03-16-2010, 09:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Caribbean
Member: 237911 Status: Offline Thanks Meter: 632 | S5233w Succesfull Repair BOOT with Z3x -maybe flash with wrong firmware -boot has been written with other boot? -Maybe while Upgrading error has been occured? - in S5233w if it is written by the other firmware for example S5230 the phone will become dead and you wont be able to detect it again in normal plugging of usb, When i check the phone i recieved its totally dead, my pc wasnt able to detect it... so the solution is repair boot with z3x in my case i encounter error a lot of time, then then i try this, --->the moment i press the boot butoon, i press the power on key right away, then i wait for the message "to UNPRESS THE KEY" then release it Code: Connect phone and press power on 10 second Start repair boot zone type 1... Unpress power button on phone ! Repair - boot ok Elapsed time: 24 second, sw ver: 3.4.0033 the phone now will on but with orange screen, its normal because your phone maybe has a blank program on it (not sure) Now since the phone has power you can now put it to download mode again by pressing Volume down + Cam + power on then flash it with the S5233w file i use multiloader to flash the phones file with S5233w files... Code: Download Start Ch[0] Amss 29622.3KB OK[80.4s] Rsrc1 39220.1KB OK[83.7s] Rsrc2 525.7KB OK[1.2s] FFS 38669.8KB OK[85.6s] All files complete[252.0s] then after flashing this file your phone will power but with yellow screen again (seems nothing happen) its okey, the reason why it was on that mode because the boot of the phone hasnt been change yet, so this time we need to change the boot of the phone by flashing the boot of S5233w file i use multiloader again. after flashing the boot the phone now will power on but this time normal mode so thats my procedure: goodluck regards |
The Following 23 Users Say Thank You to eyestrain For This Useful Post: |
07-05-2010, 14:22 | #7 (permalink) |
Member: 237911 Status: Offline Thanks Meter: 632 | hi, did the repair boot shows success? security fail error message has many different reason, maybe battery low, maybe connection error, file not correct, so if you will show some screenshot that will help |
07-23-2010, 17:12 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2008 Location: marikina, philipines
Member: 830580 Status: Offline Sonork: jhymz Thanks Meter: 317 | thanks eyestrain i follow your procedures and now the phone is working sorry if i can't post the logs and screenshots coz iam so exited when i see the phone is working its really works |
07-30-2010, 21:02 | #10 (permalink) |
Junior Member Join Date: Dec 2008 Location: Bekasi
Member: 923150 Status: Offline Thanks Meter: 7 | Need update Z3X team.S5233w its not same with 5233,phone will dead,,i prefer using another tool without write boot for that phone..btw i have some problem,i finished with U*S HW*,,more simple n save time.. |
08-03-2010, 08:41 | #11 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | thanks mate u saved my s5233w which i accidently killed ... i wasnt sure which radio to choose ... and the radio button u have on ur screenshots is bad ... u must choose brcm2133 . |
08-07-2010, 07:19 | #15 (permalink) | |
Member: 237911 Status: Offline Thanks Meter: 632 | Quote:
and tick the change boot using multi loader... see the last picture of my thread... I said that after flashing the phone will comes to yellow display, its normal since you didnt include the boot file on flashing, Now flash only the Boot file | |
The Following User Says Thank You to eyestrain For This Useful Post: |
DEAD BOOT repair of S7350 possible with Z3X | jomafi | Z3X-Team Products | 6 | 07-10-2010 09:36 |
s3600i repair imei with z3x | ardestan | Z3X-Team Products | 0 | 01-30-2010 13:55 |
how to repair imei with z3x box {samsung tool} | mohammed-anis | Z3X-Team Products | 3 | 10-09-2009 19:27 |
how I can repair j600 with z3x? | Lugo | Z3X-Team Products | 3 | 11-20-2008 22:09 |
