Old 08-14-2012, 17:10   #1 (permalink)
XHouser's Avatar
Member: 151737
Sonork: 100.1595988
Thanks Meter: 91
S5360 galaxy Y Flashing problem
Hy , i try to unlock S5360 with Z3X android 2.3.6.
Phone need to be rooted and i need install android 2.3.5 with ODIN 1.85 , but after install android 2.3.5 phone has bad image (double image, see picture)
Unlock was ok with z3x but after i try to install again android 2.3.6 and hope lcd will be back OK, but not ok
if i try install any fw OneFile (ex) S5360XXXX_S5360XXXX_S5360XXX.home.tar always i get this error:
<ID:0/003> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> S5360XXLE1_S5360OXFLD1_S5360XXLE1_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/003> Odin v.3 engine (ID:3)..
<ID:0/003> File analysis..
<ID:0/003> SetupConnection..
<ID:0/003> Initialzation..
<ID:0/003> Get PIT for mapping..
<ID:0/003> Firmware update start..
<ID:0/003> sbl.bin
<ID:0/003> NAND Write Start!!
<ID:0/003> BcmCP.img
<ID:0/003>
<ID:0/003> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
So i flash with 2.3.6 with odin and select all files PIT. PDA, PHONE and CSC, Flashing was successful but still double IMAGE!
After many tryes of flashing i use RIFF BOX to change boot , 1st i make FULL ERASE and after boot RESURECTION with RIFF, when i go to download mode the same DOUBLE IMAGE without any fw inside.
After that i do all operations to fix phone software , flash 2.3.6 again, repair imei with Z3X, unock again, but lcd problem not solve.
After phone completly turn on, image is double, but if i press lock/unlock phone only light (WHITE LCD)
PLEASE someone help me! When phone come in service work PERFECT.
ORIGINAL PHONE FORMWARE WAS XXLE1.
Old 08-14-2012, 17:29   #2 (permalink)
XHouser's Avatar
Member: 151737
Sonork: 100.1595988
Thanks Meter: 91
I forgot to mention that Touchscreen work normal. Only lcd show double.
Old 08-14-2012, 19:06   #3 (permalink)
XHouser's Avatar
Member: 151737
Sonork: 100.1595988
Thanks Meter: 91
Problem solved after much work, I found ORIGINAL FW here blue sky service center: [Stock][ROM][Odin] Galaxy Y S5360 flashable firmware packages and files was good , all archives downloaded before (over 5 gb )was damaged. I try to change extension and extract all give Extracting error.
Old 09-12-2012, 21:00   #4 (permalink)
Member: 129706
Thanks Meter: 23
flash with this file
<ID:0/003> Added!!
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/003> sbl.bin
<ID:0/003>
flash your phone with this file
S5360XXKK6_DBTKK1_Android_2.3.6_Complete
100% work
The Following User Says Thank You to wakeil For This Useful Post:
Old 10-10-2012, 23:52   #5 (permalink)
azeem781986's Avatar
Member: 503161
Sonork: 100.1584069
Thanks Meter: 473
I also had the same problem just right few hours ago and got it done with the fimrware mentioned,but still when the phone boots up,lcd is double logo samsung galaxy Y..but then it turns to normal after 2-3 seconds,how to make it done from bootup(start from first boot)logo screen one picture thnx and regards...
Old 10-11-2012, 06:03   #6 (permalink)
haroon454's Avatar
Member: 653398
Thanks Meter: 669
download this firmware and ur problem solve 100%
S5360BOKK2_DTMKK1_Android_2.3.6_Complete
Old 11-15-2012, 13:43   #7 (permalink)
Member: 769100
tks
100% work
wakeil. thank you very much, this solved my problem. tks.
Old 02-14-2013, 12:06   #8 (permalink)
phone2world's Avatar
Member: 622862
Thanks Meter: 52
5360 problem success with z3x
Selected model: S5360
Selected port: COM3 Z3X BOX Serial Port
Selected port speed: 115200
File analysis... OK
Total file size: 0x0EC789FC
Searching USB Flash Interface... detected COM180
Setup connection... OK
Reading PIT from phone... OK
Saved to C:\Program Files\Z3X\Samsung\Samsung 3G Tool\Pit\S5360_14-2-2013_16-21-29.pit
Sending BcmBoot.img... OK
Sending HEDGE_NVRAM8_RF_LE.bin... OK
Sending sysparm_dep.img... OK
Sending sbl.bin... OK
Sending boot.img... OK
Sending system.img... OK
Sending userdata.img... OK
Sending param.lfs... OK
Sending BcmCP.img... OK
Sending csc.rfs... OK
Flashing Done (time - 00:00:55)
Done with Samsung Tool v.13.9
Old 02-14-2013, 12:13   #9 (permalink)
Member: 622862
Thanks Meter: 52
Flashing succes with z3x box
The Following User Says Thank You to phone2world For This Useful Post:
Old 05-15-2013, 19:27   #10 (permalink)
dharyadi's Avatar
Member: 369678
Thanks Meter: 192
I USE this guide http://forum.gsmhosting.com/vbb/f453...-done-1529769/
driver no problem
using version 14.4
and using this file"S5360DXLE1_S5360XSELB1_S5360DXLE1_HOME.tar.md 5"
and error
Selected port: COM42 Z3X Serial Port
File analysis... OK
Total file size: 0x0DFCC000
Searching USB Flash Interface... detected COM5
Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\S5360_16-5-2013_1-27-0.pit
Sending BcmCP.img... Error
Done with Samsung Tool v.14.4
Old 05-15-2013, 19:28   #11 (permalink)
dharyadi's Avatar
Member: 369678
Thanks Meter: 192
driver no problem
using version 14.4
and error
File analysis... OK
Old 05-15-2013, 20:00   #12 (permalink)
dharyadi's Avatar
Member: 369678
Thanks Meter: 192
i just want to change language
after write this file "Sending sbl.bin... OK "
now phone cannot enter to "recovery mode"
only "download mode"
Old 05-16-2013, 00:14   #13 (permalink)
Member: 1723271
Thanks Meter: 51
Flash it via ODIN sir...
Old 05-16-2013, 07:22   #14 (permalink)
dharyadi's Avatar
Member: 369678
Thanks Meter: 192
PROBLEM SOLVED WITH OTHER FIRMWARE
BOOT:F:\FIRMWARE\Z3X SAMSUNG\S5360\S5360DXMA1_QLBMA1\DefaultCalDataWith Boot_S5360DXLL1_REV05.tar.md5
PDA:F:\FIRMWARE\Z3X SAMSUNG\S5360\S5360DXMA1_QLBMA1\PDA_S5360DXMA1_REV 05.tar.md5
PHONE:F:\FIRMWARE\Z3X SAMSUNG\S5360\S5360DXMA1_QLBMA1\MODEM_S5360DXLL1_R EV05.tar.md5
CSC:F:\FIRMWARE\Z3X SAMSUNG\S5360\S5360DXMA1_QLBMA1\GT-S5360-MULTI-CSC-QLBMA1.tar.md5
File analysis... OK
Total file size: 0x0E4D3BFC
Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\S5360_16-5-2013_13-16-45.pit
Flashing done (time - 00:00:50)
The Following User Says Thank You to dharyadi For This Useful Post:
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.33625 seconds with 10 queries
