01-12-2016, 11:01 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: dunia antah berantah
Member: 1616754 Status: Offline Thanks Meter: 245 | Remove FRP SM-N9208 lolipop 5.1.1 [ 1/12/2016 4:37:00 PM ] Selected model: SM-N9208 [ 1/12/2016 4:37:00 PM ] Software version: 24.0 [ 1/12/2016 4:37:00 PM ] [ 1/12/2016 4:37:00 PM ] Searching Samsung USB Flash Interface... detected COM9 [ 1/12/2016 4:37:00 PM ] Setup connection... OK [ 1/12/2016 4:37:00 PM ] Reading PIT from phone... OK [ 1/12/2016 4:37:00 PM ] Searching FRP lock... OK [ 1/12/2016 4:37:00 PM ] Erasing FRP... OK [ 1/12/2016 4:37:00 PM ] Searching Reactivation lock... OK [ 1/12/2016 4:37:00 PM ] Erasing Reactivation lock... OK [ 1/12/2016 4:37:00 PM ] Searching EE lock... OK [ 1/12/2016 4:37:00 PM ] Erasing EE lock... OK [ 1/12/2016 4:37:00 PM ] Reset done [ 1/12/2016 4:37:00 PM ] Thanks Z3X team... |
The Following User Says Thank You to wutangclan33 For This Useful Post: |
05-30-2016, 12:46 | #5 (permalink) |
Freak Poster Join Date: May 2015 Location: Algiers, Algeria
Member: 2399672 Status: Offline Thanks Meter: 187 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-N9208 Software version: 24.8 Searching Samsung USB Flash Interface... detected COM123 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... error Done with Samsung Tool PRO v.24.8 |
05-30-2016, 14:52 | #6 (permalink) | |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Quote:
try this http://forum.gsmhosting.com/vbb/f453...count-2092541/ | |
