04-09-2017, 22:52 | #1 (permalink) |
Freak Poster Join Date: Jun 2016 Location: cairo
Member: 2587761 Status: Offline Thanks Meter: 30 | problem with unlock g930 f UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G930F Software version: 28.0 Waiting ADB device... Ok Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: SM-G930FZKADBT Phone version: G930FXXU1APB6 PDA version: G930FXXU1BPLB CSC version: G930FDBT1BPH2 CSC country code: Germany CSC sales code: DBT HW version: MP 0.700 Phone SN: R38J105S20V Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2016-12-01 RF cal date: 20170107 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Reading MODEM... Ok Calculating... error (0 4) Initialization zTool... Ok Running zTool, please wait... Start... Card error Ok Initialization... error (error(2)) Try downgrade modem if possible Done with Samsung Tool PRO v.28.0 need help mr blang thanks in advance |
04-09-2017, 23:41 | #3 (permalink) | |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | Quote:
https://m.youtube.com/watch?v=gK5GD_mYrwo Sent from my HUAWEI VNS-L31 using Tapatalk | |
04-28-2017, 20:09 | #4 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Quote:
Thanks | |
