08-26-2015, 03:14 | #14221 (permalink) |
Registered User Join Date: Mar 2006 Location: Pilipinas
Member: 249276 Status: Offline Thanks Meter: 209 | Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Done with Samsung Tool PRO v.22.3 Br, Mr G |
08-26-2015, 07:29 | #14223 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Bahrain™ Age: 39
Member: 622142 Status: Offline Sonork: 100.1680775 Thanks Meter: 40 | NO SIGNAL / IMEI NULL / BASEBAND FIX Samsung Galaxy s3 shv-e210k Selected model: E210K Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: SHV-E210K Android version: 4.3 Product code: Unknown Phone version: Unknown PDA version: E210KKKUGNA3 CSC version: E210KKTTGNA3 IMEI: Unknown Phone S/N: Unknown Checking Super user right... true Reseting EFS... OK Rebooting phone... OK Waiting ADB device... OK Reading phone info... Model: SHV-E210K Android version: 4.3 Product code: Unknown Phone version: E210KKKNA3 PDA version: E210KKKUGNA3 CSC version: E210KKTTGNA3 IMEI: Unknown Phone S/N: Unknown Checking Super user right... true Disabling Factory mode... OK Reading nv data... OK Checking magic... OK Security damaged, restoring... OK Writing nv data... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Repair done Done with Samsung Tool v.18.9 |
08-26-2015, 07:34 | #14224 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | [ 8/26/2015 11:41:00 AM ] Operation: Unlock [ 8/26/2015 11:41:00 AM ] Selected model: SM-E700F [ 8/26/2015 11:41:00 AM ] Software version: 22.3 [ 8/26/2015 11:41:00 AM ] [ 8/26/2015 11:41:00 AM ] Waiting ADB device... OK [ 8/26/2015 11:41:00 AM ] Reading phone info... [ 8/26/2015 11:41:00 AM ] Model: SM-E700F [ 8/26/2015 11:41:00 AM ] Android version: 4.4.4 [ 8/26/2015 11:41:00 AM ] Product code: SM-E700FZWDKSA [ 8/26/2015 11:41:00 AM ] Phone version: E700FXXU1AOAA [ 8/26/2015 11:41:00 AM ] PDA version: E700FXXU1AOAA [ 8/26/2015 11:41:00 AM ] CSC version: E700FOJV1AOAA [ 8/26/2015 11:41:00 AM ] CSC country code: KSA [ 8/26/2015 11:41:00 AM ] CSC sales code: KSA [ 8/26/2015 11:41:00 AM ] HW version: MP 0.300 [ 8/26/2015 11:41:00 AM ] Phone S/N: R58G12HMJ2W [ 8/26/2015 11:41:00 AM ] Modem board: MSM8916 [ 8/26/2015 11:41:00 AM ] RF cal date: 2015.01.29 [ 8/26/2015 11:41:00 AM ] IMEI: 358494060027458 [ 8/26/2015 11:41:00 AM ] Checking Super user right... true [ 8/26/2015 11:41:00 AM ] Initialization RIL... OK [ 8/26/2015 11:41:00 AM ] Unlocking... OK [ 8/26/2015 11:41:00 AM ] Rebooting phone... OK [ 8/26/2015 11:41:00 AM ] Unlock done |
08-26-2015, 10:37 | #14225 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SHV-E210L Software version: 22.2 File analysis... OK Total file size: 0x71BCFE84 (1819 Mb) Searching USB Flash Interface... detected COM4 Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending tz.img... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending cache.img... OK Sending hidden.img... OK Sending modem.bin... OK Sending VIA_modem.bin... OK Flashing done (time - 00:09:36) Done with Samsung Tool PRO v.22.2 |
The Following User Says Thank You to razib143 For This Useful Post: |
08-26-2015, 10:39 | #14226 (permalink) |
No Life Poster Join Date: Dec 2009 Location: INDIA Age: 36
Member: 1195083 Status: Offline Sonork: QQ:3208821449 Thanks Meter: 1,348 | GT-S7560M 4.0.4 direct unlock done [IMG][/IMG] |
The Following User Says Thank You to mr.luckytarun For This Useful Post: |
08-26-2015, 12:13 | #14227 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung F490 Direct Unlock done... UNLOCK INSTRUCTIONS: UART cable: 1. Phone must be powered on. 2. Connect the phone to UART cable. 3. Choose correct COM port in port settings. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. USB cable: 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SGH-F490 Selected port: COM5 Z3X BOX Serial Port Software version: 22.2 Reading phone info... OK Model: SGH-F490 Country code: ÇÁ¶û½º(FTM) Cal date: 2008-02-28 Factory SW: F490AFHB3 Unique number: 70200000322166 Memory phone: TYA000BC10H(F490) Phone S/N: R2XQ581239 Reading IMEI... OK IMEI: 351578021467451 Reading sysinfo... OK Calculating... OK Writing sysinfo... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.22.2 |
08-26-2015, 14:10 | #14228 (permalink) |
Freak Poster Join Date: Jul 2015 Location: AG COMM QATAR Age: 38
