04-16-2016, 16:21 | #1 (permalink) |
Registered User Join Date: Jan 2010
Member: 1209576 Status: Offline Thanks Meter: 35 | problem to unlock pattern lock galaxy s5300 i try to unlock pattern lock from samsung galaxy s5300 with the box v 17.5 i use s5220 than v 25.1 pro s5300 no way the same problem i need solution i need a full dump s5300 |
04-16-2016, 17:25 | #2 (permalink) |
Member: 1209576 Status: Offline Thanks Meter: 35 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: GT-S5300 Software version: 25.1 ADB device not selected Done with Samsung Tool PRO v.25.1 |
04-16-2016, 17:41 | #3 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | want to break pattern, or Unlock Network.? For pattern z3x Not Have option... u can break it by Hard reset..! to Do this Hold Vol+,Home & power, Now wipe Data/cache.when Device popup recovery.... |
04-16-2016, 17:49 | #4 (permalink) | |
Member: 1209576 Status: Offline Thanks Meter: 35 | Quote:
wipe data by hard reset not work need a solution | |
