02-13-2010, 19:58 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: INDIA, TamilNadu, ViLLuPuRaM
Member: 651056 Status: Offline Sonork: 100.1592669 not using now Thanks Meter: 201 | S3653 locked sir i have S3653 in phone lock how to unlock this model i try but Code: Last version on support: 2G tools v3.4.0030 Selected model: S3653 Selected com port: COM45 Selected speed port: 921600 Connect phone(RJ 45 cable) and power on - press 2-3 second Detecting UART port..... OK Repower phone - please wait If see on phone "Upload data to PC" - reconnect phone manually Disconnect RJ45 cable and connect data cable(APCBS10BBE or compatible) to phone Search modem ... Timeout Elapsed time: 86 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- thx |
02-13-2010, 20:11 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
phone lock - only reflashing. | |
02-14-2010, 09:04 | #3 (permalink) |
Member: 651056 Status: Offline Sonork: 100.1592669 not using now Thanks Meter: 201 | c3653 flashing problem Hi 2 all blang sir i have problem in flash c3653 i put phone in download mode & click firmware result Code: Selected model: S3653 Selected com port: COM45 Selected speed port: 921600 Search modem ... Modem found Timeout Timeout modem not found - fail Elapsed time: 15 second, sw ver: 3.4.0030 any one help thx |
02-14-2010, 10:55 | #4 (permalink) | |
Connect usb cable direct to pc usb. In speed port try choise USB. | |
02-14-2010, 18:26 | #7 (permalink) |
Member: 651056 Status: Offline Sonork: 100.1592669 not using now Thanks Meter: 201 | sir i triy but result is not ok frist time randem port Code: Selected model: S3653 Selected com port: COM45 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM49 Timeout Elapsed time: 6 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- Selected model: S3653 Selected com port: COM45 Selected speed port: 921600 Search modem ... Modem found Timeout Timeout modem not found - fail Elapsed time: 14 second, sw ver: 3.4.0030 Code: Selected model: S3653 Selected com port: COM49 Selected speed port: 115200 Search modem ... Modem found modem not found! modem not found - fail Elapsed time: 14 second, sw ver: 3.4.0030 thx |
The Following User Says Thank You to akk.vpm For This Useful Post: |
02-14-2010, 18:30 | #8 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Switch phone to flash mode. Connect usb cable direct to pc usb. In speed port try choise USB. |
The Following 2 Users Say Thank You to blang For This Useful Post: |
02-14-2010, 19:39 | #9 (permalink) | |
Member: 651056 Status: Offline Sonork: 100.1592669 not using now Thanks Meter: 201 | Quote:
there is on usb mode in speed port try choise USB. this model s3653 i made video link click to download Code: http://www.4shared.com/file/222091366/277a273c/Z3X.html thx | |
03-07-2010, 15:17 | #11 (permalink) |
No Life Poster Join Date: Feb 2008 Location: disease
Member: 708305 Status: Offline Thanks Meter: 260 | you see this information thats you solution If see on phone "Upload data to PC" - reconnect phone manually Disconnect RJ45 cable and connect data cable(APCBS10BBE or compatible) to phone Search modem ... when he you see reconnect phon you must reconnect usb after that connecte usb now need flash fon omar |
The Following User Says Thank You to kakaomar For This Useful Post: |
03-07-2010, 16:22 | #12 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: ♥ ♥ ♥ ♥ Age: 35
Member: 748880 Status: Offline Thanks Meter: 1,705 | YOU NEED COMBO CABLE USB+RJ45 CAN'T UNLOCK with ONLY USB CABLE !! !! ! or try with fresh OS . Quote:
The Following User Says Thank You to SOHAIL BASHARAT For This Useful Post: |
A887 phone lock | Moosani | NSPRO | 5 | 06-29-2010 14:14 |
Different btw samsung candy S3650 Vs S3653 | visit999 | Z3X-Team Products | 3 | 12-02-2009 23:46 |
S3653 lockcode done | Nataraki | Z3X-Team Products | 0 | 10-28-2009 05:44 |
Sgt-s3653 | bimes | UST Pro II | 0 | 10-27-2009 14:49 |
