08-2010, 17:18 | #350 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Samsung S3650 Corby and J700v unlocked! Selected model: S3650 Selected com port: COM9 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM21 Model: GT-S3650 CountryCode: VID Factory SW: S3650APII6 UniqueNumber: 75900000090858 MemoryPhone: K522H1HACC(S3650) Phone IMEI: 3548XXXXXXXXX /0 Phone S/N: R1XSA37166 Phone Bluetooth ID: 60 D0 A9 EF 9E 30 Phone SW: S3650APII6 Phone HW: MP 0.600 Phone CalData ver: 20091013 Detecting UART port..... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:53727461 [NET LOCK]:48496268 [Subset LOCK]:41726240 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 35 sec Elapsed time: 70 second, sw ver: 3.4.0023 Selected model: J700 Selected com port: COM9 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use manual parameters Phone in TAT MODE Phone IMEI: 3599XXXXXXXXXX Phone SW: J700AMHA3_H Phone BT ADDR: 001E-E2-B820FD Phone SN: R2YQ380502 Deactivated MSL - TRUE [FREZEE]: 48146920 [NET Lock]: 68557720 [Subset Lock]: 68557720 [SP Lock]: 68557720 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 36 second, sw ver: 3.4.0023 |
01-09-2010, 03:01 | #351 (permalink) |
Freak Poster Join Date: May 2008
Member: 772286 Status: Offline Thanks Meter: 25 | S8000 JET Preved! Count supported models - 144 Searching Samsung USB interface... not found Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Reading file as S8000... ok Model: S8000 Version: S8000XEIG2 Info: Patched for unlock Searching Samsung USB interface... not found USB interface required Searching Samsung USB interface... not found USB interface required Searching Samsung USB Flash interface... not found Set phone in flash mode Searching Samsung USB Flash interface... detected (COM35) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:05:08) Searching Samsung USB interface... detected (COM35) Checking mobile state... normal Model: S8000 SW: S8000XEIG2 IMEI: 356174030****** Unlock as MSL3... Calculating codes... OK (time - 00:00:58) Freeze code... 18470509 NET lock code... 79086047 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 00000000 Multi lock... 00000000 How to enter codes: NET: #7465625*638*79086047# Sub: #7465625*782*00000000# SP: #7465625*77*00000000# CP: #7465625*27*00000000# SIM: #7465625*746*00000000# For check lock status: *#7465625# Reading file as S8000... ok Model: S8000 Version: S8000ITVIF2 Searching Samsung USB Flash interface... detected (COM35) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:05:08) |
01-09-2010, 08:15 | #352 (permalink) |
No Life Poster Join Date: May 2009 Location: destination SL3 brute force
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | t919 unlock done Checking ports... ok Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T919 SW: T919UVHL3 Unlock as MSL2 Direct... OK (time - 00:00:02) wow sec 2 only pbt3 |
01-09-2010, 09:14 | #353 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | S5230 unlock done Selected model: S5230 Selected com port: COM77 Selected speed port: 921600 Connect phone(RJ 45 cable) and power on - press 2-3 second Detecting UART port..... OK Repower phone - please wait If see on phone "Upload data to PC" - reconnect phone manually Phone must be ON Search modem ... OK Search modem on:COM10 Model: GT-S5230 CountryCode: CIT Factory SW: S5230XIIG3 UniqueNumber: 55440000175117 MemoryPhone: K522H1HACA(S5230) Phone IMEI: 35767603239231 /4 Phone S/N: RQPS823296 Phone Bluetooth ID: 00 26 5F A0 21 25 Phone SW: S5230XIIG3 Phone HW: MP 0.610 Phone CalData ver: 20090901 Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:80524748 [NET LOCK]:00000000 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 81 sec Elapsed time: 205 second, sw ver: 3.4.0018 BR, themobileshop |
01-09-2010, 13:48 | #354 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | 709SC unlock done! Quote:
thanks to Z3X team for the good support and for good product !! ; ) | |
01-10-2010, 08:41 | #355 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bali Island - Indonesia
Member: 589534 Status: Offline Thanks Meter: 251 | C5220 unlock done.. READ NEWS FOR DETAILS! Checking ports... ok Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: C5220 SW: C5220DVIB Unlock as MSL2 Direct... OK (time - 00:00:03) |
