Old 05-27-2013, 08:09   #1 (permalink)
Member: 90366
Thanks Meter: 14
s4 i9505 imei null/null repair
i have an s4 i9505 in service after root it has imei null/null and baseband unknown
function *#9090# doesn`t work, it is black blank screen and no selection for uart functions
*#7284# and *#0808# are working
on repair function everything is ok but when it says to connect to uart cable it answer it has no response from phone
i flashed the two flashes from suport but the situation is the same
any sugestions?
Old 05-31-2013, 16:43   #2 (permalink)
Angelo Cruz's Avatar
Member: 8012
Thanks Meter: 104
same problem here , anyone?
Old 06-01-2013, 10:15   #3 (permalink)
Member: 1915610
Thanks Meter: 2
People same problem here, any sugestions ?
Old 06-03-2013, 17:30   #4 (permalink)
Member: 530783
Thanks Meter: 12
This is because the baseband has corompido anyone knows anything?
I have a client with the same thing happens S3 and repair baseband anyone know?
Old 06-15-2013, 19:37   #5 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 130
any sugestions?
same problem here, any solution ?
Old 06-16-2013, 01:26   #6 (permalink)
Member: 1752659
Same problem. nothing works.
Old 06-16-2013, 10:22   #7 (permalink)
Member: 145248
Thanks Meter: 19
Does *#197328640# work? Perhaps there you got UART selection..
Послато са HTC One X користећи Тапаток 2
Old 07-05-2013, 20:31   #8 (permalink)
Member: 1816005
Thanks Meter: 172
any sugestions?
i have this problem with an i9505, please tell me if you managed to repair the imei and baseband
Old 07-06-2013, 12:26   #9 (permalink)
Member: 1816005
Thanks Meter: 172
i don't have anymore the i9505 to try this tool found on xda. you could try it and post result.
it's called efs professional
here is the link Dev-Host - EFS_Professional_2.0.46_Release.zip - The Ultimate Free File Hosting / File Sharing Service
Old 07-07-2013, 10:12   #10 (permalink)
Member: 530783
Thanks Meter: 12
This can repair baseband and imei null/null? Only repair this is ansansam Box?
Enviado desde mi GT-I9300 usando Tapatalk 4 Beta
Old 07-10-2013, 19:51   #11 (permalink)
Member: 1816005
Thanks Meter: 172
any sugestions?
You need to flash an older gsm modem in order to enable service mode. Samsung blocked this service in newer modem.
Old 08-19-2013, 16:00   #12 (permalink)
LiLSaint's Avatar
Member: 1258305
Thanks Meter: 41
I was tryed alot of things but i didnt have succes.
The main problem is to get service mode and you cant get service mode becouse of baseband.
First need solution for baseband and then with flash for modem you will got service mode.
When Baseband got repaired probably you will see some imei like 0049 etc or some other but it can be see afther that we will see service mode and im sure it will be like that
Old 09-05-2013, 19:45   #13 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 345
I have the same problem : *#9090# doesn't work .
IMEI null .
Old 09-05-2013, 23:29   #14 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 173,748
IMEI null .
try downgrate. on last firmware 9090 not work.
Old 09-07-2013, 20:57   #15 (permalink)
ZiDanRO's Avatar
Member: 1722871
Thanks Meter: 117
I think he tried to say, that 9090 menu doesn't show any option, not that is not working, because it shows a black screen.
I had a phone in same condition and I could not repaire it.
I even tried to pun a full EFS backup from a good phone.
Sent from my GT-I9300 using Tapatalk 4
Page generated in 0.37737 seconds with 7 queries
