Old 03-03-2017, 21:10   #1 (permalink)
Member: 2691398
s6 edge 925f no modem
Hi,
I've a s6 edge but when i try to read or do anything with the box, it can't read the modem board.
It has no imei or serial number either.
I think that it has the efs corrupted.
What should i do?
Thanks in advance,
BR.
Old 03-03-2017, 22:01   #2 (permalink)
Member: 2691398
When i press read phone info... searching samsung modem... not found
Could it be, drivers problem???
Old 03-03-2017, 22:15   #3 (permalink)
Member: 2684440
Thanks Meter: 218
open the dial pad write *#0808# and choose RDNIS+DM+MODEM...ok, after select the Samsung modem on port com and try again
Enviado desde mi SM-G360T1 mediante Tapatalk
The Following User Says Thank You to GSM_FIX For This Useful Post:
Old 03-03-2017, 23:19   #4 (permalink)
Member: 2691398
Available options are:
MTP+ADB
RNDIS+ADB
RNDIS+ACM+DM
RNDIS+ACM+DM+ADB
DM+ACM+ADB
what option do i have to choose?
Thanks a lot
Old 03-03-2017, 23:42   #5 (permalink)
Member: 2691398
<<<<<<<<LOGS>>>>>>>>>>
If I try to "Read phone info"
Operation: Info
Selected model: SM-G925F
Software version: 27.7
Searching Samsung modem... not found
Done with Samsung Tool PRO v.27.7
If I try to "Repair"
Operation: Repair
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Waiting ADB device... Ok
Reading phone info...
Model: SM-G925F
Android version: 6.0.1
Product code:
Phone version:
PDA version: G925FXXS3DPB1
CSC version: G925FOXA3DPB1
CSC country code: UK &amp; IRE
CSC sales code: XEU
HW version:
Phone SN:
Chip name: EXYNOS7420
Modem board:
RF cal date:
IMEI:
Checking Super user right... true
Reading NV data... Ok
Checking NV data... error
Security damaged (1)
Old 03-04-2017, 00:06   #6 (permalink)
Member: 2684440
Thanks Meter: 218
what are you trying to do?
Old 03-04-2017, 00:10   #7 (permalink)
Member: 2691398
i try to come back my phone to life again. It has no imei, so i can't make calls with it.
I've the original imei, so im trying to put it back.
Old 03-04-2017, 00:13   #8 (permalink)
Member: 2684440
Thanks Meter: 218
You must root your phone first, after write efs if you do it one backup,or try to flash the stock rom
Old 03-04-2017, 00:16   #9 (permalink)
Member: 2691443
I just got Z3x box and installed but when I tried with S7 google account and I did not find FRP or EFS as I was told by a friend. Could somebody guide me how to?
Old 03-04-2017, 00:20   #10 (permalink)
Member: 2691398
My phone is rooted. I've tried to write efs, but i don't have a backup.
I ve flash the stock firm with odin, then i ve rooted the mobile.... and then i ve tried things... but i don't know what to do
Old 03-04-2017, 09:06   #11 (permalink)
Member: 1768694
Thanks Meter: 98
If after flashing baseband is still unknown then read cert, open in notepad and check is IMEI and SN match to Your oryginal, if so then U'r modem is dead. HW issiues
The Following User Says Thank You to oggi21 For This Useful Post:
Old 03-04-2017, 10:38   #12 (permalink)
Member: 2691398
Thanks for your reply oggi21.
Could be hw issue only flashing a file? The mobile was slow, but it worked. So i tryed to flash a 5 firm with odin. Then something went wrong and i lost the baseband and imei. But mobile worked...
Could it be windows drivers issue?
I think that my efs is corrupted or missing. But i don't know how to fix it... After flashing it tells me drk fail too..
Too much issues for a beginner.
Old 03-04-2017, 10:51   #13 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,057
Solution bring to official service center, replace board.
Br,
xerraco
Old 03-04-2017, 11:07   #14 (permalink)
Member: 2691398
Could a board get broken flashing?
Old 03-04-2017, 11:21   #15 (permalink)
Member: 2691398
I've written a sn for my phone. Now i think that i need a nvdata backup from a phone like mine. Where should i find this?
Thanks in advance,
Regards.
Page generated in 0.21902 seconds with 8 queries
