02-18-2017, 05:07 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: italy
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | repair imei g935f error Code: REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935F Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDAHUI Phone version: G935FXXU1BPJE PDA version: G935FXXS1BPLC CSC version: G935FHUI1BPI1 CSC country code: ITALY CSC sales code: HUI HW version: MP 0.800 Phone SN: RF8H31RC88Y Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160215 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON335 HWID: D3 E8 44 8A 47 B7 19 D9 8C CE 57 11 D7 72 83 50 Calculating... Ok Repairing... Ok Writing NV data... Ok Rebooting phone... Ok Repair done Done with Samsung Tool PRO v.27.7 |
02-18-2017, 05:15 | #2 (permalink) |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | if I try to re-write I have this error Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: G935FXXU1BPJE PDA version: G935FXXS1BPLC CSC version: G935FHUI1BPI1 CSC country code: ITALY CSC sales code: HUI HW version: Phone SN: RF8H31RC88Y Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (decompress error) Done with Samsung Tool PRO v.27.7 |
