s5260 star2 unlock Is posible to unlock s5260 with z3x?? |
yes it is possible work fine 100% |
which model to select?? s5260 arent in model list!!!!!!!!!!!! |
instal the lates shell and you will able to see the model in the list |
The question was s5260 (not s5620)! |
TRY SELECT S5250 AND TRY UNLOCK. PLS POST RESULTS. WBR sahil2000ind |
this solution doesn't work |
yes, work fine, install kies first. |
s5260 unlock *done* hiya guys had a s5260 in for unlocking, tried everything but wouldent go past the searching modem stage, just kept on failing... *solution* use usb cable, choose s5250, then read codes, and when it goes to searching modem pull out cable and reinsert it into phone, and it will run the rest of the program and give you network code and freeze code :-) tested by me.... brian in ireland :-) |
i got it reading the phone but when i click unlock it says "APPS file SW not found ! Select this file and try again" any advice on where i can get this file. thanks in advance |
unlock done after flash the phone with S5260BVKB3_IDEKB3 Selected model: S5260 Selected com port: COM25 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM26 Phone SN: RQ4B368839 IMEI: 35604404392775 /3 Phone SW: S5260BVKB3 Search flash modem ... Search flash modem ... OK Search flash modem on:COM25 Send loader... OK Wait for boot ... Search flash modem ... Search flash modem ... Search flash modem ... OK Search flash modem on:COM25 Send loader... OK Wait for boot ... Phone must be ON Search modem ... OK Search modem on:COM28 Phone SN: RQ4B368839 IMEI: 3560111111111111 MSL DEACTIVATED - TRUE Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 133 second, sw ver: 3.5.0028 -------------------------------------- |
Selected model: S5260 Selected com port: COM25 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM26 Phone SN: RQ4B368839 IMEI: 35604404392775 /3 Phone SW: S5260BVKB3 Search flash modem ... Search flash modem ... OK Search flash modem on:COM25 Send loader... OK Wait for boot ... Search flash modem ... Search flash modem ... Search flash modem ... OK Search flash modem on:COM25 Send loader... OK Wait for boot ... Phone must be ON Search modem ... OK Search modem on:COM28 Phone SN: RQ4B368839 IMEI: 3560111111111111 MSL DEACTIVATED - TRUE Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 133 second, sw ver: 3.5.0028 |
easy unlock s5260 any idea z3x teme how to unlock s5260 plz help ad thanks |
