06-08-2016, 07:53 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Repair Imei LG nexus 5X supported models: 1233 Check adb server status... OK Device not found! Elapsed: 0 secs. --> (v9.15) Check adb server status... Try kill add server... ERROR Device name: Nexus 5X Firmware version: Android release: 6.0.1 Platform: msm8992 Root status: OK! Current intefaces: ptp,adb Enable diagnostic port Device not found! Elapsed: 76 secs. --> (v9.15) Mode: Normal Model: FAAAANAZ Build version: Jan 13 201619:31:11Jan 04 201616:00:00FAAAANAZ SW Version: M8994F-2.6.31.1.09 IMEI: 3536260787 IMEI2: 3536260787 BlueTooth Address: 08:00:01:02:26:00 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v9.15) Mode: Normal Model: FAAAANAZ Build version: Jan 13 201619:31:11Jan 04 201616:00:00FAAAANAZ SW Version: M8994F-2.6.31.1.09 IMEI: 3536260787 IMEI2: 3536260787 BlueTooth Address: 00:00:01:02:26:00 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v9.15) Checking phone at COM125 Detected ID: 00001001 (MSM8994) SW Version: M8994F-2.6.31.1.09 Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Elapsed: 254 secs. --> (v9.15) Mode: Normal Model: FAAAANAZ Build version: Jan 13 201619:31:11Jan 04 201616:00:00FAAAANAZ SW Version: M8994F-2.6.31.1.09 IMEI: 3536260787 IMEI2: 3536260787 BlueTooth Address: 2C:00:01:02:26:00 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v9.15) NV read... NV save:..\backup\H968_3536260787_08062016_014004.cnv Elapsed: 73 secs. --> (v9.15) Mode: Normal Model: FAAAANAZ Build version: Jan 13 201619:31:11Jan 04 201616:00:00FAAAANAZ SW Version: M8994F-2.6.31.1.09 IMEI: 3536260787 IMEI2: 3536260787 BlueTooth Address: 00:00:01:02:26:00 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v9.15) Repair IMEI... Working with security zone Checking phone at COM125 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... LG Modem port not detected! Port already opened! Elapsed: 0 secs. --> (v9.15) Reboot phone Done Elapsed: 116 secs. --> (v9.15) Mode: Normal Model: FAAAANAZ Build version: Jan 13 201619:31:11Jan 04 201616:00:00FAAAANAZ SW Version: M8994F-2.6.31.1.09 IMEI: 3536260787 IMEI2: 3536260787 BlueTooth Address: 00:00:01:02:26:00 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v9.15) Repair IMEI... Check adb server status... Try kill add server... ERROR Found 1 device(s) Device name: Nexus 5X Firmware version: Android release: 6.0.1 Platform: msm8992 Root status: OK! Checking phone at COM125 Detected ID: 00001001 (MSM8994) SW Version: M8994F-2.6.31.1.09 Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Scaning security area by HUMMER algo... Making security area diagram: ------------------------+++--- ------------------------+++--- Backup security zone... Sec zone saved: ..\Backup\H968_3536260787xxxxx_08062016_014805.lgs b1 Writing security zone... Reboot phone Phone detected! Reading QCN file... OK Checking phone at COM125 Detected ID: 00001001 (MSM8994) SW Version: M8994F-2.6.31.1.09 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Repair IMEI1... Write IMEI 1 OK Write IMEI 2 OK Repair done! Elapsed: 394 secs. --> (v9.15) |
06-08-2016, 08:36 | #2 (permalink) |
Crazy Poster Join Date: May 2007
Member: 504430 Status: Offline Thanks Meter: 14 | You should post the new IMEI number or at least just the last 4 digits to show it actually worked. Since the part: "Write IMEI 1 OK Write IMEI 2 OK Repair done!" Does not really mean anything. I have done V10 phones where it says, "write IMEI OK Repair done!" but IMEI came out at 000000000000000 even after performing the IMEI "0" procedure. With that being said, I can confirm that IMEI repair is possible using the Z3X tool. I just did it differently several days ago after receiving my new to me Nexus 5X phone model H790. Using H968 model number, I backup security incase anything bad happens then I can go back. Next, I backup QCN file and then edit this file with new IMEI number. Next Reset Security in phone and then write new QCN into the phone. This will do the IMEI repair on the Nexus 5X phone. This method actually works on a lot of LG phones when standard 1 click IMEI repair does not work. I have done this even with a Xiaomi Mi4 phone but that is another story--yes IMEI repair of a Xiaomi Mi4 phone using z3x box Lg Tools. Gene |
The Following User Says Thank You to gszeto99 For This Useful Post: |
01-20-2017, 02:32 | #9 (permalink) | |
Freak Poster Join Date: Oct 2014
Member: 2277857 Status: Offline Thanks Meter: 68 | Quote:
Andrew, thanks for the info and I have used this command on other LG phones to enable the diag port. On the Nexus 5x (running 7.0) there is no lg_diag_cmd folder under sys/device/platform , so command fails. I searched for diag_enable and no results anywhere on the phone. Any other ideas? | |
01-20-2017, 03:57 | #10 (permalink) |
Member: 2277857 Status: Offline Thanks Meter: 68 | Never mind, I got it, Qualcomm HS-USB Diagnostic 903D driver popped up and loaded and IMEI repaired using ADB Mode Model H955 Mode: Normal Model: FAAAANAZ Build version: Jul 7 201608:46:36Jun 25 201610:00:00FAAAANAZ SW Version: M8994F-2.6.33.2.14 IMEI: XXXXXXXXXX6390-3 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v9.31) Repair IMEI... Check adb server status... OK Found 1 device(s) Device name: Nexus 5X Firmware version: Android release: 7.0 Platform: msm8992 Root status: OK! Checking phone at COM14 Detected ID: 00001001 (MSM8994) SW Version: M8994F-2.6.33.2.14 Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Scaning security area by HUMMER algo... Making security area diagram: ------------------------+++--- ------------------------+++--- Backup security zone... Sec zone saved: ..\Backup\H955_XXXXXXXXXX63903_19012017_183205.lgs b1 Writing security zone... Reboot phone Phone detect error! Reading QCN file... OK Checking phone at COM14 Detected ID: 00001001 (MSM8994) SW Version: M8994F-2.6.33.2.14 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Repair IMEI1... Write IMEI 1 OK Repair done! Elapsed: 778 secs. --> (v9.31) Mode: Normal Model: FAAAANAZ Build version: Jul 7 201608:46:36Jun 25 201610:00:00FAAAANAZ SW Version: M8994F-2.6.33.2.14 IMEI: XXXXXXXXXX6330-9 BlueTooth Address: 47:06:26:35:3A:08 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v9.31) |
01-25-2020, 22:51 | #13 (permalink) |
Member: 2277857 Status: Offline Thanks Meter: 68 | I haven't done one of these in a while. Unplug phone, you need to load the qualcomm USB driver (different from the LG driver). Make sure USB debugging is on and select the the Qualcomm HS-USB Diagnostic 903D driver (if you don't load the Qualcomm driver, you won't see this). then just repair imei as you normally would. |
