01-28-2017, 09:54 | #1 (permalink) |
Junior Member Join Date: Jul 2016 Location: iran Age: 33
Member: 2595761 Status: Offline Thanks Meter: 4 | problem to change 2 imie j500h i write cert file but changed imie 1 i need efs j500h for change 2 imie by z3x box plz help me |
01-28-2017, 10:54 | #2 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | BRO TRY THIS CERT ITS FOR DUAL SIM J500 SM-J500H_DS_351811078623134_RV1G92C7BFV - Download - 4shared - kefah salah |
The Following User Says Thank You to profkefah For This Useful Post: |
01-28-2017, 11:13 | #3 (permalink) |
Member: 2595761 Status: Offline Thanks Meter: 4 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500H Selected port: COM68 SAMSUNG Mobile USB Serial Port Software version: 27.7 Checking CERT file... OK KEY ID: 0241 Waiting ADB device... OK Reading phone info... Model: SM-J500H Android version: 5.1.1 Product code: SM-J500HZDDMID Phone version: J500HXXU1AOI1 PDA version: J500HXXU1AOI1 CSC version: J500HOJV1AOI1 CSC country code: Iraq CSC sales code: MID HW version: MP 0.400 Phone SN: RV1H10RV58T Modem board: MSM8216 RF cal date: 2016.01.21 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0241 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.27.7 try changed imie 1 and not changed imie 2 why!!! i have bst and z3x plz help |
01-29-2017, 10:45 | #9 (permalink) | |
Member: 2595761 Status: Offline Thanks Meter: 4 | Quote: tnx bro Download J500H 11078623134 RV1G92C7BFV dual sim hsn900 cert | |