01-11-2010, 11:09 | #356 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Samsung B320 Corby and E1210M unlocked! Last version on support: 2G tools v3.4.0023 Selected model: B320 Selected com port: COM3 Selected speed port: 921600 Phone must be ON! Please, connect phone Entering TestMode... OK SW: B320AOHH2 Langpack: O2 IMEI: 35462602xxxxxx S/N: R8XQ842921 HW-> MP 0.200 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 001 Flash Device ID: 227e4200 Flash size: 33554432 Bytes Flash sectors: 262 sectors Bluetooth ID: 0021d2-5b91b6 Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*71277777# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 9 second, sw ver: 3.4.0023 Last version on support: 2G tools v3.4.0023 Selected model: E1210M Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35301403xxxxxx Phone SW: E1210MXFIG3 Phone BT ADDR: 0000-00-000000 Phone SN: RP5SC18435 Deactivated MSL - TRUE [FREZEE]: 99370420 [NET Lock]: 35459580 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 13 second, sw ver: 3.4.0023 P.S. B320 is not CORBY Sorry |
01-11-2010, 11:42 | #357 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 173741 Status: Offline Thanks Meter: 986 | c3050 Last version on support: 2G tools v3.4.0023 Selected model: C3050 Selected com port: COM6 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: C3050BVIH2 Langpack: Orange, Switzerland IMEI: 35855303873756 S/N: RUPSB36391 HW-> MP 0.303 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 089 Flash Device ID: 887e0000 Flash size: 67108864 Bytes Flash sectors: 256 sectors Bluetooth ID: c87e75-bd7379 Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE This is sha-1 code - wait for decrypt Decrypted time: 203 sec [PCK]:#0141*00000000# [NCK]:#0111*80011670# [SCK]:#0121*00000000# [SPCK]:#0133*00000000# [MCK]:#0199*12606438# Read info - ok Elapsed time: 222 second, sw ver: 3.4.0022 |
01-11-2010, 12:47 | #358 (permalink) |
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Samsung S5230 unlock Read Codes: Last version on support: 2G tools v3.4.0024 Selected model: S5230 Selected com port: COM3 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM46 Model: GT-S5230 CountryCode: FTM Factory SW: S5230BVIG2 UniqueNumber: 70670000700738 MemoryPhone: K522H1HACA(S5230) Phone IMEI: 35675803xxxxxx /x Phone S/N: R8WSA94511 Phone Bluetooth ID: A0 07 98 7B 8E CF Phone SW: S5230BVIG2 Phone HW: MP 0.610 Phone CalData ver: 20091027 Detecting UART port..... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:97208527 [NET LOCK]:09263683 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 48 sec Elapsed time: 76 second, sw ver: 3.4.0023 Direct Unlock: Selected model: S5230 Selected com port: COM3 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM46 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 43 second, sw ver: 3.4.0023 |
01-11-2010, 17:12 | #359 (permalink) |
No Life Poster Join Date: Sep 2005 Location: frp off Age: 41
Member: 183958 Status: Offline Sonork: 719191000d Thanks Meter: 523 | corby txt b3210 unlock done Selected model: B3210 Selected com port: COM62 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: B3210BVIJ1 Langpack: Orange, Switzerland IMEI: 35779703187111 S/N: RVMSB28876 HW-> MP 0.600 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 089 Flash Device ID: 88b00000 Flash size: 134217728 Bytes Flash sectors: 512 sectors Bluetooth ID: c87e75-3b547c Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE This is sha-1 code - wait for decrypt Decrypted time: 229 sec [PCK]:#0141*00000000# [NCK]:#0111*81403981# [SCK]:#0121*00000000# [SPCK]:#0133*00000000# [MCK]:#0199*47907580# Read info - ok Elapsed time: 244 second, sw ver: 3.4.0022 |
01-12-2010, 06:39 | #360 (permalink) | |
Junior Member Join Date: Dec 2009 Location: earth
Member: 1197342 Status: Offline Sonork: [email protected] Thanks Meter: 9 | E690 samsung by z3x Quote: Selected model: E690 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 5313 Sending loader2... OK Flash ID: 00EC2206000100010014 Phone IMEI -> 00000000000000 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> Read Info - ok Elapsed time: 74 second, sw ver: 3.4.0023 ------------------------------------------------------------------------------- | |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
