06-30-2017, 11:30 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1759686 Status: Offline Thanks Meter: 45 | Repair imei g925f 7.0 not ok Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-G925F Software version: 27.9 Waiting ADB device... Ok Reading phone info... Model: SM-G925F Android version: 7.0 Product code: Phone version: G925FXXU5EQAC PDA version: G925FXXU5EQBG CSC version: CSC country code: CSC sales code: HW version: Phone SN: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-02-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.9 how to fix |
The Following User Says Thank You to tvhuong262 For This Useful Post: |
06-30-2017, 12:49 | #2 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | u must downgrade to 6.0.1 your current version G925FXXU5EQAC is binary 5 use this version to this version www . sammobile . com/firmwares/galaxy-s6-edge/SM-G925F/EVR/download/G925FXXS5DQE2/171136/ remove spaces |
The Following User Says Thank You to profkefah For This Useful Post: |
02-22-2020, 10:47 | #4 (permalink) |
Junior Member Join Date: Dec 2017 Location: Bangladesh
Member: 2791460 Status: Offline Sonork: no Thanks Meter: 1 | Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 7.0 PDA version: G925FXXU6ERG1 CSC version: G925FVFG6ERG1 Phone version: G925FXXU6ERF7 Product code: CSC country code: UK CSC sales code: VOD Phone SN: RF8G62544QN IMEI: 350000000000006 HW version: RF cal date: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-06-01 Boot Warranty bit: 1 SIM State: NOT_READY Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 46 5A 4F 35 04 00 00 00 00 00 00 00 00 00 00 Calculating... hmac mismatch, this can damage phone continue? Yes OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.39.4 |
The Following User Says Thank You to Redoy Ghosh For This Useful Post: |
