08-25-2010, 09:11 | #1381 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82236 Status: Offline Thanks Meter: 583 | Selected model: B5310 Selected com port: COM23 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM20 Phone OLD IMEI: 359688010xxxxx /6 Phone SW: B5310DDIK5/B5310ODDIK5 Search modem ... OK Phone detected... OK Send loader... OK Wait for boot ... Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM20 MSL DEACTIVATED - TRUE Write imei - ok Phone NEW IMEI: 3596880104xxxxx /6 Search modem ... OK Phone detected... OK Send loader... OK Elapsed time: 94 second, sw ver: 3.4.0063 |
The Following User Says Thank You to telecomindia For This Useful Post: |
08-25-2010, 11:40 | #1382 (permalink) |
Registered User Join Date: Dec 2009 Location: p A k I s T a N
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | SoftBank 740SC Unlocking Done Code: Reading file... OK Model: 740SC Version: 740SCJD1 Info: Unlock and media patch Searching Samsung USB Flash interface... detected (COM15) Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 00:03:36) |
08-25-2010, 11:41 | #1383 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | SoftBank 740SC Unlocking Done Code: Reading file... OK Model: 740SC Version: 740SCJD1 Info: Unlock and media patch Searching Samsung USB Flash interface... detected (COM15) Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 00:03:35) |
08-25-2010, 11:51 | #1384 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | U600 U600 succesfully read codes and direct unlock. Thank you Z3X Team. BR. Selected model: U600 Selected com port: COM29 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: U600GXXHH4 Langpack: Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom IMEI: 355524024xxxxxx S/N: RUXQA32733 HW-> MP 0.200 Phone password: 00310 Sum Flash: 1 Flash Prod ID: 0ec Flash Device ID: 22fd0000 Flash size: 33554432 Bytes Flash sectors: 519 sectors Bluetooth ID: 00233a-dd57e3 Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*00000000# for deactivate this lock [SIMLOCK]: Use #0141*100310# for deactivate this lock Read info - ok Elapsed time: 18 second, sw ver: 3.4.0064 ------------------------------------------------------------------------------- Selected model: U600 Selected com port: COM29 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: U600GXXHH4 IMEI: 355524024xxxxxx MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 15 second, sw ver: 3.4.0064 ------------------------------------------------------------------------------- |
08-26-2010, 07:28 | #1385 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | Samsung GT_S5230 unlocking done Code: Selected model: S5230 Selected com port: COM5 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM10 Phone IMEI: 35210404057477 /8 Phone S/N: RQLZ208530 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 48 second, sw ver: 3.4.0064 |
08-26-2010, 09:03 | #1386 (permalink) |
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | E900 E900 succesfully read codes and direct unlock. Thank you Z3X Team. BR. Selected model: E900 Selected com port: COM29 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: 900AFFF2 Langpack: Not found langpack ! IMEI: 356030017xxxxxx S/N: R5YP756289 HW-> MP 1.110 Phone password: 4665 Sum Flash: 1 Flash Prod ID: 0ec Flash Device ID: 22fd0000 Flash size: 33554432 Bytes Flash sectors: 519 sectors Bluetooth ID: 001c43-6d2e18 Status OTP: OTP not present MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*52975131# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 29 second, sw ver: 3.4.0064 ------------------------------------------------------------------------------- Selected model: E900 Selected com port: COM29 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: E900AFFF2 IMEI: 356030017xxxxxx MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 38 second, sw ver: 3.4.0064 |
08-26-2010, 11:21 | #1387 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Denmark Age: 41
