02-23-2016, 12:02 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | SM-g925i samsung account bypass Can't unlocked new 5.1.1 reactiavtion lock on g925i Code: Operation: Reset FRP/React/EE Selected model: SM-G925I Software version: 24.2 Searching Samsung USB Flash Interface... detected COM6 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.24.2 |
10-31-2016, 17:54 | #5 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | g925i samsung account bypass dead i have a g925i trying to reset frp using z3x, phone dead any solution to bypass samsung account thx |
11-01-2016, 21:43 | #9 (permalink) |
No Life Poster Join Date: Nov 2013 Location: Third World ;)
Member: 2061381 Status: Offline Sonork: 100.1673769 Thanks Meter: 129 | If you want help please answer this: - Which software version is installed in phone, and build number? - I think you used standard method in download mode, but tell me if it is right and if you tried another method. - Is your phone alive now? what do you mean exactlywith "phone dead"? - You can put in recovery/download mode? Also in google and here in forum you will find many methods, some with downgrade, some with sidesync and some with combination firmware. You can search and try some of them, or if you you preffer I can help you but I can't if don't know any info about your handset. |
The Following User Says Thank You to joel_3mo For This Useful Post: |
11-03-2016, 17:37 | #10 (permalink) |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | it's about samsung account lock i try to use frp in z3x but it was dead i can't downgrade , because it give error only version of software accepted is : G925IDVS3EPC1_G925IKSA3EPB4 thx for help |
11-03-2016, 19:54 | #11 (permalink) | |
Member: 2061381 Status: Offline Sonork: 100.1673769 Thanks Meter: 129 | Quote:
First you can try to use sidesync method, search it here in forum and in google, there is a lot of info for this method. First downgrade fimware to an older version, ALL PARTS EXCEPT BOOTLOADER (sboot.bin and cm.bin), then make a factory reset and only then use sidesync method. Anyway if you can't, I could try to share engineering kernel for easyer way. BR | |
11-04-2016, 07:39 | #12 (permalink) | |
Here is file for enable ADB: http://www.4shared.com/file/p0YSqyBr...2_ENG_KER.html Last edited by joel_3mo; 11-04-2016 at 07:46. | |
11-04-2016, 16:12 | #13 (permalink) | |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | Quote:
