01-18-2012, 12:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | problem conecting to qualcom modems ? i have some werid problem , it juats started i have reinstalled all drivers from start. after fresh restart of pc , if i try to unlock and qualcom 3g phone , i have np. after first try of soft detecting the diagnostic port , next time i try soft freez on searching modem. if i disconect phone it gives error modem cant be found , but if phone stay conected soft is frozen. like i said , first time after reboot first phone works with np.... any ideas ? im using latest version |
01-18-2012, 22:03 | #4 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | any phone i try do the same s5603 , s8300 ,this i try today more then 5 different phones when it try to search for the modem soft freez , if i'll let it it will stay like this forever , i can press cancel or just remove the phone from usb and it release. any ideas ? i have removed drivers and reinstalled them few times. reinstall the z3x programs few times it happen also with i9000 im sure there is a problem as this is a new winxp install and in first few days all worked 100% |
01-23-2012, 13:11 | #6 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | well i checked and i got the problem. as soon as i check use server on the 3g tool , program freez on conecting to modem i have no firewall or any antivirus program. so support can you please give some help about this problem ? if i remove the check for use server , soft freez when conecting to phone Count supported models - 290 Searching Samsung USB Modem... Not Found Done with Samsung Tool ver 11.9 Reading Phone Info... OK Reading SysInfo... Error Access Denied Done with Samsung Tool ver 11.9 Reading Phone Info... OK Model: GT-S5603 Country Code: CEL Cal Date: 2009-09-28 Factory SW: S5603JIIH1 Unique Number: 12340000352809 Memory Phone: K5R2G1GACC(S5600)S Phone S/N: RUWZ326852 Build: M6281A-KLRZR-4.0.9640_3G IMEI: 356176034014751 Reading SysInfo... Error Access Denied Done with Samsung Tool ver 11.9 Searching Samsung USB Modem... |
01-25-2012, 07:43 | #7 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | problem still not solved !!! noone can answer this problem ? when check use server soft freezing when trying to conect to modem!!! try reinstall soft many times |
02-09-2012, 14:56 | #9 (permalink) |
No Life Poster Join Date: Mar 2006 Location: morroco
Member: 245026 Status: Offline Thanks Meter: 382 | 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Samsung usb 3. Connect USB cable, setup drivers. 4. Choise Modem driver 5. Select New algo and unlock 6. Press Unlock Code: Done with Samsung Tool ver 12.1 Searching Samsung USB Modem... Detected (COM10) Reading Phone Info... OK Model: GT-S5603 SW: S5603JPJE2 IMEI: 35========== Country Code: OPENاâ Factory SW: S5603JPJE2 Unique Number: 80530000600465 Memory Phone: K5R2G1GACC(S5603)S Reading SysInfo... OK Searching server... OK Unlocking ... OK Done with Samsung Tool ver 12.1 |
The Following User Says Thank You to sassa_01 For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