Member: 268415 Status: Offline Thanks Meter: 57 | GT S3370 unlock. Model: GT-S3370 CountryCode: VDR Factory SW: S3370AMJF1_OAMJF1 UniqueNumber: 86120000167296 MemoryPhone: K522H1HACC(S3370)S IMEI: 352673043****/1 Phone S/N: RVGZ718136 Build: Q6270B-KPVZL-1.5.55011ST Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:51) Freeze code: 68486297 NET lock: #7465625*638*46841815# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# For check lock status: *#7465625# |
08-26-2010, 12:00 | #1388 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | Samsung GT_B5310 unlocking done Code: Selected model: B5310 Selected com port: COM5 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM24 Phone OLD IMEI: 35783603115009 /3 Phone SW: B5310XFIK5/B5310OXFIK5 Search modem ... OK Phone detected... OK Send loader... OK Wait for boot ... Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM24 MSL DEACTIVATED - TRUE Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Search modem ... OK Phone detected... OK Send loader... OK Elapsed time: 89 second, sw ver: 3.4.0064 |
08-26-2010, 12:01 | #1389 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | Samsung D900i IMEI repair ok Code: Selected model: D900I Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 4541 Sending loader2... OK Flash ID: 00EC2206000100000034 Repair IMEI block Repair IMEI block Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 123 second, sw ver: 3.4.0064 |
08-26-2010, 12:02 | #1390 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | Samsung E1120 unlocking done Code: Selected model: E1120 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35601303669109 Phone SW: E1120BVID1 Phone BT ADDR: 0000-00-000000 Phone SN: RT5S989092 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 14 second, sw ver: 3.4.0064 |
08-26-2010, 12:31 | #1391 (permalink) |
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | Zv10 ZV10 succesfully unlocked using Z500 usb-rj45 cable. Thank you Z3X Team. BR. Count supported models - 201 Searching Samsung USB interface... detected (COM63) Model: SGH-ZV10 SW: ZV10BUEJ7 IMEI: 35715800xxxxxx/6 Unlocking... OK |
08-26-2010, 12:58 | #1392 (permalink) |
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | C3510 C3510 succesfully read codes and direct unlock. Thank you Z3X Team. BR. Selected model: C3510 Selected com port: COM29 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Phone IMEI -> 353433040xxxxxx Phone SW -> C3510CWAXEC Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> [NET LOCK]:54755770, [SIM LOCK]:00000000, [PHONE LOCK]:00000000, [SP LOCK]:00000000, Read Info - ok Elapsed time 81 second, sw ver: 3.4.0064 ------------------------------------------------------------------------------- Selected model: C3510 Selected com port: COM29 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 131 second, sw ver: 3.4.0064 |
08-26-2010, 14:20 | #1393 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Model: SGH-L760 CountryCode: AMN Factory SW: L760BNHA2 UniqueNumber: 02680000032407 MemoryPhone: K5D1G13DCM IMEI: 35565801926753/9 Phone S/N: R5YQ286846 Build: M6260A-KYRZ-2.1.300605T Reading SysInfo... OK Calculating... OK Searching Samsung USB interface... detected (COM7) Model: SGH-L760 SW: L760BNHA2 IMEI: 35565801926753/9 Bypass MSL... OK Unlocking... OK (time - 00:00:10) |
08-26-2010, 14:25 | #1394 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Model: SGH-L760 CountryCode: AMN Factory SW: L760BNHA2 UniqueNumber: 02680000032407 MemoryPhone: K5D1G13DCM IMEI: 35565801926753/9 Phone S/N: R5YQ286846 Build: M6260A-KYRZ-2.1.300605T Reading SysInfo... OK Calculating... OK Calculating codes... OK (time - 00:00:58) Freeze code: 12345678 NET lock: #7465625*638*80480728# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# |
08-26-2010, 14:46 | #1395 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1338457 Status: Offline Thanks Meter: 31 | u800 unlocked Count supported models - 188 ----------------------------- Model: SGH-U800 CountryCode: DTM Factory SW: U800RFHF2_HG1 UniqueNumber: 60360000037494 MemoryPhone: TY9D00A800BT(U800) IMEI: 35515601315253/4 Phone S/N: R1XQ808322 Build: M6260A-KYRZ-2.5.1032 Reading SysInfo... OK Calculating... OK Calculating codes... OK (time - 00:02:08) Freeze code: 90702749 NET lock: #7465625*638*35807414# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
