10-26-2017, 07:27 | #2 (permalink) |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | |
The Following 4 Users Say Thank You to farukpdm For This Useful Post: |
01-22-2018, 14:31 | #3 (permalink) |
Freak Poster Join Date: Apr 2009 Location: pirojpur bangladesh
Member: 1012044 Status: Offline Sonork: 100:1668956 Thanks Meter: 131 | ROOT file for G610F network unlock done 6.0.1 7.0 CF-Auto-Root-v6.01+7.0 100%-smg610f 100000000% working UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G610F Software version: 30.4 Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 7.0 Product code: SM-G610FZDDKSA Phone version: G610FDDU1BQJ4 PDA version: G610FDDU1BQJ7 CSC version: G610FOJV1BQJ7 CSC country code: KSA CSC sales code: KSA HW version: MP 0.400 Phone SN: R58J91Q7BKM Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-08-01 RF cal date: 20170909 IMEI: 3516xxxxxxxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 77 05 00 00 00 00 00 00 00 00 00 00 03 2E 1F DD Calculating... OK Checking hash file... OK Please wait, calculating codes... OK (time - 00:00:08) Freeze code: 81946370 NET lock: 08035792 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.4 UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G610F Software version: 30.4 Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 7.0 Product code: SM-G610FZDDKSA Phone version: G610FDDU1BQJ4 PDA version: G610FDDU1BQJ7 CSC version: G610FOJV1BQJ7 CSC country code: KSA CSC sales code: KSA HW version: MP 0.400 Phone SN: R58J91Q7BKM Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-08-01 RF cal date: 20170909 IMEI: 351692xxxxxxxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 77 05 00 00 00 00 00 00 00 00 00 00 03 2E 1F DD Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
The Following 13 Users Say Thank You to shanjoyhalder For This Useful Post: |
01-28-2018, 10:18 | #4 (permalink) | |
Product Manager Join Date: Feb 2015 Location: United Arab Emirates
Member: 2340466 Status: Offline Sonork: 100.1669233 Thanks Meter: 221 | Quote:
The Following User Says Thank You to Ashikulislam For This Useful Post: |
01-29-2018, 15:46 | #5 (permalink) | |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote:
Thanks, works with 7.0, just needs patience to wait when phone is restarting | |
The Following 4 Users Say Thank You to Fragga For This Useful Post: |
