01-21-2014, 07:30 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Quebec city Canada
Member: 798845 Status: Offline Thanks Meter: 45 | S4 M919V 4.3 imei repair = big problem the issue is the *#9090# serviceMode don't working, so Z3X dont recognize the phone i trayed a lot of ways *#0808# and go with serial port , 0 phone detected, flash modem.bin 4.2.2 but no chance, Selected model: M919V Selected port: COM5 USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.8 because i rooted it , i selected other model Selected model: M8800 Selected port: COM5 USB Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM3 Reading phone info... Model: SGH-M919V IMEI: Reseting phone lock... error Reseting SIM lock... error Done with Samsung Tool v.16.8 please help , i wont get back my phone Last edited by tadj; 01-21-2014 at 07:39. |
01-21-2014, 19:18 | #3 (permalink) |
Freak Poster Join Date: Dec 2012 Location: The North
Member: 1861077 Status: Offline Thanks Meter: 89 | Mothod 1. Why do you flash 4.2.2 Modem on 4.3 firmware. ODIN a 4.3 firmware on the phone. Root the phone using Kingo or ur favorite tool. Install SuperSU from play store, and disable knox when it ask you to. Write the original IMEI. Method 2. Get another M919v, backup the NV value using QPST, Open HEX editor, change the IMEI on that backup file (search 08 3A etc), and change the IMEI backword, restore the new file using QPST. IMEI changed |
01-22-2014, 03:19 | #4 (permalink) |
Member: 798845 Status: Offline Thanks Meter: 45 | with z3x , it said repaired but in real it did no thing Selected model: M919V Selected port: COM5 USB Serial Port Selected port speed: 115200 Checking phone at COM5 Repairing IMEI... OK Repairing network settings... OK Reseting... OK Repair done Done with Samsung Tool v.16.8 imie is always null |
01-22-2014, 08:30 | #5 (permalink) | |
Member: 798845 Status: Offline Thanks Meter: 45 | Quote:
please any developer has the solution | |
01-22-2014, 12:54 | #6 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: Congo
Member: 332635 Status: Offline Sonork: 100.1648966 Thanks Meter: 54 | Quote:
01-22-2014, 15:36 | #7 (permalink) | |
Member: 1861077 Status: Offline Thanks Meter: 89 | Quote:
01-22-2014, 19:04 | #8 (permalink) | ||
this is all DAta work my bad nv_data and a true nv_data from other good same s4 with two methode this is the link https://forum.gsmhosting.com/vbb/****************************/?3b0elx4r835jjl3 | ||
01-23-2014, 06:01 | #9 (permalink) |
Member: 798845 Status: Offline Thanks Meter: 45 | Selected model: M919V Selected port: COM5 USB Serial Port Selected port speed: 115200 Checking phone at COM5 Repairing IMEI... OK Repairing network settings... OK Reseting... OK Repair done Done with Samsung Tool v.16.9 imei still null |
01-24-2014, 04:49 | #11 (permalink) |
Member: 798845 Status: Offline Thanks Meter: 45 | the big problem become no thing , i resolve my problem i did it waooooo Selected model: M919 Selected port: COM5 USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SGH-M919V Android version: 4.3 Product code: Not Active Phone version: M919VVLUEMK5 PDA version: M919VVLUEMK5 CSC version: M919VYVLEMK5 IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM5 OK Reading phone info... Model: SGH-M919V Country code: VTR Cal date: - Factory SW: M919VVLUEMK5 Unique number: C16B01E8915B010 Memory phone: - Bypass MSL... OK Repairing IMEI... OK Rebooting... OK Repair done Done with Samsung Tool v.14.7 just use this version of z3x as you have m919v use just m919 and this methode http://forum.gsmhosting.com/vbb/f453...4-3-a-1763743/ . go to setting and enable debugging, dial *#0808#(with I337) or *#7284# (with M919, T999, I747) and chose DM+ADB+MODEM, then install drivers. 2. Root the phone, there are too many root methods out there, just chose the one that you feel appropriate for you. 3. Open Z3X 14.7 and chose the correct model. 4. Write the correct IMEI and click repair 5. Use Uart cable when prompt. Done. Code: Selected model: I337 Selected port: COM535 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SGH-I337 Android version: 4.3 Product code: SGH2I337ZKMATT Phone version: I337UCUEMK2 PDA version: I337UCUEMK2 CSC version: I337ATTEMK2 IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM535 OK Reading phone info... Model: SGH-I337 Country code: ATT Cal date: - Factory SW: I337UCUEMK2 Unique number: C16B05D62C94E80 Memory phone: - Bypass MSL... OK Repairing IMEI... OK Rebooting... OK Repair done Done with Samsung Tool v.14.7 thank you very much hasanr92 , thank you |
