07-12-2016, 14:10 | #1 (permalink) |
Crazy Poster Join Date: May 2013 Location: venezuela
Member: 1946869 Status: Offline Sonork: tonyx Thanks Meter: 7 | s7 edge g935f error remove google account UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 25.9 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM154 Setup connection... OK Reading data from phone... error Done with Samsung Tool PRO v.25.9 |
07-12-2016, 21:04 | #3 (permalink) |
Member: 1946869 Status: Offline Sonork: tonyx Thanks Meter: 7 | Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 25.9 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM48 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: PDA version: G935FXXU1APF2 CSC version: G935FDBT1APB1 CSC country code: TRINIDAD AND TOBAGO CSC sales code: TTT HW version: Phone S/N: RF8H501Y6PE Modem board: RF cal date: IMEI: Checking Super user right... true Erasing FRP... OK Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.25.9 |
