11-26-2012, 13:13 | #1 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1536983 Status: Offline Thanks Meter: 5 | Problem unlock GT-B5510, read info but when press unlock not found phone I have a problem, with unlock GT-B5510 Yoigo Spain. I have read info fine but when I press unlock it says not found phone. I select "samsung modem" on port, I selected "z3x box" too, but it doesn´t work. Fox example I can to see that port where phone is connected is com 124, but when I select "samsung modem" I can to see that port here is 125 (in Administrador device is 124), if I change the usb port, it happends the same problem, port com100 on administrador devince, but on z3x soft I can only to see com99. If I select z3x box or not select port, it happends the same problem, It read the correct info but when I click unlock button or read codes, it says "phone not found". I wait your answer. Thanks. |
11-28-2012, 00:17 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | Quote:
read info and unlock via different method. totaly different. | |
