08-03-2013, 07:08 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: India
Member: 1014826 Status: Offline Thanks Meter: 88 | Problem To Unlock Samsung S4-I9500 Selected model: I9500 Selected port: Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.15.2 Done with Samsung Tool v.15.2 Then I Try This Mathed For 4.2.2 The “Developer Options” menu item on 4.2.* is hidden. 1. Goto Settings -> About Phone. 2. Goto “Build Number” at the end of the Scroll list. 3. Tap on “Build Number” repeatedly (7 times). On your third tap you should see message indicating that you only have 4 more taps to go to ‘become a developer’. 4. Continue: 4 more taps. 5. Hooray, you are now a ‘Developer’, go back to the Setting page. 6. You should see Developer Option menu item in your setting list now. 7. Open Developer Options and check USB debugging > Ok But Not Show Anything Then I Try The Keys For Modem *#7284# But Not Happen Anything Also I try This Key For usb Deb *#9090# Nothing Happen Bhone Not Conected With Z3x Need Hellp To Unlcok |
