11-28-2012, 13:16 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: InsiDe lAtest CPUs Age: 35
Member: 1386000 Status: Offline Sonork: 100.1624055 Thanks Meter: 29 | Problem in Unlocking SC06D with Z3x When I try to unlock Galaxy S3 NTT Docomo with Z3x it gives me the error "NO ANSWER FROM PHONE". Please Help Mr. Blang |
11-30-2012, 15:38 | #3 (permalink) |
Member: 1386000 Status: Offline Sonork: 100.1624055 Thanks Meter: 29 | Sorry for late Im using samsung tool 13.4. Rried with Original Samsung USB Cable and the cable which came with z3x box but no avail. Here is my log Selected model: SC06D Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.13.4 Selected model: SC06D Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.13.4 Done with Samsung Tool v.13.4 But when I select SC04D in Model the log is, Selected model: SC04D Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM115 Reading phone info... Software version: SC06DOMALJ3/SC06DDCMALJ3/SC06DOMLJ3/SC06DOMALJ3 IMEI: 352670054449644 Product code: SGH-N064RWNDCM Done with Samsung Tool v.13.4 Selected model: SC04D Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SC-06D Android version: 4.0.4 Product code: SGH-N064RWNDCM Phone version: SC06DOMLJ3 PDA version: SC06DOMALJ3 CSC version: SC06DDCMALJ3 IMEI: Unknown Checking Super user right... true Reading data from phone... error Done with Samsung Tool v.13.4 Done with Samsung Tool v.13.4 Please help soon |
11-30-2012, 21:58 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,515 | Quote:
also you can try usb or uart mode. i not see correct log of usb unlocking. cos usb not selected. | |
The Following User Says Thank You to blang For This Useful Post: |
12-06-2012, 17:25 | #5 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 534602 Status: Offline Thanks Meter: 30 | Selected model: SC06D Selected port: COM28 Z3X Serial Port Selected port speed: 115200 Reading phone info... Done with Samsung Tool v.13.4 Selected model: SC06D Selected port: COM28 Z3X Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.13.4 |
07-17-2013, 11:27 | #6 (permalink) |
No Life Poster Join Date: May 2008 Location: Sri Lanka , Kandy Age: 34
Member: 763865 Status: Offline Sonork: Cvlvertcharges Thanks Meter: 123 | Selected model: SC06D Selected port: COM10 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.15.0 Done with Samsung Tool v.15.0 help plz but setting are correct *#9090# |
08-20-2013, 15:10 | #11 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IN GSM
Member: 304574 Status: Offline Sonork: 100.1593675 Thanks Meter: 72 | downgrade to 4.04 then dial *#7284# then go to quqlqcom setting select last one restart phone select corect com port do read code done. |
10-09-2013, 14:57 | #13 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 897922 Status: Offline Thanks Meter: 42 | type *#9090# select uart type *#7284# and select uart to modem.. this code will work on version 4.0.4 only..your in higher version downgrade it. and use micro uart cable..3303 select com and press unlock tested 10000% hear is the log... enjoy.... |
11-11-2013, 21:39 | #14 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1617200 Status: Offline Thanks Meter: 0 | Good afternoon, I'm trying to unlock this model, and I'm not getting there I decided to flash with another version downloaded from Z3x support did however usually ends properly and connects and makes rebolte renicia qdo arrives on screen samsung so it is, already downloaded 3 different versions on the stand and not succeeded, would like help to be able to solve this problem, someone already did flash this unit successfully help me. Thank you. |
