03-03-2017, 21:10 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2691398 Status: Offline Thanks Meter: 0 | s6 edge 925f no modem I've a s6 edge but when i try to read or do anything with the box, it can't read the modem board. It has no imei or serial number either. I think that it has the efs corrupted. What should i do? Thanks in advance, BR. |
03-03-2017, 22:15 | #3 (permalink) | |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | Quote:
Enviado desde mi SM-G360T1 mediante Tapatalk | |
The Following User Says Thank You to GSM_FIX For This Useful Post: |
03-03-2017, 23:42 | #5 (permalink) |
Member: 2691398 Status: Offline Thanks Meter: 0 | <<<<<<<<LOGS>>>>>>>>>> If I try to "Read phone info" Operation: Info Selected model: SM-G925F Software version: 27.7 Searching Samsung modem... not found Done with Samsung Tool PRO v.27.7 If I try to "Repair" Operation: Repair Selected model: SM-G925F Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: Phone version: PDA version: G925FXXS3DPB1 CSC version: G925FOXA3DPB1 CSC country code: UK & IRE CSC sales code: XEU HW version: Phone SN: Chip name: EXYNOS7420 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.7 |
03-04-2017, 00:13 | #8 (permalink) |
Member: 2684440 Status: Offline Thanks Meter: 218 | You must root your phone first, after write efs if you do it one backup,or try to flash the stock rom Enviado desde mi SM-G360T1 mediante Tapatalk |
03-04-2017, 00:20 | #10 (permalink) |
Member: 2691398 Status: Offline Thanks Meter: 0 | My phone is rooted. I've tried to write efs, but i don't have a backup. I ve flash the stock firm with odin, then i ve rooted the mobile.... and then i ve tried things... but i don't know what to do |
03-04-2017, 09:06 | #11 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1768694 Status: Offline Thanks Meter: 98 | If after flashing baseband is still unknown then read cert, open in notepad and check is IMEI and SN match to Your oryginal, if so then U'r modem is dead. HW issiues |
The Following User Says Thank You to oggi21 For This Useful Post: |
03-04-2017, 10:38 | #12 (permalink) | |
Member: 2691398 Status: Offline Thanks Meter: 0 | Quote:
Could be hw issue only flashing a file? The mobile was slow, but it worked. So i tryed to flash a 5 firm with odin. Then something went wrong and i lost the baseband and imei. But mobile worked... Could it be windows drivers issue? I think that my efs is corrupted or missing. But i don't know how to fix it... After flashing it tells me drk fail too.. Too much issues for a beginner. | |
