s5610 successfull unlock..by z3x 3 Attachment(s) down load & install only z3x driver(SAMSUNG_USB_Driver_for_Mobile_Phones) in pc from server z3x 1 down load this file from z3x server ( CSC_S5620ODDJC1) 10 mb ( CODE_S5620DDJC1) 10 mb 2 connect phone in download mode. (for download mode prees volum down key then press power on) 3 connect cable to pc with phone . 4 clock on port serch on multi loder. 5 phone port will select by exe . 6 click on full download of m d exe. 7 select boot filr folder .after select all file as on image 8 click on download 9 within 5 to 8 minut flace will complit . 10 after flace run z3x softwere select model 5620 11 select all file as on image 3 . 12 click on direct unlock yr phone will unlock enjoy & earn mony |
sorry this phone is s5620 |
S5610 unlocked done.... Code: Selected model: S5610 |
Thank You good useful post. keep post log.... |
Good Work Mate. BR. Arsalan gsm2000. |
Which cable do you use? |
Use cable B3210 (micro uart+usb) select z3x port Selected model: S5610 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 35526405xxxxyy Phone SW: S5610BVKL1 Phone BT ADDR: 50F5-20-3C880B Phone SN: R21D26EQHV [FREZEE]:188xxxx [NET LOCK]:1002xxxx [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 22 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
Yea i make a video about unlocking with uart http://www.youtube.com/watch?v=V62LH0CDpyQ Sent from my GT-I8190N using Tapatalk |
with c3300k microuart cable Selected model: S5610 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 3594xxxxxxxxxx Phone SW: S5xxxxVML1 Phone BT ADDR: BC44-86-C2173B Phone SN: R21xxxxx5V [FREZEE]:1xxxx350 [NET LOCK]:79xxx400 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 14 second, sw ver: 3.5.0040 |
c33ook cable Selected model: S5610 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 353630xxxxx Phone SW: S5610BVKL1 Phone BT ADDR: 04FE-31-286DA1 Phone SN: R21C87xxxx [FREZEE]:30135200 [NET LOCK]:68082110 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 28 second, sw ver: 3.5.0040 ------------------------------------------------------ |
what's the flash mode for s5610 |
unlock done !!! Samsung S5610 with Z3X Use rj45 C3300k cable with the phone OFF , press read codes and insert C3300k cable . elected model: S5610 Selected com port: COM7 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 356939xxxxxxxxxx Phone SW: S5610Bxxxxxx Phone BT ADxxx: 10D5-42-7C3xxx1 Phone SN: Rxx57xxxxxx [FREZEE]:14260620 [NET LOCK]:08708250 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:00000000 Read info - ok Elapsed time: 10 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
with c3300k microuart cable again: Selected model: S5610 Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 3552xxxxxxx Phone SW: S5610XXMA1 Phone BT ADDR: 50F5-20-37xxxx Phone SN: R21xxxxxx [FREZEE]:16069090 [NET LOCK]:480xxxx [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:00000000 [Activa LOCK]:00000000 [Phone LOCK]:12345 Read info - ok Elapsed time: 10 second, sw ver: 3.5.0040 |
Z3X says phone is unlocked, but not unlocked, insert correct sim card showing..! why?? Selected model: S5610 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 35817304860239 Phone SW: S5610XXKK1 Phone BT ADDR: 18E2-C2-999F4A Phone SN: R21C52KAWQ All code change to -> 00000000 If phone lock enter code -> 00000000 Unlock - ok Elapsed time: 14 second, sw ver: 3.5.0040 |
