11-14-2015, 20:08 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Read Codes & Unlock OK - Still Locked Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-G920F Software version: 23.3 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 5.1.1 Product code: SM-G920TZKABTU Phone version: G920TUVU2COF6 PDA version: G920XXU2QOI7 CSC version: G920FXXU2QOI7 CSC country code: Russia CSC sales code: SER HW version: REV1.0 Phone S/N: R58G316G7JD Modem board: SHANNON333 RF cal date: 20150316 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 35073152 NET lock: 20737081 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.3 Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SM-G920F Software version: 23.3 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 5.1.1 Product code: SM-G920TZKABTU Phone version: G920TUVU2COF6 PDA version: G920XXU2QOI7 CSC version: G920FXXU2QOI7 CSC country code: Russia CSC sales code: SER HW version: REV1.0 Phone S/N: R58G316G7JD Modem board: SHANNON333 RF cal date: 20150316 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.3 IMEI is Fine Any Idea ? Regards |
11-17-2015, 18:27 | #9 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Wrong flash file flashed to phone. I had same problem after flashing correct flashfile then the bought code worked at first try otherwise displayed Network Unlock Unsuccessful |
11-19-2015, 19:18 | #11 (permalink) | |
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
Some one flashed with Russian firmware Any way guys its old story , thanks to all for replay Regards | |
