05-09-2016, 17:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: morocco
Member: 1012961 Status: Offline Thanks Meter: 37 | remove frp from j120f not done 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. If you have one file firmware, then you must check 'Use one package file' option. 4. Check flashing options if needed (Repartition, EFS clear, Boot update). 5. Power on phone in download mode (turn off phone, press vol.down + home + power). 6. Connect phone to PC with USB cable, install drivers if needed. 7. Press 'Flash' button. opération: Reset FRP/React/EE modèle sélectionné: SM-J120F Version logiciel: 25.3 Searching Samsung USB Flash Interface... Détécté COM75 Paramètre de connection... OK Lecture PIT du telephone... OK Searching FRP lock... OK Erasing FRP... erreur Fait avec Samsung outil PRO v.25.3 |