Member: 2426327 Status: Offline Sonork: 100.4294967295 Thanks Meter: 70 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Fill values what you need to repair. 5. Press 'Repair' button. Operation: Repair Selected model: GT-S5830I Software version: 22.2 Waiting ADB device... OK Reading phone info... Model: GT-S5830i Android version: 2.3.6 Product code: Phone version: S5830iXXLB1 PDA version: S5830iJPLB1 CSC version: S5830iOJPLA5 CSC country code: UAE CSC sales code: XSS HW version: MP 0.000 Phone S/N: 0000000000F Modem board: RF cal date: 20150826 IMEI: 359971042759299 Checking Super user right... true Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.22.2 I DIDN'T GET NETWORK SIGNAL PLZ HELP ME TO FIX THIS PROBLEM .... |
08-26-2015, 14:35 | #14229 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung c3322i lock read done Operation: Read User Lock Selected model: GT-C3322I Selected port: COM7 Z3X BOX Serial Port, 921600 Software version: 20.5 Checking phone at COM7... OK Reading phone info... Model: Country code: Factory SW: Unique number: Memory phone: Software version: C3322iDDNJ1/C3322iODDNJ1 IMEI: 3593730+++++++ Reading phone lock... OK Phone lock: 14789 Done with Samsung Tool v.20.5 |
08-26-2015, 14:42 | #14230 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung s3 i747m Unlock Done Operation: Unlock Selected model: SGH-I747M Selected port: COM105 SAMSUNG Mobile USB Serial Port , Software version: 20.5 Reading phone info... Reading IMEI... OK IMEI: 35332305xxxxxxx Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool v.20.5 Thanks z3x Team |
08-26-2015, 20:12 | #14231 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Write CERT Selected model: SM-G900T Selected port: COM49 SAMSUNG Mobile USB Serial Port Software version: 22.3 Checking certificate file... OK KEY ID: 0478 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G900T Android version: 4.4.2 Product code: SM2G900TZWATMB Phone version: G900TUVU1CNK2 PDA version: G900TUVU1CNK2 CSC version: G900TTMB1CNK2 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: R38FB0C36MT Modem board: MSM8974PRO RF cal date: 2014.11.08 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0478 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.22.3 Operation: Write CERT Selected model: SM-G900T Selected port: COM43 SAMSUNG Mobile USB Serial Port Software version: 22.3 Checking certificate file... OK KEY ID: 0478 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G900T Android version: 5.0 Product code: SM-G900TZWATMB Phone version: G900TUVU1DOB1 PDA version: G900TUVU1DOB1 CSC version: G900TTMB1DOB1 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: RV8F503BFRK Modem board: MSM8974PRO RF cal date: 2014.05.08 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0478 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.22.3 |
08-27-2015, 07:36 | #14234 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g360h unlock done Selected model: SM-G360H Selected port: Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: SM-G360H Android version: 4.4.4 Product code: SM-G360HZWDKSA Phone version: G360HDDU0AOD4 PDA version: G360HDDU0AOB1 CSC version: G360HOJV0AOB2 IMEI: 3596560685xxxxx Phone S/N: R51G61050LX Checking Super user right... true Reading cert... OK Certificate file saved to M:\Program Files\Z3X\Samsung\SamsungTool\Cert\SM-G360H_3596560685xxxxx_R51G61050LX.cert Done with Samsung Tool v.18.9 Selected model: SM-G360H Selected port: Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-G360H Android version: 4.4.4 Product code: SM-G360HZWDKSA Phone version: G360HDDU0AOD4 PDA version: G360HDDU0AOB1 CSC version: G360HOJV0AOB2 IMEI: 3596560685xxxxx Phone S/N: R51G61050LX Checking Super user right... true Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.18.9 Done with Samsung Tool v.18.9 |
08-27-2015, 09:56 | #14235 (permalink) |
Junior Member Join Date: May 2015
Member: 2391420 Status: Offline Thanks Meter: 7 | J100H SINGLE SIM UNLOCK DONE Operation: Unlock Selected model: SM-J100H Software version: 22.0 Waiting ADB device... OK Reading phone info... Model: SM-J100H Android version: 4.4.4 Product code: SM-J100HZBAITV Phone version: J100HXCU0AOE1 PDA version: J100HXCU0AOD5 CSC version: J100HVFG0AOE1 CSC country code: Germany CSC sales code: VD2 HW version: MP 0.201 Phone S/N: R51G71YLEMB Modem board: sc7727s RF cal date: 20150717 IMEI: 3528 Checking Super user right... true Running zTool, please wait... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.22.0 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
