12-26-2016, 07:37 | #1 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2228162 Status: Offline Sonork: 23243564rtrwe Thanks Meter: 31 | S6 EDGE --write imei error checking nv data error security damaged (1) |
12-26-2016, 10:50 | #2 (permalink) |
Freak Poster Join Date: Feb 2005 Location: algiers algeria Age: 51
Member: 115573 Status: Offline Thanks Meter: 102 | 12/26/2016 10:27:00 AM ] Operation: Repair [ 12/26/2016 10:27:00 AM ] Selected model: SM-G920F [ 12/26/2016 10:27:00 AM ] Software version: 27.6 [ 12/26/2016 10:27:00 AM ] [ 12/26/2016 10:27:00 AM ] [ 12/26/2016 10:27:00 AM ] Waiting ADB device... [ 12/26/2016 10:27:00 AM ] Please, allow USB debugging on phone... Ok [ 12/26/2016 10:27:00 AM ] Reading phone info... [ 12/26/2016 10:27:00 AM ] Model: SM-G920F [ 12/26/2016 10:27:00 AM ] Android version: 6.0.1 [ 12/26/2016 10:27:00 AM ] Product code: [ 12/26/2016 10:27:00 AM ] Phone version: G920FXXU4BPF1 [ 12/26/2016 10:27:00 AM ] PDA version: G920FXXU4DPGW [ 12/26/2016 10:27:00 AM ] CSC version: G920FOXA4DPGW [ 12/26/2016 10:27:00 AM ] CSC country code: France [ 12/26/2016 10:27:00 AM ] CSC sales code: XEF [ 12/26/2016 10:27:00 AM ] HW version: [ 12/26/2016 10:27:00 AM ] Phone SN: 00000000000 [ 12/26/2016 10:27:00 AM ] Chip name: EXYNOS7420 [ 12/26/2016 10:27:00 AM ] Modem board: SHANNON333 [ 12/26/2016 10:27:00 AM ] RF cal date: [ 12/26/2016 10:27:00 AM ] IMEI: [ 12/26/2016 10:27:00 AM ] Checking Super user right... true [ 12/26/2016 10:27:00 AM ] Reading NV data... Ok [ 12/26/2016 10:27:00 AM ] Checking NV data... error [ 12/26/2016 10:27:00 AM ] Security damaged (1) |
12-26-2016, 11:08 | #3 (permalink) | ||
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | Quote:
12-26-2016, 11:17 | #4 (permalink) |
Member: 115573 Status: Offline Thanks Meter: 102 | downgrade modem ..same Waiting ADB device... Ok Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: Phone version: PDA version: G920FXXU4DPGW CSC version: G920FOXA4DPGW CSC country code: France CSC sales code: XEF HW version: Phone SN: Chip name: EXYNOS7420 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.6 |
12-26-2016, 11:38 | #5 (permalink) | |
Freak Poster Join Date: Jun 2012
Member: 1768694 Status: Offline Thanks Meter: 98 | Quote:
Fix first modem, then try again | |
12-26-2016, 11:55 | #6 (permalink) |
12-26-2016, 12:24 | #11 (permalink) |
Member: 1768694 Status: Offline Thanks Meter: 98 | try this one https://www.dropbox.com/s/o20th6b6nc...65R5TM.7z?dl=0 it's efs and cert |
12-26-2016, 12:28 | #12 (permalink) |
Member: 2228162 Status: Offline Sonork: 23243564rtrwe Thanks Meter: 31 | [QUOTE=oggi21;12243284]try this one https://www.dropbox.com/s/o20th6b6nc...65R5TM.7z?dl=0 it's efs and cert[/QUOT this efs is from level 3 RP and our modem is 4 i think we will face a dead phone if we flashed it |
12-26-2016, 13:06 | #13 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2613683 Status: Offline Thanks Meter: 3 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G925F Software version: 27.6 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: Phone version: PDA version: G925FXXU4DPG8 CSC version: G925FAUT4DPG1 CSC country code: Switzerland CSC sales code: AUT HW version: Phone SN: Chip name: EXYNOS7420 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.6 |
12-26-2016, 20:42 | #15 (permalink) | |
Insane Poster Join Date: Sep 2012
Member: 1808655 Status: Offline Thanks Meter: 27 | Quote:
try this modem only odin cp load later repair | |
The Following User Says Thank You to crow20 For This Useful Post: |
