Read code issue a520w check the log Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM92 Reading phone info... OK Model: SM-A520W AP version: A520WVLU1BQI1 CSC version: A520WOYA1BQI1 CP version: A520WVLU1BQI1 Product code: TLS Phone SN: R58J34LCM1F Unique number: CBJ10571FE25424 Searching Samsung diag port... detected COM91 Reading phone info... OK CP version: A520WVLU1BQI1 CP build: Sep 1 2017 14:03:33 Reading data from phone... error (19) Done with Samsung Tool PRO v.29.7 |
Please try again. Did you reboot pc after removing USB capture software? |
Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM92 Reading phone info... OK Model: SM-A520W AP version: A520WVLU1BQI1 CSC version: A520WOYA1BQI1 CP version: A520WVLU1BQI1 Product code: TLS Phone SN: R58J34LCM1F Unique number: CBJ10571FE25424 Searching Samsung diag port... detected COM91 Reading phone info... OK CP version: A520WVLU1BQI1 CP build: Sep 1 2017 14:03:33 Reading data from phone... OK Calculating... error Security damaged (hmac mismatch) HWID: D40600000000000000000000856A1755856A1755D86145973F 32A69481AEA47F 03251001 Done with Samsung Tool PRO v.29.7 |
knox is 0 ..................... |
knox is 0 ..................... too short of a message i guesss sorry for duplicaiton |
Blang did you check it ???? any update ??? |
1 Attachment(s) Hello and I have this pb.What solution can You ofer. Thanks |
Thanks a lot UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-A520W Software version: 30.1 Searching Samsung modem... detected COM222 Reading phone info... OK Model: SM-A520W AP version: A520WVLU1BQI1 CSC version: A520WOYA1BQI1 CP version: A520WVLU1BQI1 Product code: RWC Phone SN: R58J84MQ65P Unique number: CBJ105862B89254 Searching Samsung diag port... detected COM183 Reading phone info... OK CP version: A520WVLU1BQI1 CP build: Sep 1 2017 14:03:33 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 17251419 NET lock: 40814851 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.1 |
UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. only can find DM +ACM +ADB 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-A520W Software version: 30.1 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM45 Reading phone info... OK Model: SM-A520W AP version: A520WVLS1AQH1 CSC version: A520WOYA1AQH1 CP version: A520WVLS1AQH1 Product code: SM-A520WZKAKDO Phone SN: R58J94ZT23J Unique number: CBJ1087C8EAA864 Searching Samsung diag port... detected COM44 Reading phone info... OK CP version: A520WVLS1AQH1 CP build: Aug 3 2017 19:04:44 Reading data from phone... error (1) Done with Samsung Tool PRO v.30.1 |
