Old 01-26-2017, 09:33   #1 (permalink)
Member: 2638040
Reset FRP lock Samsung J3 2016 (J320FN)
Hi everybody,
I need your help because I have tried to reset FRP using Z3X Box so I have downloaded Combination folder in "Download section" for my device but now, when I boot my J3, I have a boot loop with and and screen with a list of green text.
I have tried to install last stock rom with SamFirm but no change.
Any help would be really appreciate.
Thanks,
Denis
Old 01-26-2017, 09:45   #2 (permalink)
kamrolhasan's Avatar
Member: 2506300
Thanks Meter: 337
Need screenshot ..........
Old 01-26-2017, 10:38   #3 (permalink)
Member: 2638040
I agree with you but i'm a new user on this forum so i can't upload pictures in my post.
Any help to do it?
Old 01-26-2017, 10:45   #4 (permalink)
Member: 2506300
Thanks Meter: 337
Any help to do it?
Maybe its checksum......
The Following 2 Users Say Thank You to kamrolhasan For This Useful Post:
Old 01-26-2017, 10:54   #5 (permalink)
Member: 2638040
Thanks for your help. Can you explain me how to do it please?
The Following User Says Thank You to denis.717 For This Useful Post:
Old 01-26-2017, 11:09   #6 (permalink)
Member: 2506300
Thanks Meter: 337
have you whatsapp send me picture
Old 01-26-2017, 11:12   #7 (permalink)
Member: 2506300
Thanks Meter: 337
No need picture Flash this file using ap part by odin md5_OXA_OXAFA51_J320FNXXU0APB2_CL6907192_QB8770875 _REV00_user_mid_noship.tar - Download - 4shared - kamrol hasan
post result
The Following 4 Users Say Thank You to kamrolhasan For This Useful Post:
Old 01-26-2017, 11:58   #8 (permalink)
Member: 2638040
Problem solved wtih your files. Thanks a lot!
Old 01-26-2017, 12:00   #9 (permalink)
Member: 2506300
Thanks Meter: 337
press only thanks Button.....allways help forum member.and follow forum rule.
Old 01-26-2017, 19:52   #10 (permalink)
Member: 2638040
Can you explain me how to use combination files in order to reset FRP lock please?
Old 01-27-2017, 01:32   #11 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 836
Try this NO Box method:
NO BOX Universal Lollipop 5.1.1 Marshmallows 6.0.1 GOOGLE FRP Account Bypass Removal
CLICK ON THE THANKS BUTTON IF THIS POST WAS USEFULL
The Following 2 Users Say Thank You to GalaxyVibe For This Useful Post:
Old 01-27-2017, 10:10   #12 (permalink)
Member: 2638040
Okay so I have folowed the procedure but i block at step 14.
When i click on the apk file, installation is okay but if i try to open it, I got a message :"FRP Bypass stopped"... and i don't see Google Sign in windows.
Any help??
Old 01-27-2017, 22:42   #13 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 836
Any help??
Try by downloading the following apk and copy it from your computer to an SdCard. Slice in the SD card in your phone. Open the ES Files program and try again. Here is the link:
https://www.androidfilehost.com/?fid=24665542585483676
Old 01-27-2017, 22:45   #14 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 836
Once you are at the Samsung account, search for "ES FILE Explorer" and install it in your phone. Once, it is installed, open the app. The app will allow you to go to the "Download" folder of your phone. There you will find the "com.rootjunky.frpbypass-1.0.apk" that you previously downloaded. Open and Install the "com.rootjunky.frpbypass-1.0.apk". The App will send you to the "Google Sign In" windows. DO NOT SING IN. Click on the three dots at the upper right hand side of the screen and click on "BROWSER SIGN IN". Then a new Google browser sign in screen will appear. Yes, you can Sign in there with your existing Google account (Again, do not worry, you can remove it later). Once you are signed in, you need to restart your phone.
Old 01-28-2017, 01:22   #15 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 836
1. You can also try by downloading the Quick Shortcut Maker apk from the link below:
https://quickshortcutmaker.en.uptodown.com/android
2. Copy the apk from your computer to an SdCard. Slice in the SD card in your phone.
3. Open the ES Files program and search for the "Quick Shortcut Maker apk" in your SD Card.
4. Install it in your phone and open the apk. After opening the Quick Shortcut Maker apk, search on the search bar of it "Google Account Manager".
5. Then select:
Type Email and Pasword
com.google.android.gsf.login/
com.google.android.gsf.login.EducLoginActivity
6. Then, select 'Try"
7. The App will send you to the "Google Sign In" windows. DO NOT SING IN. Click on the three dots at the upper right hand side of the screen and click on "BROWSER SIGN IN". Then a new Google browser sign in screen will appear. Yes, you can Sign in there with your existing Google account (Again, do not worry, you can remove it later). Once you are signed in, you need to restart your phone.
8. Follow the setup instructions. The phone is not going to ask you for the Google account because you already entered.
9. Once at the home screen, click on 'Settings". Then go to "Accounts” and click on the "Samsung Account", click on "Remove Account". The phone is going to ask you for a confirmation to enter your password. Enter it and click on Remove. Go back and click on your "Google Account". Click on "Remove Account".
10. Go back to settings, and then click on "BACKUP AND RESET". Then click on "FACTORY DATA RESET". Then "RESET DEVICE". The phone will factory reset and the FRP will be removed.
DO NOT FORGET TO CLICK ON THE THANKS BOTTON
Page generated in 0.37554 seconds with 7 queries
