12-31-2015, 19:32 | #1 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Eastern U.S.
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | Regarding New Security on N920T FRP Reset, Searching React, Erasing React: error |
The Following User Says Thank You to CastleSamsung12 For This Useful Post: |
01-01-2016, 19:58 | #4 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | OKC works for FRP/Samsung/EE Reset on Z3X iDonTuseRubbers, so you are incorrect, it is another security update just released, I am uploading the files to drop box now that allows the downgrade back to OKC, because again, Z3X works on OKC for FRP reset. |
01-01-2016, 20:02 | #5 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | 40 Minutes left on upload but be sure to download OKC for after you flash these files that allow the wipe and the downgrade from the security update. |
01-01-2016, 20:04 | #6 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | So after you flash these two files, place in download mode, use Z3X's frp/samsung/ee reset, it will work flawless, then after you go through and the phone is working and you are in it, put in download again and flash full OKC firmware. |
01-01-2016, 21:34 | #7 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | You need to download both the AP.tar and the BL.tar sorry that i had to upload to two different sources. https://www.dropbox.com/s/7yvq72je2g...P.tar.md5?dl=0 http://www.filedropper.com/bltar Cheers! |
01-01-2016, 23:14 | #11 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | Will upload to mediafire momentarily, need help with att s6, have efs wipe tar, heard you can just use z3x pro v21.6 to write, ne one with info pm please. Putting to mediafire now. |
01-01-2016, 23:15 | #12 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | I made a program that writes the firmware for each phone and allows downgrade. |
01-01-2016, 23:24 | #13 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | The two files are uploading to Mediafire right now, I will post link the second it is complete. |
01-02-2016, 05:14 | #15 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | Mediafire link as requested AP: http://www.mediafire.com/download/uu...857/AP.tar.md5 BL: https://forum.gsmhosting.com/vbb/****************************/?2qcycjepqqbhjtr |
