06-07-2016, 00:04 | #1 (permalink) |
Insane Poster Join Date: Dec 2003 Age: 35
Member: 46926 Status: Offline Thanks Meter: 2 | S6 repair DRK - recovery.ini not found i have a s6 repaired IMEI when i flashed a new rom...it stucked at boot logo. so i would like to do DRK repair. but it said Checking Recovery file...not found Seraching Server...OK Can't write C:/xxxxxx/z3x/samsungtoolpro/Recovery.ini |
06-11-2016, 07:35 | #6 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1663210 Status: Offline Thanks Meter: 35 | SM-G928C MRK repare good REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair DRK Selected model: SM-G928C Software version: 25.5 Checking Recovery file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM6 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: G928CXXS2BPD4 Platform: exynos7420 Boot serial: 0215393341423035 Product board: zenlte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... OK Repairing DMVT key... OK Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.25.5 |
The Following User Says Thank You to touchchanny2 For This Useful Post: |
07-30-2016, 06:30 | #7 (permalink) | |
Insane Poster Join Date: Nov 2006 Location: Sri Lanka
Member: 392792 Status: Offline Sonork: lasa_dal Thanks Meter: 8 | Quote:
did you solved your issue?? Im having the same | |
