11-14-2014, 15:51 | #1 (permalink) |
Junior Member Join Date: Aug 2006 Location: Sri Lanka
Member: 339368 Status: Offline Thanks Meter: 7 | S4 I9500 NEW CPU type IMEI repair succesfully done via USB without UART by Z3X One on Jellybean 4.3 and second one on Kitkat 4.4.2 STEP BY STEP GUIDE 1. You can get default IMEI (004999XXXXXXX) by full firmware flash, If you ar on IMEI NULL state. 2. For Root and desable Knox (only for 4.3 and above) install Phils touch recovery for I9500 Via Odin (I used this since CF autoroot gave me some trouble of desabling Knox) Link: https://goo.im/devs/philz_touch/CWM_...Edition/i9500/ 3. Reboot phone and copy attached Knox removal script to phone memory 4. Boot into recovery 5. Install Knox removal script 6. Go to PhilZ setting 7. Select Re-root System (SuperSU) -Yes- Apply SuperSU 8. Reboot and install SuperSU from google play and update binary 9. Install root checker from google play and get it confirm you have root access 10. Dial *#0808# Select MTP+ADB and hit OK (You dont need to select DM+MODEM+ADB or *#9090# since you are not going to use UART PORT/CABLE) 11. Enable USB Debugging and connect to pc via USB. If drivers start installing, let finish the process 12. Do the IMEI repair via Z3X as you do Now You will get original IMEI and Serial But you will have NOT REGISTERED ON NETWORK problem now. IMPORTANT: DO NOT TRY TO USE NETWORK REPAIR AS YOU DONE FOR I9300 AND IT WILL GIVES YOU IMEI NULL AGAIN 13. Without doing above, write Cert file from attached and if it not worked, try differant cert from here: http://forum.gsmhosting.com/vbb/f453...-here-1855895/ ENJOY Repair log of one phone on Kitkat 4.4.2 Code: Selected model: I9500 Selected port: COM75 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-I9500 Android version: 4.4.2 Product code: Not Active Phone version: I9500DDUFNA4 PDA version: I9500XXUFNC1 CSC version: I9500YDDFNC2 IMEI: 004999010640000 Phone S/N: 00000000000 Checking Super user right... true Disabling Factory mode... OK Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Writing nv data... OK Rebooting phone... OK Repair done Done with Samsung Tool v.18.3 Selected model: I9500 Selected port: COM75 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM29 Reading phone info... Software version: =1,1 IMEI: 357633056962449 Done with Samsung Tool v.18.3 Selected model: I9500 Selected port: COM75 Z3X BOX Serial Port Selected port speed: 115200 Checking certificate file... OK Waiting ADB device... OK Reading phone info... Model: GT-I9500 Android version: 4.4.2 Product code: Not Active Phone version: I9500DDUFNA4 PDA version: I9500XXUFNC1 CSC version: I9500YDDFNC2 IMEI: 357633056962449 Phone S/N: RF1F403TK22 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security v0 Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool v.18.3 |
The Following 3 Users Say Thank You to hasloku For This Useful Post: |
11-14-2014, 18:03 | #3 (permalink) | |
Member: 339368 Status: Offline Thanks Meter: 7 | Quote:
02-11-2015, 09:51 | #12 (permalink) |
No Life Poster Join Date: Feb 2015 Location: IRAN-TABRIIZ
Member: 2339474 Status: Offline Sonork: 100.1662352 Thanks Meter: 332 | hi i have new type i9500 . i did change imei for work in turkey country but when cheng no registered network. and dail *#0011# and imei cert is fail. and again write new cert file but imei changed to imei of new cert. please help me i want change my own imei and no network problem. |
02-14-2015, 12:57 | #14 (permalink) | |
Member: 2339474 Status: Offline Sonork: 100.1662352 Thanks Meter: 332 | Quote:
But you will have NOT REGISTERED ON NETWORK problem now.*** how can solve this problem?? i was changed imei. and baseband is ok changed imei is ok but i have now above problem | |
