Old 12-20-2008, 18:30   #31 (permalink)
Member: 182669
Thanks Meter: 80
U600 Unlock -ok
Count supported models - 372
Phone must be ON!
CONNECT PHONE
TestModeOn - ok
SoftWare-> U600XXGG3
IMEI-> 35880301745712
S/N-> R8WPA53508
HW-> MP 2.101
Password-> 03030000
Flash Prod ID-> 0ec
Flash Device ID-> 0x22fd0000
Flash size-> 33554432 Bytes
Flash sectors-> 519 sectors
Bluetooth ID-> 001df6-a49117
MSL Detected
OTP is ok
Default cal data present
Good job
Phone must be ON!
CONNECT PHONE
TestModeOn - ok
MSL DEACTIVATED - TRUE
UNLOCK ALL COMPLITED
Good job
Old 12-25-2008, 15:19   #32 (permalink)
Member: 182669
Thanks Meter: 80
J700 -Unlock + flash with new ver 2.28 -OK
Selected model J700
Connect phone and power on
Phone Detected
Send loader1
Loader1 - ok
ARM version 3721
Loader2 - ok
Detected flash KAP29SN00M
Phone IMEI -> 35780602050524
Phone SOFTWARE ->
Phone HW ->
Phone BT ADDR ->
[NET LOCK]:76299510
[SIM LOCK]:00000000
[PHONE LOCK]:00000000
Good job
Phone Detected
Send loader1
Loader1 - ok
ARM version 3721
Loader2 - ok
NAND format - ок
Mount NAND - ok
Flash TFS Start
Create DIR - ok
Good job
Old 01-03-2009, 18:58   #33 (permalink)
Member: 182669
Thanks Meter: 80
Z240-success unlock
Searching Samsung USB interface... detected (COM14)
Checking mobile state... normal
Model: SGH-Z240
IMEI: 353826010735877
SW: Z240BGGC1_GC2
Reading NVM... ok (D:\Z3X\Qualcomm\NVM\z240_353826010735877_3.1.2009 _
13-25-33.qnvmbkp)
Model: SGH-Z240
SW: Z240BGGC1_GC2
Checking mobile state... flash
Unlock as MSL FLASH... ok (NSK - 12345678)!
Old 01-08-2009, 19:37   #34 (permalink)
Member: 152097
Thanks Meter: 3
tried to read info for A137 from AT&T and phone just keeps Blinking at the Boot Up 4D040002. How do i fix this problem...
Old 01-08-2009, 20:01   #35 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 171,529
MAN DON't SMAP IN FORUM. DO YOU READ NAME OF THREAD????
You got answear in this thread:
Samsung Tool 2.28 Update. 4 new models Added
No need make double message, cos i will del!!
Old 01-08-2009, 20:19   #36 (permalink)
Member: 152097
Thanks Meter: 3
Nobody, snap if you would read u would see the person had 2 phones to unlock and the first one got the blinking after i tried to unlock and then i tried to read the information on the second one and same thing happen because i want to read the flash. So just be Cool because i dealing with people phones....
I do like the Quick responce and i will try the solution...
THANKS
Old 02-07-2009, 00:30   #37 (permalink)
Member: 70174
Thanks Meter: 7
I tried F480 IMEI repair....without success.
I tried Samsung mode 2in1 cable and usb cable, Qualcomm mode with usb cable and 2in1 cable - all the time - calc login code error. When the phone came to me it has XXDA software. I tried 5 others, even F480F - still the same. I think I've got F480 with new security. Please update tool.
Old 02-07-2009, 01:04   #38 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Where srceen shots?
where log of program?
Where info about phone version??
How we can make something if you not give any info.
Old 02-07-2009, 15:02   #39 (permalink)
Member: 70174
Thanks Meter: 7
Sorry...
Searching Qualcomm USB interface... detected (COM26)
Model: F480
IMEI: 35187---------
SW: F480XXHDA
Repairing as MSL2 Direct... error! (calc login code error)
Searching Samsung USB interface... detected (COM24)
Model: SGH-F480
SW: F480XXHD9
Model: F480
IMEI: 35187-------
SW: F480XEHJ1
Model: F480
IMEI: 35187-----
SW: F480XEHE1
Every time it goes to 81% and then stops. I tried couple of frimwares, the same problem occurs.
Old 02-12-2009, 15:56   #40 (permalink)
..::Mr999::..'s Avatar
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,018
Searching Samsung USB interface... detected (COM23)
Model: SGH-U900
IMEI: 352442027342706
SW: U900BVHD3
Repairing as MSL2 Direct... error! (IMEI length must be 15)
Repairing as MSL2 Direct... ok (IMEI - 356261015645136)!
Unlock as MSL2 Direct... ok
Old 02-20-2009, 20:35   #41 (permalink)
rorm's Avatar
Member: 593158
Thanks Meter: 6
please for help
how to direct change imei, samsung smart phone i550, i520, with z3x samsung smart phone tool.
Old 02-21-2009, 12:54   #42 (permalink)
laduka's Avatar
Member: 194939
Sonork: 100.1613858
Thanks Meter: 585
today i have sucsessfuly unlocked L770 infineon platform with z3x thancks z3x team
The Following User Says Thank You to laduka For This Useful Post:
Old 02-24-2009, 11:56   #43 (permalink)
fadhel's Avatar
Member: 39196
Thanks Meter: 117
For me pc can't detect phone L770.
thanks.
Old 02-24-2009, 13:22   #44 (permalink)
Member: 540932
Thanks Meter: 36
.1.3.3
supported models: 53
andrew_tm 2008(c)
Mode: Normal
Model: KU990
Build version: Jan 16 200816:47:39Sep 27 200717:00:00KU990
SW Version: KU990-MSM6280-V10a-SEP-27-2007-XX
IMEI: 35820301877181-4
BlueTooth Address: 00:1E:75:E3:37:3E
Elapsed: 0 secs.
unlock done but not for this versionv
Mode: Normal
Model: KU990
Build version: Dec 27 200718:03:25Oct 05 200717:00:00KU990
SW Version: KU990-MSM6280-V10c-DEC-27-2007-XX
IMEI: 35363802386783-1
BlueTooth Address: 00:1F:6B:B8:17:08
Old 02-24-2009, 17:00   #45 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 328
Originally Posted by umerfarooq View Post
.1.3.3
new updated Version .Wel ph working or not ??after unlock that is what needed to check
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1546 01-20-2018 12:33
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 17:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 17:29
Page generated in 5.22546 seconds with 9 queries
