03-24-2016, 16:41 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | S5 neo SM-G903W unlock problam http://forum.gsmhosting.com/vbb/f453...ccess-2043088/ UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G920W8 Software version: 24.9 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G903W Android version: 5.1.1 Product code: SM-G903WZKABMC Phone version: G903WVLU1AOJ9 PDA version: G903WVLU1AOJ9 CSC version: G903WOYA1AOJ9 CSC country code: Canada CSC sales code: BMC HW version: G903W.01 Phone S/N: Modem board: SHANNON310 RF cal date: 20151124 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Reading nv data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:24) For check lock status: *#7465625# Done with Samsung Tool PRO v.24.9 |
03-24-2016, 16:43 | #2 (permalink) |
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | read code done but code not show UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G903W Software version: 24.9 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G903W Android version: 5.1.1 Product code: SM-G903WZKABMC Phone version: G903WVLU1AOJ9 PDA version: G903WVLU1AOJ9 CSC version: G903WOYA1AOJ9 CSC country code: Canada CSC sales code: BMC HW version: G903W.01 Phone S/N: Modem board: SHANNON310 RF cal date: 20151124 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Reading nv data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:23) For check lock status: *#7465625# Done with Samsung Tool PRO v.24.9 |
03-24-2016, 16:45 | #3 (permalink) |
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | z3x show unlock done but mobile ask unlock pin UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G903W Software version: 24.9 Waiting ADB device... OK Reading phone info... Model: SM-G903W Android version: 5.1.1 Product code: SM-G903WZKABMC Phone version: G903WVLU1AOJ9 PDA version: G903WVLU1AOJ9 CSC version: G903WOYA1AOJ9 CSC country code: Canada CSC sales code: BMC HW version: G903W.01 Phone S/N: Modem board: SHANNON310 RF cal date: 20151124 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Reading nv data... OK Checking NV data... OK Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.9 |
03-26-2016, 14:22 | #8 (permalink) |
Junior Member Join Date: Aug 2015 Location: India
Member: 2451504 Status: Offline Thanks Meter: 2 | Okay so with your yelp I restore the Imei but now it says insert sim unlock. Phone is lock again. I am trying to figure out what's going on. Any suggestions ?? |
04-02-2016, 00:00 | #10 (permalink) |
Insane Poster Join Date: Oct 2010 Location: Canada
Member: 1423046 Status: Offline Thanks Meter: 7 | Step 1. root the phone using Cfroot for G903F link https://download.chainfire.eu/779/CF...xx-smg903f.zip Step 2. Select Model SM-G920W8 and Select Read Code. Software Will show you a warning that wrong model is selected. ignore it and continue. Step 3. Success you will get your Codes. https://drive.google.com/file/d/0B-V...ZqSzFXVUk/view Press Thanks |
04-20-2016, 07:00 | #12 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Viet Nam (VFS)
Member: 1822938 Status: Offline Sonork: 100.1656339 Thanks Meter: 63 | at apr 2016, this phone still unable unlock by z3x pro, direct unlock kill imei, read codes done but not show code (old version show codes but unlock req unsuccessful) z3x team, we need help. SM-G903W_nv_data - Download - 4shared this is original nvdata. |
10-04-2017, 09:10 | #14 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Searching Samsung modem... detected COM244 Reading phone info... OK Model: SM-G903W AP version: G903WVLU1CQH4 CSC version: G903WOYA1CQH4 CP version: G903WVLU1APJ1 Product code: KDO Phone SN: RF8HA20MX4H Unique number: C0000D0E02BF173 Reading IMEI... OK IMEI: 354726076755422 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.3.1 |
