05-04-2012, 19:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: twitter home
Member: 120893 Status: Offline Thanks Meter: 69 | S5253 no network after flash ?? |
05-04-2012, 20:26 | #3 (permalink) |
Registered User Join Date: Jan 2006 Location: Romania Age: 39
Member: 215866 Status: Offline Sonork: 100.1617874 Thanks Meter: 125 | Does phone find any network!?!? Was it working before flashing!? I have this manual for flashing: Here is the proper way to flash this phone. - Use MultiDownloader v5.56. - Select "BRCM2133" from radio buttons. Connect phone in "Download Mode" (press volume up + camera + power on) with usb cable and install drivers if need. Press "Port Search". - Check "Boot Change" and "Full Download". Press "Boot" button and select folder with boot files from uncompressed firmware. Select amss, rsrc1, rsrc2 and factory fota. !!! For rsrc2 use ....(Low)... file, otherwise phone may not power on. Press "Download" and wait. - After procedure is finished phone will boot and be ready for use. - If anyone want, can make pre-configuration. For this follow these steps: 1. Inset *#6984125*# from keyboard. 2. Select "Pre-configuration" from menu 3. For "Operator code" insert *#73561*# (click on field to get keyboard), press "Done" , press "Confirm" 4. Select what You want and press "Install". Phone will restart. !!! WARNING !!! With pre-configuration You will lost all data from phone, make a backup on important data first! And after that phone have full network signal but you can't make any call or send SMS, so you must do what I wrote before: Enter on keypad *2767*2878* press back 3 times press 3 RF Test press 7 RF Cal data Restore press confirm restart phone now all should be fine and phone should make and recive calls! THIS SOLUTION IS FOR S5230 SERIES BUT POSSIBLE WILL WORK ON YOUR PHONE ALSO |
05-05-2012, 08:29 | #5 (permalink) | |
Member: 120893 Status: Offline Thanks Meter: 69 | Quote:
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
