02-03-2016, 19:11 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: king of saudia arabia
Member: 2501469 Status: Offline Sonork: speakme2009 Thanks Meter: 33 | Reset frp error z3x pro every bady i have problem with sm-g925t 5.1.1 FRP ON i use all box and dongle for reset frp but no thing slove even Z3X PRO LAST VERSION AND OLD VERSION UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G920T Software version: 23.9 Searching Samsung USB Flash Interface... detected COM59 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.23.9 any help any edia about this strong problem |
02-03-2016, 19:20 | #2 (permalink) |
Member: 2501469 Status: Offline Sonork: speakme2009 Thanks Meter: 33 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G925T Software version: 24.2 Searching Samsung USB Flash Interface... detected COM47 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.24.2 |
02-03-2016, 19:28 | #5 (permalink) |
Member: 2501469 Status: Offline Sonork: speakme2009 Thanks Meter: 33 | in fact 4 dayes i cant slove my problem i flash stock rom with oden no otg slove my prob no any box or any dongle explain me plzzzzzz |
02-03-2016, 19:31 | #6 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: World of technology
Member: 749754 Status: Offline Sonork: partycrasher131 Thanks Meter: 134 | Quote:
http://forum.gsmhosting.com/vbb/f453...olved-2042556/ | |
The Following User Says Thank You to partycrasher131 For This Useful Post: |
02-03-2016, 19:33 | #7 (permalink) |
Member: 2501469 Status: Offline Sonork: speakme2009 Thanks Meter: 33 | hi sir first thanx aloot for u and now i iwll download SBOOT AND MODEMS.rar after that i will post resolt here again thanx |
02-03-2016, 20:42 | #8 (permalink) |
Member: 2501469 Status: Offline Sonork: speakme2009 Thanks Meter: 33 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G925T Software version: 24.2 Searching Samsung USB Flash Interface... detected COM15 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.24.2 الحمد لله im very happy my problem sloved |
05-16-2016, 09:49 | #9 (permalink) |
Crazy Poster Join Date: May 2015 Location: United Arab Emirates
Member: 2395079 Status: Offline Thanks Meter: 18 | I have Successfully done with Samsung tool pro 25.3 Hi.. 1st you need to flash with repair files then try this on unlock option here is my phone report Operation: Reset FRP/React/EE Selected model: SM-J500H Selected port: COM52 Z3X BOX Serial Port Software version: 25.3 Searching Samsung USB Flash Interface... detected COM4 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.25.3 |
