S5620 dead?? HI! I just try to unlock a samung s6520. I read that I had to fhas before unlock. I flash with the following fhashes: CODE_S5620XEJB2 + CSC_S5620OXEJB2 I only ticked the apps and csc boxes in the program. (I following the instrunctions of this link :http://forum.gsmhosting.com/vbb/f453...s5620-1026095/) After that the phone will not swich on. if I connect the phone with the computer the phone begins to charge the baterry. Then I fhas the phone again with all boxes ticked in the program... but the same result. It is possible to recover the phone?? Thanks best regards |
Flash Phone with multi loader its 100% Working |
Hi! I just download multiloader. can you tell me the configuration of the multiloader? I must tiked the full flash?? or change boot?? wich fash I must to use?? thanks |
check full flash, do full flash and after that flash just csc-open in z3x and do unlock all will be ok tested and unlocked by me BR |
check this thread.will help you.luck br |
tell me u r problem what u face [email protected] |
CSC_S5620OXEJD1 CODE_S5620XEJD1 flash with all files and write boot with multiloader ur phone ok |
HI! I justh fhas the phone with multiloader and the fone works OKS!!!!! ;D thanks... But now the problem is that i cant unlock the phone. I use the z3x I fhash the CSC with the csc_s5620_open_europe_slav.csc ans then i click on direct unlock . and the answer is time out. how I can unlock?? the phone must be in boot mode?? o normal mode?? ... thanks |
HI I have new problem. Affter flash with multiloader the phone works ok. At this moment I try unlock with z3x I had a mistake. I fhased the pone only with csc. after that the phone will not swich on. I flash again with multiloader and the phont will not swich on. why not?? Please help me! |
http://darkforestgroup.com/archives/96 check battery.if boot gone dead,may be not luck br.try to put phone in download mode.post result. |
hi dani2080 Im reading your post... and i have a problem..... Make sure your phone dose not have sim lock or net lock before you try and flash. Type *#7465625# and make sure the SIMLOCK and NETWORKLOCK is OFF, if it is ON you MUST Unlock it or you will freeze your phone! Here is fast and trusted way! Network lock is not as big of risk as simlock, you have a 50/50 chance of bricking your phone if you flash with it on. You have a 100% chance of a brick if the simlock is on. Trust me, members make that mistake every day. I can check that and Im sure that the phone is not unlock. (" You have a 100% chance of a brick if the simlock is on.") what can I do???' |
http://forum.gsmhosting.com/vbb/f453...8/#post6104173 http://forum.gsmhosting.com/vbb/f453...g-z3x-1010463/ check this thread,very explained guide here. |
I put in download mode and I do full fhash, but the phone will not swich on. The screem show: GT-S5620 and a loading bar. When is about 3/4 the phone restart. and then only swich on in downlaod mode. mayby is the fhas¿???¿ or mayby is because I use Rsrc2_S5620(mid).rc2 file instead of Rsrc2_S5620(low).rc2 |
dani2080 The same. I fhas the phone and it will not swith on. if I tiked in chance boot... the screen phone show: upload to pc... |
hello! The last new... The phone is "OK". I fhas with another fhas and works "OK" The problem is when I remove the batery... after that will dont swich on. I must to fhash again... any solution? |
