06-14-2013, 12:05 | #1 (permalink) | |
Freak Poster Join Date: May 2011 Location: Pilipinas
Member: 1574276 Status: Offline Thanks Meter: 37 | S4 (I9505) Cant Unlcock Meaning of this error Quote:
Is this version is not supported? i follow mostly all of the instruction of the member Who has succesfully unlock this model I also use 14.7/14.5 version of z3x but still the same regard's | |
06-14-2013, 12:11 | #2 (permalink) |
No Life Poster Join Date: Jan 2013
Member: 1873398 Status: Offline Thanks Meter: 149 | contact me chek imei first show or not ? i unlock 3set successfully if u want more help contact me [email protected] 03214640261 |
06-14-2013, 12:18 | #3 (permalink) | |
Member: 1574276 Status: Offline Thanks Meter: 37 | Quote:
Can you post the procedure that you do? regard's | |
06-14-2013, 12:40 | #5 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Selected model: I9505 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... error access denied Done with Samsung Tool v.14.6 same issue here ????? |
06-15-2013, 04:53 | #7 (permalink) |
Insane Poster Join Date: Jun 2007 Location: philippines
Member: 526062 Status: Offline Thanks Meter: 17 | Same problem here.. original cable is using.. new version of S4 i9505 Kernel Version is higher... http://forum.gsmhosting.com/vbb/f453...-help-1672722/ |
06-22-2013, 07:39 | #9 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Atlantis
Member: 638371 Status: Offline Thanks Meter: 56 | having the same problem here... maybe somethings wrong with the handset or software maybe, becouse when i try switching to uart and usb, theres an above message shows error, then it not reboot completely, unless removin battery, note only s4 from smart, from globe are all ok |
06-22-2013, 14:15 | #10 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,530 | Please someone with i9505 v.4.2.2 error while code reading and unlocking , contat with me. |
The Following User Says Thank You to blang For This Useful Post: |
06-25-2013, 10:48 | #11 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 45
Member: 107932 Status: Offline Thanks Meter: 21 | Same here any solution? Selected model: I9505 Selected port: COM2 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... error access denied Done with Samsung Tool v.14.4 |
07-06-2013, 07:30 | #14 (permalink) | |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | Quote:
The Following User Says Thank You to Rex For This Useful Post: |
